  3. first battery powered DHT lux
10 Posts 2 Posters 2.4k Views 1 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    hi guys so im trying to build my first sensor from scratch, its using the easyPCB @sundberg84 (CHEERS)!
    im having issues combining it all for the DHT
    i keep getting dht was not declared
    so its a battery sensor with a DHT 22 and a photo resistor for lux
    here is my code
    anyone with advice would be greatly appreciated
    // Enable debug prints
    #define MY_NODE_ID 3
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define LIGHT_SENSOR_ANALOG_PIN A1
    unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
    #define SKETCH_NAME "loungeroom living sensor #1"        // Change to a fancy name you like
    #define SKETCH_VERSION "1"                    // Your version
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int LightLevel = 0;
    int lastLightLevel;
    MyMessage LightMsg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    // BATTERY VOLTAGE DIVIDER SETUP
    #define VBAT_PER_BITS 0.003363075
    #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0;                              // Calc value for battery %
    int batLoop = 0;                                  // Loop to help calc average
    int batArray[3];                                  // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
     analogReference(INTERNAL);             // For battery sensing
      delay(500); // Allow time for radio if power used as reset
      metric = getConfig().isMetric;
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_LIGHTLEVEL, S_LIGHT_LEVEL);
      // Fetch temperatures from DHT sensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        Serial.print("T: ");
        Serial.println(temprature);
      // Fetch humidity from DHT sensor
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          send(LightMsg.set(lightLevel));
          lastLightLevel = lightLevel;
      batM();
      sleep(SLEEP_TIME); //sleep a bit
    void batM() //The battery calculations
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       float Vbat  = sensorValue * VBAT_PER_BITS;
       int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
       Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       // Add it to array so we get an average of 3 (3x20min)
       batArray[batLoop] = batteryPcnt;
       if (batLoop > 2) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
         batteryPcnt = batteryPcnt / 3;
       if (batteryPcnt > 100) {
         batteryPcnt=100;
         Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
           batLoop = 0;
         else
         batLoop++;
    • markjgabbM markjgabb
      here is my code
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      int LightLevel = 0;
      int lastLightLevel;
            lastHum = humidity;
        batM();
         delay(500);
         delay(500);
         if (batLoop > 2) {
           batteryPcnt=100;
             batLoop = 0;
           else
           batLoop++;
      @markjgabb you need to install the external dht22 library and you forgot to declare dht. (DHT dht;)
      See my sketch https://github.com/sundberg84/MySensors2.0.0/blob/master/NorrHumAs/NorrHumAs.ino
      • markjgabbM
        markjgabbM
        markjgabb
        @sundberg84
        i copied your github one directly....
        but when i try to verify i get the following error
        exit status 1
        no matching function for call to 'DHT::DHT()'
          @sundberg84
          exit status 1
          @markjgabb did you install the library?
          • markjgabbM
            markjgabbM
            markjgabb
            i did install DHT library...but mine seems to be diffrent, if i manually include it i get dht_U.h
            • markjgabbM
              markjgabbM
              markjgabb
              wrote on last edited by markjgabb
              dht sensor library by adafruit installed version 1.3.0
              • markjgabbM
                markjgabbM
                markjgabb
                @sundberg84 copied a dht library from another computer i used last time i did mysensors work...now ive got that base sketch working....now to add the photo resistor
                • markjgabbM
                  markjgabbM
                  markjgabb
                  @sundberg84 champion and here is completed sketch which compiles without errors
                  #define MY_NODE_ID 14
                  #define MY_PARENT_NODE_ID 100
                  #include <DHT.h>
                  unsigned long SLEEP_TIME = 120000; // Sleep time between reads (in milliseconds)
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                  int LightLevel = 0;
                  int lastLightLevel;
                      Serial.println(temperature);
                        lastHum = humidity;
                    batM();
                     delay(500);
                     delay(500);
                     if (batLoop > 2) {
                       batteryPcnt=100;
                         batLoop = 0;
                       else
                       batLoop++;
                    #include <DHT.h>
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    int LightLevel = 0;
                    int lastLightLevel;
                          lastHum = humidity;
                      batM();
                       delay(500);
                       delay(500);
                       if (batLoop > 2) {
                         batteryPcnt=100;
                           batLoop = 0;
                         else
                         batLoop++;
                    @markjgabb - nice to hear!
                    I always use the librarys in the ext. MySensors folder: https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries since they are known to work with the sketches in the build section.
                    Also note that you have fixed the ID and parent node now... you might want to remove those lines
                    atleast the parent_node_id because that is a repeater in my setup... so unless you have a repeater woth 100 as id this will not work.
                    If you have flashed this to the node, it might be a good idea to clear the eeprom before flashing the new sketch without the parent_node_id feature.
                    • markjgabbM
                      markjgabbM
                      markjgabb
                      @sundberg84 nah just prrof of build at the moment...ill fix them with my proper node ID's when it's build time....waiting on step up's at the moment..... they seem to take a while when you find them cheaper
