  3. Jeedom plugin configuration
5 Posts 4 Posters 3.4k Views 1 Watching
  • G
    G
    Giacometti Michele
    First I want to congratulate to the inventor of this very exciting project.
    I have a problem with the plugin on configuration jeedom controller.
    in the images attached to post my configuration, but can not be answered by the sensors.
    can you give me some advice ??
    Screenshot from 2014-12-15 14:21:18.png
    Screenshot from 2014-12-15 14:22:54.png
      Mattia Reggiani
      Hi Michele, have you try to "reboot" the sensore Node, because only when Sensore Node "boot" he send the presentation information to the Controller (Jeedom).
      Normally the sensore is added in automatic.
      Check the log in Main->management->logs and select mySensors from dropdown menù on the top let, in this log you can see the communication between Gateway and node.
      • T
        Tibus
        Also update your sensors in 1.4.1 and update your MySensor plugin. It comes with a "new system" for Serial Gateway.
        If you want more help about jeedom or mysensors on jeedom, please go to the jeedom's forum where there's a mysensor sub-forum with a lot of people and very active. (Even more active than this forum ;D) You can post in english, no problems!
        https://forum.jeedom.fr/viewforum.php?f=35
        • G
          G
          Giacometti Michele
          I tried many variations and this is what I am now in the logs.
          I have never been able to bring up any device.
          thanks in advance for how you can help
          22-02-2015 22:09:12 | info | Save Value : Value-24-0-3
          22-02-2015 22:09:12 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=3&donnees=23&value=24
          22-02-2015 22:09:12 | info | Got response Value: 200
          <- 0;255;0;0;17;1.4.1
          22-02-2015 22:09:25 | info | Save saveLibVersion : Value-0-1.4.1
          22-02-2015 22:09:25 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveLibVersion&type=mySensors&id=0&value=1.4.1
          22-02-2015 22:09:26 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:26 | info | Got response saveLibVersion: 200
          <- 0;0;0;0;7;1.4.1
          22-02-2015 22:09:27 | info | Save saveSensor : Value-0-0-7
          22-02-2015 22:09:27 | info | Save saveLibVersion : Value-0-1.4.1
          22-02-2015 22:09:27 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveLibVersion&type=mySensors&id=0&value=1.4.1
          <- 0;1;0;0;6;1.4.1
          22-02-2015 22:09:27 | info | Save saveSensor : Value-0-1-6
          <- 0;2;0;0;1;1.4.1
          22-02-2015 22:09:27 | info | Save saveSensor : Value-0-2-1
          22-02-2015 22:09:28 | info | Got response saveSensor: 200
          22-02-2015 22:09:28 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:28 | info | Got response saveLibVersion: 200
          22-02-2015 22:09:29 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:29 | info | Got response saveLibVersion: 200
          <- 0;3;0;0;16;1.4.1
          22-02-2015 22:09:29 | info | Save saveSensor : Value-0-3-16
          22-02-2015 22:09:29 | info | Save saveLibVersion : Value-0-1.4.1
          22-02-2015 22:09:29 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveLibVersion&type=mySensors&id=0&value=1.4.1
          <- 0;4;0;0;0;1.4.1
          22-02-2015 22:09:29 | info | Save saveSensor : Value-0-4-0
          22-02-2015 22:09:30 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:30 | info | Got response saveSensor: 200
          22-02-2015 22:09:30 | info | Got response saveLibVersion: 200
          <- 0;1;1;0;0;20.0
          22-02-2015 22:09:30 | info | Save Value : Value-20.0-0-1
          22-02-2015 22:09:30 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=1&donnees=0&value=20.0
          <- 0;0;1;0;1;38.0
          22-02-2015 22:09:30 | info | Save Value : Value-38.0-0-0
          22-02-2015 22:09:30 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=0&donnees=1&value=38.0
          <- 0;2;1;0;16;0
          22-02-2015 22:09:30 | info | Save Value : Value-0-0-2
          22-02-2015 22:09:30 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=2&donnees=16&value=0
          <- 0;3;1;0;23;27
          22-02-2015 22:09:30 | info | Save Value : Value-27-0-3
          22-02-2015 22:09:30 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=3&donnees=23&value=27
          <- 0;4;1;0;16;1
          22-02-2015 22:09:30 | info | Save Value : Value-1-0-4
          22-02-2015 22:09:30 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=4&donnees=16&value=1
          22-02-2015 22:09:30 | info | Got response Value: 200
          22-02-2015 22:09:31 | info | Got response Value: 200
          22-02-2015 22:09:31 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:31 | info | Got response saveSensor: 200
          22-02-2015 22:09:31 | info | Got response saveLibVersion: 200
          22-02-2015 22:09:38 | info | Save saveLibVersion : Value-0-1.4.1
          22-02-2015 22:09:38 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveLibVersion&type=mySensors&id=0&value=1.4.1
          22-02-2015 22:09:39 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:40 | info | Got response saveLibVersion: 200
          <- 0;0;0;0;7;1.4.1
          22-02-2015 22:09:40 | info | Save saveSensor : Value-0-0-7
          22-02-2015 22:09:40 | info | Save saveLibVersion : Value-0-1.4.1
          22-02-2015 22:09:40 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveLibVersion&type=mySensors&id=0&value=1.4.1
          <- 0;1;0;0;6;1.4.1
          22-02-2015 22:09:40 | info | Save saveSensor : Value-0-1-6
          <- 0;2;0;0;1;1.4.1
          22-02-2015 22:09:40 | info | Save saveSensor : Value-0-2-1
          <- 0;3;0;0;16;1.4.1
          22-02-2015 22:09:40 | info | Save saveSensor : Value-0-3-16
          <- 0;4;0;0;0;1.4.1
          22-02-2015 22:09:41 | info | Save saveSensor : Value-0-4-0
          22-02-2015 22:09:41 | info | Save saveLibVersion : Value-0-1.4.1
          22-02-2015 22:09:41 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveLibVersion&type=mySensors&id=0&value=1.4.1
          <- 0;1;1;0;0;21.0
          22-02-2015 22:09:42 | info | Save Value : Value-21.0-0-1
          22-02-2015 22:09:42 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=1&donnees=0&value=21.0
          <- 0;0;1;0;1;37.0
          22-02-2015 22:09:42 | info | Save Value : Value-37.0-0-0
          22-02-2015 22:09:42 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=0&donnees=1&value=37.0
          <- 0;2;1;0;16;0
          22-02-2015 22:09:42 | info | Save Value : Value-0-0-2
          22-02-2015 22:09:42 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=2&donnees=16&value=0
          22-02-2015 22:09:42 | info | Got response saveSensor: 200
          22-02-2015 22:09:42 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:42 | info | Got response saveLibVersion: 200
          22-02-2015 22:09:43 | info | Got response saveSensor: 200
          22-02-2015 22:09:43 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:44 | info | Got response saveLibVersion: 200
          22-02-2015 22:09:44 | info | Gateway Lib 1.4.11.4.1
          22-02-2015 22:09:44 | info | Got response saveSensor: 200
          <- 0;3;1;0;23;24
          22-02-2015 22:09:44 | info | Save Value : Value-24-0-3
          22-02-2015 22:09:44 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=3&donnees=23&value=24
          <- 0;4;1;0;16;1
          22-02-2015 22:09:44 | info | Save Value : Value-1-0-4
          22-02-2015 22:09:44 | info | http://127.0.0.1:8082/jeedom/core/api/jeeApi.php?api=2k42jteg6jhwsjt7n80u&messagetype=saveValue&type=mySensors&id=0&sensor=4&donnees=16&value=1
          22-02-2015 22:09:44 | info | Got response Value: 200
          22-02-2015 22:09:45 | info | Got response Value: 200
          L 1 Reply Last reply
          • G Giacometti Michele
            <- 0;0;0;0;7;1.4.1
            <- 0;1;0;0;6;1.4.1
            <- 0;2;0;0;1;1.4.1
            <- 0;3;0;0;16;1.4.1
            <- 0;4;0;0;0;1.4.1
            <- 0;1;1;0;0;20.0
            <- 0;0;1;0;1;38.0
            <- 0;2;1;0;16;0
            <- 0;3;1;0;23;27
            <- 0;4;1;0;16;1
            <- 0;0;0;0;7;1.4.1
            <- 0;1;0;0;6;1.4.1
            <- 0;2;0;0;1;1.4.1
            <- 0;3;0;0;16;1.4.1
            <- 0;4;0;0;0;1.4.1
            <- 0;1;1;0;0;21.0
            <- 0;0;1;0;1;37.0
            <- 0;2;1;0;16;0
            <- 0;3;1;0;23;24
            <- 0;4;1;0;16;1
            L
            L
            lunarok
            @Giacometti-Michele : your sensor present itself with an ID 0.
            That's not possible, the sensor must have an ID of 1 at least.
            Can you try a clear eeprom ?
            Now Jeedom is translated in english/russian and partialy in spanish/indonesian/italian. If you like Jeedom maybe you can help (for the latest one ? :)) We use transifex for translating.
