  3. OpenHAB
  4. Beginner - what is wrong
45 Posts 6 Posters 16.8k Views 6 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @zeroxdeadbeef
    the SB micro is using the standard 6pin AVR-ISP header.
    Would be interesting to get a memory dump from a fresh SB micro that exhibits the problems with programming.. One of my theories is that it lacks the bootloader, or are misconfigured somehow from the factory.
    • X
      X
      xmonika
      The programmer has 10 pins but the GND is presented 4x. Check the picture [here](http://www.avrfreaks.net/forum/adapter-program-10-pin-6-pin-socket-cable-computer-pc-led-reset-power for wiring, this is how I did it.
      • Z
        Z
        zeroxdeadbeef
        Thanks for your responses. Sadly, both of my devices are not in factory state anymore. Nevertheless, I will report back after I have received this USBISP programmer.
        • Z
          Z
          zeroxdeadbeef
          Hello!
          Finally, I have received this USB programmer... I wired everything up, but flashing the Sensebender Micros does not work, sadly. According to avrdude they do not seem to respond:
          avrdude: warning: cannot set sck period. please check for usbasp firmware update.
          avrdude: error: program enable: target doesn't answer. 1
          avrdude: initialization failed, rc=-1
                   Double check connections and try again, or use -F to override
                   this check.
          Error while burning bootloader.
          I managed to program and burn the bootloader of a normal Arduino Pro Mini using this programmer and the same cable, so the programmer is working as expected.
          • sinczeS
            sinczeS
            sincze
            MySensors Evangelist
            Mmm i think I received a DOA... No pling pling sound in windows...
