  3. OpenHAB
  4. Beginner - what is wrong
45 Posts 6 Posters 17.4k Views 6 Watching
  • X
    X
    xmonika
    I have successfully installed MySensors 2.2.0 beta, Openhab 2.1 on Raspberry 3 and connected NRF24l01+. Using MQTT.
    Once I've started mysensors gateway there is some communication between node and gateway but the node doesn't get response
    /MySensors $ sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-beta
     __  __       ____
            |___/                      2.2.0-beta
    mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: Attempting MQTT connection...
    mysgw: connected to 127.0.0.1
    mysgw: MQTT connected
    mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
    mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
    mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
    Could you help me what should I try next? Is that HW error, some wrong configuration or anything else?
    My mqtt.cfg has this configuration
    mqtt:mysensors.url=tcp://localhost:1883
    mqtt:mysensors.clientId=openHAB
      How did you connect the radio modules? Did you use any capacitor? Do you have a serial debug of the node?
      • X
        X
        xmonika
        Thank you for the reply, I've connected it to the raspberry directly (pins 19-24) as described here https://www.mysensors.org/build/raspberry. I've been playing with adding a capacitor 47 uF to both node and raspberry with no efect. I don't have debug of the node, it is mysensebender micro - standalone.
        One way could be to replace gateway direct connection or node with arduino and start tracking. At this moment I don't know if I shall focus my energy to track hardware or there is just some SW tweak/configuration I've missed.
        What I know for sure - if I disconect battery (two AA) from the node and reconnect it again the gateway writes some READ,255-255-0 rows above - according to log parser indicating that the node is requesting for ID but the gateway doesn't respond (just my guess).
          Could also be, if you post your code of the node we could take a look
          • X
            X
            xmonika
            It is just new mysensebender micro out of the box, I suppose this code https://www.openhardware.io/view/1/Sensebender-Micro but I may be wrong. It has the same behavior - when GND and A0 connected during boot, the led blinks.
              after #define MY_RADIO_NRF24 add
              #define MY_NODE_ID 1
              • X
                X
                xmonika
                Thank you for pointing my focus. I will try to experiment with that tonight.
                X 1 Reply Last reply
                • X xmonika
                  X
                  X
                  xmonika
                  wrote on last edited by xmonika
                  Unfortunately I couldn't move futher because of not being able to upload sketch into the node. I've bought CP1202 USB-TTL/3V3 with DTR pin, downgraded Arduino IDE to 1.6.13, set up Mysensebender micro board, COM6, ATmega328 8 MHz and tried all the programmers available but everytime got
                  Arduino: 1.6.13 (Windows 10), Vývojová deska: "Sensebender Micro, Atmega328 8Mhz"
                  Projekt zabírá 20 862 bytů (67%)  úložného místa pro program. Maximum je 30 720 bytů.
                  Globální proměnné zabírají 747 bytů (36%)  dynamické paměti, 1 301 bytů zůstává pro lokální proměnné. Maximum je 2 048 bytů.
                  avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc2
                  avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x37
                  avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb4
                  avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x57
                  avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc5
                  avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
                  avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
                  avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd9
                  avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe5
                  avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x41
                  Nastala chyba při nahrávaní projektu.
                  Táto zpráva by měla mít víc informacií v
                  "Zobrazení podrobného výstupu při kompilaci"
                  podle zapnuté volby v Soubor -> Nastavení.
                  I've tried to switch Tx/Rx but not helped. I can track serial output, so there is some transfer
                  Sensebender Micro FW 1.1req node id
                  send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
                  sensor started, id 255
                   - Online!
                  req node id
                  req node id
                  req node id
                  req node id
                  isMetric: 1
                  req node id
                  T: 21.09
                  H: 53
                  Any ideas how to setup IDE to push the code into node?
                  • Nca78N
                    Nca78N
                    Hello, you should link TX of the adapter to RX on the board, and RX to TX.
                    Make sure DTR pin is corretly connected to DTR pin of the board and check all the wires you could have a defective one.
                    Selected programmer in Arduino should be AVR ISP mk2
                      If you have the red ftdi like in the picture, you can plug it straight in
                      • X
                        X
                        xmonika
                        I have this one alt text.
                        The programmer I am using is called AVRISP.mkII, hope that is correct.
                        I have the RX-TX and TX-RX connected. I tried to switch them as well and suppose they are now correct because serial monitor works. DTR on the adapter is connected to the board. The board in self test mode works ok, so it is not damaged.
                        The output is the error as above. This is very frustrating I already have some experience with arduino but here after 20+ hours of experimenting I am not able to get out of point zero.
                        Anyway thank you for your patience and help.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @xmonika
                          The node requests an ID from the controller.. It is also shown in the MQTT on your raspberry pi, but the controller doesn't seem to reply to this ID request.
                          Have you configured OpenHAB to use MQTT for the mysensor gateway? Does the log in OpenHAB tell you anything?
                          Did you try to hardcode the node ID, as suggested by @gohan? If yes, could you post the node and gateway logs after this?
                          gohanG 1 Reply Last reply
                          • tbowmoT tbowmo
                            @xmonika
                            @tbowmo he tried to add the node id, but he is stuck with the uploading of the sketch :D
                            @xmonika then you start to see "uploading" in arduino IDE, try pressing the reset button on the arduino and see if it starts transferring the program.
                              X
                              X
                              xmonika
                              @gohan But I don't have arduino, I have direct connection between USB/TTL and sensebender micro like this (double checked)
                              CP1202 USB-TTL <-> MySensebender micro
                              GND <-> GND
                              3v3 <-> VCC (tried as well with AA battery without VCC connected)
                              RX <-> TX
                              TX <-> RX
                              DTR <-> DTR
                              Is there some way to manipulate reset directly on Sensebender micro? Like try to generate edge with the wire?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @xmonika
                                What target do you use in Arduino, when you're trying to program the sensebender micro?
                                • tbowmoT tbowmo
                                  @xmonika
                                  X
                                  X
                                  xmonika
                                  @tbowmo In IDE (Arduino: 1.6.13 - Windows 10), I have: "Sensebender Micro, Atmega328 8Mhz" (it is also shown in the code above) is that correct configuration?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @xmonika
                                    And you can successfully see the debug log in your terminal program, from your sensebender micro?
                                    • tbowmoT tbowmo
                                      @xmonika
                                      X
                                      X
                                      xmonika
                                      @tbowmo Yes, i.e. now I can see in the terminal all this:
                                       - Online!
                                      req node id
                                      req node id
                                      req node id
                                      req node id
                                      isMetric: 1
                                      req node id
                                      T: 19.93
                                      H: 79
                                      req node id
                                      req node id
                                      tbowmoT 1 Reply Last reply
                                      • X xmonika
                                         - Online!
                                        req node id
                                        req node id
                                        req node id
                                        req node id
                                        isMetric: 1
                                        req node id
                                        T: 19.93
                                        H: 79
                                        req node id
                                        req node id
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @xmonika and still you can not upload a new sketch to this Pcb?
                                        • tbowmoT tbowmo
                                          X
                                          X
                                          xmonika
                                          @tbowmo Yes, exactly. By pressing Project Upload => not in sync and Upload error. By pressing Project Upload via programmer => just Upload error message. Here is my setup
