  3. RelayWithButtonActuator Example with touch sensor
relay
7 Posts 3 Posters 3.5k Views 1 Watching
  • C
    C
    C.r.a.z.y.
    I tried RelayWithButtonActuator Example with touch sensor but didnt work.
    When i touch serial prints 111111111.... but relay state doesnt change.
    After 3-5 secs touching it stops printing like this;
    send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:1
    • C C.r.a.z.y.
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @C.r.a.z.y.
      Looks like the sensor may need de-bouncing.
      What are you using to check that? A simple sketch that toggles the on- board led on pin 13 would be easiest.
      C 1 Reply Last reply
        Are you powering the relay separately?
          @C.r.a.z.y.
          C
          C
          C.r.a.z.y.
          wrote on last edited by C.r.a.z.y.
          @BulldogLowell I am using original sketch didnt make any change.
          @hek Only touch sensor was powered separately.
          Same power source for touch and relay result;
          It stopped working after getting 2 touch at the end of 2 rows print.
          repeater started, id 0
          send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
          send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
          send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=14,st=fail:Relay & Button
          send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
          send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
          • C C.r.a.z.y.
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @C.r.a.z.y.
            what kind of touch sensor do you have?
              @C.r.a.z.y.
              C
              C
              C.r.a.z.y.
              @BulldogLowell http://www.dx.com/p/catalex-digital-capacitive-touch-sensor-switch-module-for-arduino-blue-black-230867#.VJWV4sgM
              catalex
              • C C.r.a.z.y.
                catalex
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @C.r.a.z.y.
                yeah.... those are VERY bouncy.
                are you interrupt triggering or just using a state change?
                post your code, let's make sure you have it de-bounced enough.
