  3. Send pH, Redox and temperature values to domoticz
7 Posts 2 Posters 3.4k Views 2 Watching
  • Jérôme Mathues KoodyJ Offline
    In first time, sorry but my english is not very good.
    I will explain my project:
    I put in place a pool regulation with an arduino Mega and an LCD screen.
    • pH value of the water pool
    • Redox value
    • temperature of the water
    • pump to inject Chlore for the redox
    • pump to inject acid for the pH
    My system works as I want.
    My next step is:
    • Send the pH value to domoticz ( between 6.8 and 8.0 ) (float)
    • Send the Redox value to domoticz ( between 400 and 1000 ) (int)
    • send the temperature value
    I would like to be able to control the light and the heat pump of the pool throught domoticz.
    I allready have some mysensors nodes at home ( light level, temperature and motion sensors ) wiches are working perfectly.
    I don't know how to send the pH and the Redox values
    It will be kind of you if someone could help me.
    Best regards
    Jerome
    Belgium
    • Jérôme Mathues KoodyJ Jérôme Mathues Koody
      • Redox value
      My next step is:
      Best regards
      Jerome
      Belgium
      Welcome @Jérôme-Mathues-Koody !
      I think you could use S_WATER_QUALITY and V_ORP + V_PH. See https://www.mysensors.org/download/serial_api_20#sensor-types for a complete list of the supported sensor types.
      See https://www.openhardware.io/view/381/Floating-Swimming-Pool-Sensor-Water-Quality for a similar project, maybe you can reuse some of Ric's ideas/code.
        thanks @mfalkvidd I will have a look at this.
          I have a look at https://www.openhardware.io/view/381/Floating-Swimming-Pool-Sensor-Water-Quality
          In fact, in my arduino code, I take the average value of the ph and the redox to keep stability of the values. I record it into 2 variables:
          • float pH
          • int Redox
          So I have to use the "var1_msg( 0 , V_VAR1 )," to send my variables as I can see in the "sensor water quality" project.
          I will try this
            Oups!
            Unfortunatly, my LCD allready use the PIN 2 of the arduino.
            As I need to connect my NRF24L01+ on my Arduino mega, I need to use the PIN 2 also for the RF.
            Do you know if it's possible to map the LCD on other PIN?
            For the moment, it's map like this:
            LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
            Thank you for your help
            Jerome
              Oups!
              Jerome
              @Jérôme-Mathues-Koody just us another number instead of 2?
                I try to change the pin 2 by another but my lcd doesn't works.
                I don't know if it's possible to change the assignment for the pin lcd.
                To put in place the lcd I have used a tutorial. I have a look on google but a lot of tutorials have the same pin assignment.
