  3. Switch with 3 settings - domoticz
3 Posts 3 Posters 2.1k Views 2 Watching
  • B Offline
    B Offline
    Ben Andrewes
    I am trying to create a switch that has 3 states but am unsure what to present it as. It will be used to send a setting, that can be one of 3 things, to the node.
    What I'd like is a simple selector switch in Domoticz which has 3 buttons and if button 1 is pressed it sends e.g. value1 to the node (which will then change a setting within the node).
    I have tried presenting an S_Custom child with V_VAR1 as the message but nothing shows in Domoticz.
    Am I missing an obvious solution?
    S 1 Reply Last reply
    • B Ben Andrewes
      @Ben-Andrewes - One way is to select a dimmer function, and only use the first values? Depends on how you wants it to look in Domoticz.
      In edit under each switch you can select switch type.
      • K Offline
        K Offline
        kimot
        https://forum.mysensors.org/topic/4933/using-the-selector-switch-in-domoticz-tutorial
        12.2k
