  3. My 1AA battery sensor
prototypepoweredbatterylow
23 Posts 9 Posters 27.0k Views 6 Watching
  • T
    that0n3guy
    Well, if its pulling ~1mA, then it should only last about a month or two. (right?)
    You could also pull battery voltages to see the battery "level" as well.
    • klimK klim
      Hi, i want to present you my working but not really sexy looking single cell AA battery sensor. It is as it is - under development and was just made to get some experience about power consumption and physical size.
      I thought a lot about the type of battery to choose, but at the end i desisted to use an ordinary AA cell. I know about the advantages and disadvantages of different battery chemistry and types, but in the aspect of price/mA the AA battery is still the winner. Self discharge of a few years is acceptable for that type of battery.
      Another aspect i followed is, just to use buy-able and assembled modules, as i don't have enough time to build my own arduino board, or battery management (step up), etc. .....
      The core of the sensor is the battery itself. The components are mounted around the battery. The sensor can be completely disassembled in a few seconds, as the modules are just connected with pin headers.
      The power consumption for sleep is around 90µA, if i can believe my Fluke 175. The power consumption of normal operation and transmit i don't post here, because of two reasons:
      1. I was not able to get a good measurement result with a multimeter. I should integrate the consumption over time to get a real result.
      2. The lifetime of a sensor is dominated by the sleep consumption, not by the operating consumption (if transmission time is just a few times per hour)
      There are still some improvements to do, but ehh, this is just a prototype.
      Used components:
      -Arduino pro mini 3.3V @ 8Mhz (mcu board)
      -NRF24L01 (wireless board)
      -3.3V StepUp (0.8V-3.3V from Canton electronic an ebay product link)
      Modifications:
      -Arduino board: Cut LED
      -Arduino board: Cut LDO
      -StepUp board: Cut LED
      Physical dimensions (without pin headers):
      65mm x 22mm x 25mm
      Which values the sensor can send?
      In general this is just a battery monitor, as i want to get some experience of power consumption, but the pin header is able to work with various types of sensors. I use a simple DS18B20 temperature sensor on the header pins.
      Here are some pictures:
      Overall view1
      upload-55448569-77ab-4346-80ce-0fbb859991ea
      Overall view2
      upload-47cc27d8-c72c-47f6-8219-ed2668202c61
      Overall view3
      upload-ec04de50-8172-4891-914f-413dafa86824
      Overall view4
      upload-10334a15-91fb-4171-bda9-92e976e95de7
      Unused space over battery, but i didn't had the correct pin headers at home "mea culpa"
      upload-3e47d133-e3e2-46e0-8fc1-c3d667439ece
      Disassembled view1
      upload-fce77d46-7b45-4388-920d-f74055c0a75e
      Disassembled view2
      upload-6278a2b6-a1ce-41a1-a788-146209c0ab04
      Assemble view1
      upload-aba7428f-b2b4-40c3-a727-c4923e15f347
      Assemble view2
      upload-46644d8c-9537-431b-8bc2-eeaace130e79
      Assemble view3
      upload-2dd25b83-45e6-4861-9934-9fb3288185ef
      Assemble view4
      upload-d954cb15-453d-4817-bc0c-cb589acdf69d
      Assemble view5
      upload-ea78b989-eeb8-4d9d-be4d-846bf6b3e8d1
      Bottom view (remember - just a prototype)
      upload-62b434cd-c8d5-48dd-b959-d897f8de4224
      I hope i could give you some potential ideas for your own project.
      Questions, suggestions, feedback, all is welcome.
      TotcheT
      TotcheT
      Totche
      @klim Nice integration.
      Do you have a schematic of your board ?
      especially for the pins with the jumper.
      As I can see, the blue jumper is for open/closed current loop, but for the other pins ?
      • jsiddallJ
        jsiddallJ
        jsiddall
        Looks like it has been a year or two now. Is it still going on the original battery?
