  3. Gas Meter
Gas Meter
1 Posts 1 Posters 1.5k Views 1 Watching
  • 1kohm1
    1kohm1
    1kohm
    I'm working on gas meter using In-Z61 reed sensor - it's dedicated for gas meters.
    My node is build based on https://www.mysensors.org/hardware/ac-dc-ssd-relay
    My controller is Domo: v3.8258
    My gateway is Arduino UNO shield
    Data is send over to Domo as designed
    One full rotare of gas meter 00.000 [m3] -> 00.010 [m3] is one impuls triggered by reed sensor.
    This is working - after one rotare i got value send to Domo:
    The issue is that after some while the counter still increments - no actual meter movement is done
    Below is debug - pulse was 100 and was changed to 101.
    pulsecount:100
    TSP:MSG:SEND 8-8-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=ok:100
    volume:0.100
    TSP:MSG:SEND 8-8-0-0 s=1,c=1,t=35,pt=7,l=5,sg=0,ft=0,st=ok:0.100
    TSP:MSG:READ 7-7-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSP:MSG:BC
    TSP:MSG:BC
    l/min:0.03
    TSP:MSG:SEND 8-8-0-0 s=1,c=1,t=34,pt=7,l=5,sg=0,ft=0,st=ok:0.03
    pulsecount:101
    TSP:MSG:SEND 8-8-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=ok:101
    volume:0.101
    TSP:MSG:SEND 8-8-0-0 s=1,c=1,t=35,pt=7,l=5,sg=0,ft=0,st=ok:0.101
    TSP:MSG:BC
    pulsecount:101
    As a sketch I use modified version of PulseWaterMeter - https://www.mysensors.org/build/pulse_water
    I changed presentation:
     present(CHILD_ID, S_GAS);
    and added node temp sensor:
    present(CHILD_DSB_ID, S_TEMP);
    It looks like some kind of bouncing effect, but have no idea why counter increments itself.
    Help me out to make the code more clear and free of errors.
    code below:
     * Version 1.0 - Henrik Ekblad
     * Version 1.1 - GizMoCuz
     * Use this sensor to measure volume and flow of your house watermeter.
     * You need to set the correct pulsefactor of your meter (pulses per m3).
     * The sensor starts by fetching current volume reading from gateway (VAR 1).
     * Reports both volume and flow back to gateway.
     * Unfortunately millis() won't increment when the Arduino is in
     * sleepmode. So we cannot make this sensor sleep if we also want
     * to calculate/report flow.
     * http://www.mysensors.org/build/pulse_water
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #include <Bounce2.h>
    #include <OneWire.h>
    #define CHILD_DSB_ID 13
    #define ONE_WIRE_BUS 8
    #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
    #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
    #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
    #define CHILD_ID 1                              // Id of the sensor child
    unsigned long SEND_FREQUENCY =
        3000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool state;
    Bounce debouncer2 = Bounce();
    int oldValue2 = 0;
    bool state2;
    MyMessage flowMsg(CHILD_ID,V_FLOW);
    MyMessage volumeMsg(CHILD_ID,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    MyMessage msgTemp(CHILD_DSB_ID, V_TEMP);
    OneWire oneWire(ONE_WIRE_BUS);
    double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
    volatile double flow = 0;
    bool pcReceived = false;
    unsigned long newBlink = 0;
    double oldflow = 0;
    double volume =0;
    double oldvolume =0;
    unsigned long lastSend =0;
    unsigned long lastPulse =0;
        // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
        pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
        pulseCount = oldPulseCount = 0;
        request(CHILD_ID, V_VAR1);
        lastSend = lastPulse = millis();
        attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
        sendSketchInfo("Gas Meter", "1.1");
        // Register this device as Waterflow sensor
        static float prevTemp = 0;
        unsigned long currentTime = millis();
        if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY)) {
            lastSend=currentTime;
            if (!pcReceived) {
                //Last Pulsecount not yet received from controller, request it again
                return;
            if (!SLEEP_MODE && flow != oldflow) {
                oldflow = flow;
                Serial.print("l/min:");
                Serial.println(flow);
                // Check that we dont get unresonable large flow value.
                // could hapen when long wraps or false interrupt triggered
                if (flow<((unsigned long)MAX_FLOW)) {
                    send(flowMsg.set(flow, 2));                   // Send flow value to gw
            // No Pulse count received in 2min
            if(currentTime - lastPulse > 120000) {
                flow = 0;
            // Pulse count has changed
            if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                oldPulseCount = pulseCount;
                Serial.print("pulsecount:");
                Serial.println(pulseCount);
                send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                if ((volume != oldvolume)||(!SLEEP_MODE)) {
                    oldvolume = volume;
                    Serial.print("volume:");
                    Serial.println(volume, 3);
                    send(volumeMsg.set(volume, 3));               // Send volume value to gw
        float temperature = static_cast<float>(static_cast<int>(sensors.getTempCByIndex(0) * 10.f)) / 10.f;
        if (temperature != -127.00f && temperature != 85.00f && prevTemp != temperature) {
            Serial.print("Sent temperature: ");
            Serial.println(temperature);
            prevTemp = temperature;
        if (SLEEP_MODE) {
            sleep(SEND_FREQUENCY);
        if (message.type==V_VAR1) {
            unsigned long gwPulseCount=message.getULong();
            pulseCount += gwPulseCount;
            flow=oldflow=0;
            pcReceived = true;
    void onPulse()
        if (!SLEEP_MODE) {
            unsigned long interval = newBlink-lastBlink;
            if (interval!=0) {
                if (interval<500000L) {
                    // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                    return;
                flow = (60000000.0 /interval) / ppl;
            lastBlink = newBlink;
        pulseCount++;
