  3. Whitelist not wirking from sensor to gateway
26 Posts 2 Posters 5.6k Views 2 Watching
  • K
    K
    karelsmits
    wrote on last edited by karelsmits
    I am trying to set up a gateway-sensor setup. The sensor is based on the following; when the temperature (which is attached to arduino port 3) is reaching a certain point, the relay (port d4) should activate. All this is managed by a controller.
    The issue is, that I am trying to use whitelisting. I am able to accomplish everything without whitelisting. I added the serial of the gateway in the node-code (which has the temp dht11 and relay attached to it). And to the W5100 I added the serial of the sensor-node in the whitelist.
    The issuer is, that it seems that the gateway is receiving proper signing from the sensor-node, but when sending a command from the controller to the sensor-node (to activate the relay), it looks like the gateway is getting a SIGNING FAILED message. I don’t understand why; I added the gateway serial to the sensor-node (so it should accept commands from the gateway), but it still fails.
    This is the sensor-node code for whitelist:
    #define MY_NODE_ID 1
    // #define MY_SIGNING_SOFT
    // #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    // #define MY_SIGNING_REQUEST_SIGNATURES
    // #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 1,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}},{.nodeId = 2,.serial = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09}}}
    // Select soft/hardware signing method
    #define MY_SIGNING_SOFT //!< Software signing
    //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
    // Enable node whitelisting
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD9}}} // for gateway
    //#define MY_SIGNING_NODE_WHITELISTING {{{.nodeId = GATEWAY_ADDRESS,.serial = {0x4E,0xD3,0xAD,0x93,0xC6,0xF2,0xC6,0xF3,0x25}},{.nodeId = 2,.serial = {0xDC,0x1E,0x7F,0x20,0x62,0x2F,0xD3,0x04,0x29}}}
    // Enable this if you want destination node to sign all messages sent to this node.
    // SETTINGS FOR MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed
    // SETTINGS FOR MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
    And here is the code at the gateway:
    #define MY_NODE_ID 0
    // #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}},{.nodeId = 2,.serial = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09}}}
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 1,.serial = {0xB0,0x23,0xE6,0x8E,0x74,0x14,0x78,0x3B,0x3F}}} // for temp sensor DCC-arduino
    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 0,.serial = {0x4E,0xD3,0xAD,0x93,0xC6,0xF2,0xC6,0xF3,0x25}},{.nodeId = 1,.serial = {0xDC,0x1E,0x7F,0x20,0x62,0x2F,0xD3,0x04,0x29}}}
    //7C6389F07EF41C360A764100B8F18F45D6274116F3C287907087BBCD92E55DB5
    Here is the code at MyConfig.h:
    *  Message Signing Settings
     * @def MY_SIGNING_ATSHA204
     * @brief Enables HW backed signing functionality in library.
     * For any signing related functionality to be included, this define or @ref MY_SIGNING_SOFT has to be enabled.
     * @def MY_SIGNING_SOFT
     * @brief Enables SW backed signing functionality in library.
     * For any signing related functionality to be included, this define or @ref MY_SIGNING_ATSHA204 has to be enabled.
     * @def MY_SIGNING_REQUEST_SIGNATURES
     * @brief Enable this to inform gateway to sign all messages sent to this node.
     * If used for a gateway, gateway will only request signatures from nodes that in turn
     * request signatures from gateway.
     * @def MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL
     * @brief Enable this to have gateway require all nodes in the network to sign messages sent to it. @ref MY_SIGNING_REQUEST_SIGNATURES must also be set.
     * Use this for maximum security, but be aware that every single node will have to be personalized before they can be used.
     * Note that if this is enabled, and whitelisting is also enabled, whitelisting will also be in effect for all nodes.
    #define MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL
     * @def MY_VERIFICATION_TIMEOUT_MS
     * @brief Define a suitable timeout for a signature verification session
     * Consider the turnaround from a nonce being generated to a signed message being received
     * which might vary, especially in networks with many hops. 5s ought to be enough for anyone.
    #ifndef MY_VERIFICATION_TIMEOUT_MS
    #define MY_VERIFICATION_TIMEOUT_MS 5000
     * @def MY_SIGNING_NODE_WHITELISTING
     * @brief Enable to turn on whitelisting
     * When enabled, a signing node will salt the signature with it's unique signature and nodeId.<br>
     * The verifying node will look up the sender in a local table of trusted nodes and
     * do the corresponding salting in order to verify the signature.<br>
     * For this reason, if whitelisting is enabled on one of the nodes in a sign-verify pair, both
     * nodes have to implement whitelisting for this to work.<br>
     * Note that a node can still transmit a non-salted message (i.e. have whitelisting disabled)
     * to a node that has whitelisting enabled (assuming the receiver does not have a matching entry
     * for the sender in it's whitelist). The whitelist to use is defined as the value of the flag.
    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 0,.serial = {0x4E,0xD3,0xAD,0x93,0xC6,0xF2,0xC6,0xF3,0x25}},{.nodeId = 2,.serial = {0xDC,0x1E,0x7F,0x20,0x62,0x2F,0xD3,0x04,0x29}}}
     * @def MY_SIGNING_ATSHA204_PIN
     * @brief Atsha204 default pin setting
     * Pin where ATSHA204 is attached
    #ifndef MY_SIGNING_ATSHA204_PIN
     * @def MY_SIGNING_SOFT_RANDOMSEED_PIN
     * @brief Pin used for random generation in soft signing
     * Do not connect anything to this when soft signing is enabled
    #ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
    Just by the way, I did use the same soft HMAC key when generating the serials for gateway and sensor.
    Please let me know. Thank you all!
    Output of debug gateway:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.0.249
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0103
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0103
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:CDBB80B75188E97C55019080B5DBC7B88E56C99B1F9DEE5637
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.1.1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:389E3C0D6BC371BC3FC6306D86F6AD770D710692432EEFF172
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:2B05EA69845A4099778574B94125A5464F30707E44C3B73753
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=14,sg=1:Relay & Button
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:126653A761529A780711A7D6248C373A7E47D268A1C97AB3A9
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=5,c=3,t=16,pt=0,l=0,sg=1:
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:6417C73230C80E12FD0CD54F9E7711E53E755884D51FF1E570
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=5,c=0,t=3,pt=0,l=0,sg=1:
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:74DFCAA97CD3310E6FD38B5F9F6CA9A02EAE9B5CB0B1A2460E
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=22,sg=1:TemperatureAndHumidity
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:46F02801A65114F751195785F8F9F745595F8AD87280F5FE53
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:352C2B939E76A8E8E29E3B7BF3A1241103A0CC58BE4B419927
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=0,t=7,pt=0,l=0,sg=1:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:432E9E2657025B581CBE5BE2E3CE640A011B913FAEA14CF46C
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=1:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=17,pt=6,l=25,sg=0:CC21BFDF07D45E8E37774543D43D3C7DDC651C9AC1EC4C9A1F
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:BD94EB12AAE16A17BDCE22A888E91A3AC43143ABD2409C17CF
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=1:22.0
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:E3DD12079E4659DE001223D557048F89E311A6F0602C1979EF
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=1:45.0
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;2;
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;Eth: 1;5;1;1;2;0
    0;255;3;0;9;!TSF:MSG:SEND,0-0-1-1,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
    0;255;3;0;9;!TSF:MSG:SIGN FAIL
    Output of debug sensor-node:
    0 MCO:BGN:INIT NODE,CP=RNNNAS-,VER=2.1.1
    41 MCO:BGN:BFR
    58 TSM:INIT
    70 TSF:WUR:MS=0
    93 TSM:INIT:TSP OK
    112 TSM:INIT:STATID=1
    136 TSF:SID:OK,ID=1
    156 TSM:FPAR
    205 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    458 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=1:0
    514 TSF:MSG:FPAR OK,ID=0,D=1
    2278 TSM:FPAR:OK
    2295 TSM:ID
    2308 TSM:ID:OK
    2324 TSM:UPL
    2339 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4411 TSM:UPL
    4426 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4757 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4814 TSF:MSG:PONG RECV,HP=1
    4844 TSM:UPL:OK
    4860 TSM:READY:ID=1,PAR=0,DIS=1
    4895 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0103
    4970 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0103
    5032 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
    5127 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=0:CDBB80B75188E97C55019080B5DBC7B88E56C99B1F9DEE5637
    5329 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.1.1
    5407 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    5569 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:389E3C0D6BC371BC3FC6306D86F6AD770D710692432EEFF172
    5772 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
    7843 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    7923 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:2B05EA69845A4099778574B94125A5464F30707E44C3B73753
    8126 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=14,sg=1,ft=0,st=OK:Relay & Button
    8214 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    8377 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:126653A761529A780711A7D6248C373A7E47D268A1C97AB3A9
    8580 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
    8654 TSF:MSG:SEND,1-1-0-0,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    8815 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:6417C73230C80E12FD0CD54F9E7711E53E755884D51FF1E570
    9018 TSF:MSG:SEND,1-1-0-0,s=5,c=0,t=3,pt=0,l=0,sg=1,ft=0,st=OK:
    9088 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    9249 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:74DFCAA97CD3310E6FD38B5F9F6CA9A02EAE9B5CB0B1A2460E
    9452 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=1,ft=0,st=OK:TemperatureAndHumidity
    9548 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    9711 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:46F02801A65114F751195785F8F9F745595F8AD87280F5FE53
    9913 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
    9989 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    10149 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:352C2B939E76A8E8E29E3B7BF3A1241103A0CC58BE4B419927
    10353 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=1,ft=0,st=OK:
    10423 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    10583 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:432E9E2657025B581CBE5BE2E3CE640A011B913FAEA14CF46C
    10786 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
    10854 MCO:REG:REQ
    10875 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
    11003 TSF:MSG:READ,0-0-1,s=255,c=3,t=16,pt=0,l=0,sg=0:
    11077 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:CC21BFDF07D45E8E37774543D43D3C7DDC651C9AC1EC4C9A1F
    11291 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=1:1
    11440 MCO:PIM:NODE REG=1
    11466 MCO:BGN:STP
    11486 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
    11544 MCO:SLP:TPD
    11564 MCO:SLP:WUP=-1
    11585 MCO:BGN:INIT OK,TSP=1
    11639 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    11717 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:BD94EB12AAE16A17BDCE22A888E91A3AC43143ABD2409C17CF
    11921 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:22.0
    T: 22.00
    11996 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    12155 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:E3DD12079E4659DE001223D557048F89E311A6F0602C1979EF
    12358 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=1,ft=0,st=OK:45.0
    H: 45.00
    12431 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    12500 MCO:SLP:TPD
    12519 MCO:SLP:WUP=-1
    12563 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    12622 MCO:SLP:TPD
    12642 MCO:SLP:WUP=-1
    12686 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    12745 MCO:SLP:TPD
    Thanks for your help!!
    AnticimexA 1 Reply Last reply
    • K karelsmits
      IP: 192.168.0.249
      41 MCO:BGN:BFR
      58 TSM:INIT
      70 TSF:WUR:MS=0
      93 TSM:INIT:TSP OK
      136 TSF:SID:OK,ID=1
      156 TSM:FPAR
      2278 TSM:FPAR:OK
      2295 TSM:ID
      2308 TSM:ID:OK
      2324 TSM:UPL
      4411 TSM:UPL
      4844 TSM:UPL:OK
      10854 MCO:REG:REQ
      11466 MCO:BGN:STP
      11544 MCO:SLP:TPD
      T: 22.00
      H: 45.00
      12500 MCO:SLP:TPD
      12622 MCO:SLP:TPD
      12745 MCO:SLP:TPD
      AnticimexA
      AnticimexA
      Anticimex
      @karelsmits
      could you please provide the logs with verbose signing debug enabled.
      Also, have you validated with the security personalizer that you have the correct serial in the whitelists on both node and gateway?
      • K
        K
        karelsmits
        Below is the settings I used with the SecurityPersonalizer.ino, I do notice now (with the verbose signing enabled, that the HMAC key does not match, even though you could see from the serial output that I used the same to generate the serials for the gateway and node:
        =====================================gateway:
        Personalization sketch for MySensors usage.
        Using this user supplied soft HMAC key:
        #define MY_SOFT_HMAC_KEY 0x75,0x58,0x79,0x5B,0x8A,0x17,0xFC,0x7B,0x6E,0x53,0x8E,0x30,0xD5,0x14,0xDD,0x7C,0x86,0x3F,0x8E,0x33,0xA1,0x54,0xE5,0x09,0xD9,0x4C,0x49,0xDE,0xEF,0xE6,0xEA,0x23
        This value will be stored in EEPROM as soft serial:
        #define MY_SOFT_SERIAL 0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD9
        Using this user supplied AES key:
        #define MY_AES_KEY 0xC5,0x87,0x79,0x06,0xE9,0x3C,0x0B,0x91,0x3C,0xD6,0xB6,0x05,0x64,0xD5,0xE9,0x18
        EEPROM configuration:
        SOFT_HMAC_KEY | 7558795B8A17FC7B6E538E30D514DD7C863F8E33A154E509D94C49DEEFE6EA23
        SOFT_SERIAL   | A0B171FAC56296F1D9
        AES_KEY       | C5877906E93C0B913CD6B60564D5E918
        Personalization is now complete.
        Sensor node:
        #define MY_SOFT_SERIAL 0xB0,0x23,0xE6,0x8E,0x74,0x14,0x78,0x3B,0x3F
        SOFT_SERIAL   | B023E68E7414783B3F
        Where did I go wrong, or what else is wrong. Thanks!
        Debug is below:
        Gateway:
        IP: 192.168.0.249
        0;255;3;0;9;Skipping security for command 3 type 16
        0;255;3;0;9;SHA256: A32644FAF9873B1928DBA958C28ADD65EE6124BEF279A13C5100000000000000
        0;255;3;0;9;Skipping security for command 3 type 17
        0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:A32644FAF9873B1928DBA958C28ADD65EE6124BEF279A13C51
        0;255;3;0;9;Transmitted nonce
        0;255;3;0;9;Signature in message: 01CD1C
        0;255;3;0;9;Message to process: 0100B6030BFF54656D7065726174757265416E6448756D6964697479
        0;255;3;0;9;Current nonce: A32644FAF9873B1928DBA958C28ADD65EE6124BEF279A13C51AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 7706426564FE57CAAEA11A8ADAA14F183087ED555F3711464D771AB3ED3C9323
        0;255;3;0;9;SHA256: 27CD1C4A537AC7DACC8BF91594D4EDAF962393C2B1C99C95075170F64406BAAD
        0;255;3;0;9;SHA256: 299EFBD3E478F83AB907954202484FDDD517F42B82EDFBCF15AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:299EFBD3E478F83AB907954202484FDDD517F42B82EDFBCF15
        0;255;3;0;9;Signature in message: 01CB19527B5B728708B43AAEC818FD91968808B34DDF
        0;255;3;0;9;Message to process: 01001E030CFF312E31
        0;255;3;0;9;Current nonce: 299EFBD3E478F83AB907954202484FDDD517F42B82EDFBCF15AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 3FE658AEDD29C670BEBC1BD7C0648103DA1E9A7B434252637589AD85C101D684
        0;255;3;0;9;SHA256: BACB19527B5B728708B43AAEC818FD91968808B34DDF6D7EC38027CD740A8F90
        0;255;3;0;9;SHA256: 1D86F9BA8F4A57E7F735C9C90B92BB007DD1B21759FBA5A1D4AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:1D86F9BA8F4A57E7F735C9C90B92BB007DD1B21759FBA5A1D4
        0;255;3;0;9;Signature in message: 016ADFB67F2E7AA29A62758B8DED6BA4445DCD50E5D43A6BB1
        0;255;3;0;9;Message to process: 010006000700
        0;255;3;0;9;Current nonce: 1D86F9BA8F4A57E7F735C9C90B92BB007DD1B21759FBA5A1D4AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 1D3F2387700161E5E7F91D8884A35050DDEA6031BBD394E9BB6380768B45B4E2
        0;255;3;0;9;SHA256: D86ADFB67F2E7AA29A62758B8DED6BA4445DCD50E5D43A6BB132A4EEB6DDDFFC
        0;255;3;0;9;SHA256: 2FA7278301DF11A478579ED0052E1E3F5374F4797D16E909A1AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:2FA7278301DF11A478579ED0052E1E3F5374F4797D16E909A1
        0;255;3;0;9;Signature in message: 0137133BA006F1055A77CC818F6DEA8794BE062951DDA8E4B1
        0;255;3;0;9;Message to process: 010006000601
        0;255;3;0;9;Current nonce: 2FA7278301DF11A478579ED0052E1E3F5374F4797D16E909A1AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 4A37BA5E250329F7A25933F5FEB0942B23C0A8F541EF32420EFDD60C6348722D
        0;255;3;0;9;SHA256: C437133BA006F1055A77CC818F6DEA8794BE062951DDA8E4B137CFE94EDDE9CD
        0;255;3;0;9;Skipping security for command 3 type 26
        0;255;3;0;9;Nonce requested from 1. Waiting...
        0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=17,pt=6,l=25,sg=0:C944AFD1C5122A0BFE35688614CE0AEC5014EF342809631212
        0;255;3;0;9;Nonce received from 1.
        0;255;3;0;9;Proceeding with signing...
        0;255;3;0;9;Message to process: 00010E231BFF01
        0;255;3;0;9;Current nonce: C944AFD1C5122A0BFE35688614CE0AEC5014EF342809631212AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 00AAE164745F6ED4DF7763E03AC018F1770139E16D50432E4933BE2A8A477898
        0;255;3;0;9;SHA256: 6DD0A65CCEB888592ABC7B700BA3D37430963FD260F1A84C7D28E17C19E550AF
        0;255;3;0;9;Signature in message: 01D0A65CCEB888592ABC7B700BA3D37430963FD260F1A84C
        0;255;3;0;9;Message signed
        0;255;3;0;9;Message to send has been signed
        0;255;3;0;9;SHA256: 861F99C1366BA4A1C01A03015C6A3F0C03C692E4FDAE490429AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:861F99C1366BA4A1C01A03015C6A3F0C03C692E4FDAE490429
        0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=1:21.0
        0;255;3;0;9;Signature in message: 011538815F551510B343CAF23DD479E8DB58C001
        0;255;3;0;9;Message to process: 01002EE100010000A84101
        0;255;3;0;9;Current nonce: 861F99C1366BA4A1C01A03015C6A3F0C03C692E4FDAE490429AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: A65541EEBA5E51C9D168F50B1AED7958B48645AD3D9CD0BD8A21D9B3544FDBE7
        0;255;3;0;9;SHA256: 64FBD77F2F2EB9AD031A619E29808059B5DAF9A2A214E4BB0AC2661C80801FF5
        0;255;3;0;9;Signature bad: 01FBD77F2F2EB9AD031A619E29808059B5DAF9A2
        0;255;3;0;9;Signature verification failed!
        0;255;3;0;9;!TSF:MSG:SIGN VERIFY FAIL
        0;255;3;0;9;SHA256: 85DE10FA1E868ACEE3930FE5B3170D441B2F1CC89A14BB1979AAAAAAAAAAAAAA
        0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:85DE10FA1E868ACEE3930FE5B3170D441B2F1CC89A14BB1979
        0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=1:46.0
        0;255;3;0;9;Signature in message: 0150C530844128121E1E6EE1F31F27C2162C8231
        0;255;3;0;9;Message to process: 01002EE101000000384201
        0;255;3;0;9;Current nonce: 85DE10FA1E868ACEE3930FE5B3170D441B2F1CC89A14BB1979AAAAAAAAAAAAAA
        0;255;3;0;9;HMAC: 014E462C1402CB244B8CEB46BEF6D3490002DBF95809DDA87217F4F1D3A7BF8F
        0;255;3;0;9;SHA256: F1B8DE6DC1D2B17E2E27D930EC9FF3AC430AEC728118B85E44434FA8A62520A7
        0;255;3;0;9;Signature bad: 01B8DE6DC1D2B17E2E27D930EC9FF3AC430AEC72
        Sensor node:
        41 MCO:BGN:BFR
        58 TSM:INIT
        70 TSF:WUR:MS=0
        93 TSM:INIT:TSP OK
        136 TSF:SID:OK,ID=1
        156 TSM:FPAR
        171 Will not sign message for destination 255 as it does not require it
        280 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2353 !TSM:FPAR:NO REPLY
        2377 TSM:FPAR
        2392 Will not sign message for destination 255 as it does not require it
        2503 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4404 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        4460 Skipping security for command 3 type 8
        4506 TSF:MSG:FPAR OK,ID=0,D=1
        4577 TSM:FPAR:OK
        4594 TSM:ID
        4606 TSM:ID:OK
        4623 TSM:UPL
        4636 Skipping security for command 3 type 24
        4685 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        4897 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        4956 Skipping security for command 3 type 25
        5002 TSF:MSG:PONG RECV,HP=1
        5031 TSM:UPL:OK
        5048 TSM:READY:ID=1,PAR=0,DIS=1
        5082 Signing required
        5105 Whitelisting required
        5133 Skipping security for command 3 type 15
        5184 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0103
        5258 Waiting for GW to send signing preferences...
        5602 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0103
        5662 Skipping security for command 3 type 15
        5709 Mark node 0 as one that require signed messages
        5765 Mark node 0 as one that require whitelisting
        5817 Skipping security for command 3 type 16
        5866 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
        5936 Nonce requested from 0. Waiting...
        6144 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=0:61472C0608B0A9EB29E9B3C70F9D7F6FD09BCB87F733B08F7D
        6253 Skipping security for command 3 type 17
        6300 Nonce received from 0.
        6330 Proceeding with signing...
        Message to process: 01002E0011FF322E312E31
        Current nonce: 61472C0608B0A9EB29E9B3C70F9D7F6FD09BCB87F733B08F7DAAAAAAAAAAAAAA
        HMAC: 01E9469D9B0A8E83EF7C29625D14DD63FB9CA5D7D69FE1154337A30A021B3208
        SHA256: 0822C73BAF43DD88FDC68C48AE623E98209F3A7DF9FCA19D3B0F85BF1F741B3F
        Signature in message: 0122C73BAF43DD88FDC68C48AE623E98209F3A7D
        6657 Message signed
        6745 Message to send has been signed
        6786 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.1.1
        6861 Skipping security for command 3 type 16
        6910 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        6980 Nonce requested from 0. Waiting...
        7556 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:AC0F413FA6A514F6BFA3B83C115154F54790801FF8AE22841D
        7665 Skipping security for command 3 type 17
        7712 Nonce received from 0.
        7741 Proceeding with signing...
        Message to process: 01000E2306FF00
        Current nonce: AC0F413FA6A514F6BFA3B83C115154F54790801FF8AE22841DAAAAAAAAAAAAAA
        HMAC: 40265CF5C94E46D211045580B861C7A323A5787D86CDD9EEA9E372317DAE8813
        SHA256: D8D4F9E9760D3D9A946F480C2BCCF883B222D792268C616F93DC963A343A5E30
        Signature in message: 01D4F9E9760D3D9A946F480C2BCCF883B222D792268C616F
        8068 Message signed
        8156 Message to send has been signed
        8198 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
        10267 Skipping security for command 3 type 16
        10317 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        10388 Nonce requested from 0. Waiting...
        15431 Message to send could not be signed!
        15475 !TSF:MSG:SIGN FAIL
        15502 Skipping security for command 3 type 16
        15553 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=OK:
        15624 Nonce requested from 0. Waiting...
        20667 Message to send could not be signed!
        20711 !TSF:MSG:SIGN FAIL
        20738 Skipping security for command 3 type 16
        20789 TSF:MSG:SEND,1-1-0-0,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=OK:
        20857 Nonce requested from 0. Waiting...
        25900 Message to send could not be signed!
        25944 !TSF:MSG:SIGN FAIL
        25970 Skipping security for command 3 type 16
        26021 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=OK:
        26092 Nonce requested from 0. Waiting...
        26299 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:A32644FAF9873B1928DBA958C28ADD65EE6124BEF279A13C51
        26409 Skipping security for command 3 type 17
        26458 Nonce received from 0.
        26487 Proceeding with signing...
        26815 Message signed
        26905 Message to send has been signed
        26947 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=1,ft=0,st=OK:TemperatureAndHumidity
        27042 Skipping security for command 3 type 16
        27092 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        27164 Nonce requested from 0. Waiting...
        27736 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:299EFBD3E478F83AB907954202484FDDD517F42B82EDFBCF15
        27846 Skipping security for command 3 type 17
        27894 Nonce received from 0.
        27925 Proceeding with signing...
        28252 Message signed
        28342 Message to send has been signed
        28384 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
        28457 Skipping security for command 3 type 16
        28509 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        28577 Nonce requested from 0. Waiting...
        29150 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:1D86F9BA8F4A57E7F735C9C90B92BB007DD1B21759FBA5A1D4
        29260 Skipping security for command 3 type 17
        29308 Nonce received from 0.
        29338 Proceeding with signing...
        29666 Message signed
        29755 Message to send has been signed
        29798 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=1,ft=0,st=OK:
        29865 Skipping security for command 3 type 16
        29916 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        29985 Nonce requested from 0. Waiting...
        30557 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:2FA7278301DF11A478579ED0052E1E3F5374F4797D16E909A1
        30667 Skipping security for command 3 type 17
        30715 Nonce received from 0.
        30746 Proceeding with signing...
        31074 Message signed
        31163 Message to send has been signed
        31205 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
        31273 MCO:REG:REQ
        31292 Skipping security for command 3 type 26
        31343 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
        31862 TSF:MSG:READ,0-0-1,s=255,c=3,t=16,pt=0,l=0,sg=0:
        31921 Skipping security for command 3 type 16
        SHA256: C944AFD1C5122A0BFE35688614CE0AEC5014EF34280963121200000000000000
        31992 Skipping security for command 3 type 17
        32110 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:C944AFD1C5122A0BFE35688614CE0AEC5014EF342809631212
        32234 Transmitted nonce
        32858 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=1:1
        HMAC: B0A2CE42D6C8D5C2E536F0623D42DD7906416B6F1C9C29D2F3F29FDF71F8674D
        SHA256: D667EA1AC54C5DCC60EC65460E7BF6637C6D767457894D45359457871B5FC647
        Signature bad: 0167EA1AC54C5DCC60EC65460E7BF6637C6D767457894D45
        33276 Signature verification failed!
        33383 !TSF:MSG:SIGN VERIFY FAIL
        33417 MCO:BGN:STP
        33436 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
        33495 MCO:SLP:TPD
        33514 MCO:SLP:WUP=-1
        33536 MCO:BGN:INIT OK,TSP=1
        33587 Skipping security for command 3 type 16
        33638 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        33707 Nonce requested from 0. Waiting...
        33913 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:861F99C1366BA4A1C01A03015C6A3F0C03C692E4FDAE490429
        34024 Skipping security for command 3 type 17
        34072 Nonce received from 0.
        34103 Proceeding with signing...
        HMAC: 33F5DB30601220F5DBE0C1671EF230D741298E59C76088211A55F9FCEBA3D51F
        SHA256: F71538815F551510B343CAF23DD479E8DB58C001841F4DFB95B0C55AE5951DAB
        34430 Message signed
        34520 Message to send has been signed
        34562 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:21.0
        T: 21.00
        34656 Skipping security for command 3 type 16
        34707 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
        34776 Nonce requested from 0. Waiting...
        35482 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:85DE10FA1E868ACEE3930FE5B3170D441B2F1CC89A14BB1979
        35593 Skipping security for command 3 type 17
        35641 Nonce received from 0.
        35671 Proceeding with signing...
        HMAC: 1633381545CBE6D28AF5CFE4A6A327B33A67B0DFAF1EA34D0537C52C4139217D
        SHA256: 3C50C530844128121E1E6EE1F31F27C2162C8231058F664B0D62653602F02CF8
        35998 Message signed
        36088 Message to send has been signed
        36130 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=1,ft=0,st=OK:46.0
        H: 46.00
        36203 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        36272 MCO:SLP:TPD
        36291 MCO:SLP:WUP=-1
        36335 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        36395 MCO:SLP:TPD
        36414 MCO:SLP:WUP=-1
        36458 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        36517 MCO:SLP:TPD
        36536 MCO:SLP:WUP=-1
        36580 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        36639 MCO:SLP:TPD
        36659 MCO:SLP:WUP=-1
        36703 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        36762 MCO:SLP:TPD
        36782 MCO:SLP:WUP=-1
        36825 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        36885 MCO:SLP:TPD
        Thank you
        • K karelsmits
          Sensor node:
          Debug is below:
          Gateway:
          IP: 192.168.0.249
          Sensor node:
          41 MCO:BGN:BFR
          58 TSM:INIT
          70 TSF:WUR:MS=0
          93 TSM:INIT:TSP OK
          136 TSF:SID:OK,ID=1
          156 TSM:FPAR
          2377 TSM:FPAR
          4577 TSM:FPAR:OK
          4594 TSM:ID
          4606 TSM:ID:OK
          4623 TSM:UPL
          5031 TSM:UPL:OK
          6657 Message signed
          8068 Message signed
          31273 MCO:REG:REQ
          33417 MCO:BGN:STP
          33495 MCO:SLP:TPD
          T: 21.00
          H: 46.00
          36272 MCO:SLP:TPD
          36395 MCO:SLP:TPD
          36517 MCO:SLP:TPD
          36639 MCO:SLP:TPD
          36762 MCO:SLP:TPD
          36885 MCO:SLP:TPD
          Thank you
          AnticimexA
          AnticimexA
          Anticimex
          @karelsmits
          Your configuration looks good, but I cannot see that the debug output fits what is supposed to be printed for version 2.1.1.
          Are you sure your library is in a clean state?
          When I look on github for version 2.1.1, I would expect more whitelisting related debug prints.
          I also cannot find the "0103" message in the gateway log which should inform it that the node require whitelisting.
          The node has received it from the GW I can see though.
          So it could be that the node knows about the GWs preference, but the GW does not know that the node also require whitelisting.
          The node got configured here:
          But I don't see anything like that in the GW log. So my guess is that the GW does not salt the signatures properly according to the nodes expectations. So the node fails to verify the messages, while the GW knows that the node will salt the signatures, so it will be able to verify messages from the node.
          Could you try to reset the GW and then the node, and see if the node manages to inform the GW properly?
          • K
            K
            karelsmits
            I redid the code, by downloading the latest edition of mysensors (2.1.1 - Latest Release). Here is the error log from the gateway.
            Gateway:
            IP: 192.168.0.249
            0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSF:MSG:BC
            0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
            0;255;3;0;9;TSF:PNG:SEND,TO=0
            0;255;3;0;9;TSF:CKU:OK
            0;255;3;0;9;TSF:MSG:GWL OK
            0;255;3;0;9;Skipping security for command 3 type 8
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            0;255;3;0;9;Skipping security for command 3 type 24
            0;255;3;0;9;Skipping security for command 3 type 25
            0;255;3;0;9;Skipping security for command 3 type 15
            0;255;3;0;9;Mark node 1 as one that require signed messages
            0;255;3;0;9;Mark node 1 as one that require whitelisting
            0;255;3;0;9;Informing node 1 that we require signatures
            0;255;3;0;9;Informing node 1 that we require whitelisting
            0;255;3;0;9;SHA256: 635ADD8607ED079B85C15D6CEF0303ECFD6389962B963EAA0500000000000000
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:635ADD8607ED079B85C15D6CEF0303ECFD6389962B963EAA05
            0;255;3;0;9;Signature in message: 01779AE68396C7000C2AA6302F0DE89070F7D8CB
            0;255;3;0;9;Message to process: 01002E0011FF322E312E31
            0;255;3;0;9;Current nonce: 635ADD8607ED079B85C15D6CEF0303ECFD6389962B963EAA05AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 2A6B189942AC438855B0FFF007580356C85AAED0C6C2331AA2EBD96AD8D694E5
            0;255;3;0;9;SHA256: D159F7F5DD1FE7912ADCC2C67AF7B0B01363C49A04F4CCF3E91E9D8DB5938E01
            0;255;3;0;9;Signature bad: 0159F7F5DD1FE7912ADCC2C67AF7B0B01363C49A
            0;255;3;0;9;SHA256: 701A70E84569482F1E26A0C65DCC936B8248FD88168E723095AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:701A70E84569482F1E26A0C65DCC936B8248FD88168E723095
            0;255;3;0;9;Signature in message: 01C9468DBD954A8DC8C7D38B144FD1303CAFD01EB84F3CB6
            0;255;3;0;9;Message to process: 01000E2306FF00
            0;255;3;0;9;Current nonce: 701A70E84569482F1E26A0C65DCC936B8248FD88168E723095AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 337DDA1FA458CE0BFBCE84CB2531D23A3D7E34AAD2AE87EE090B1DF04DA5B7FA
            0;255;3;0;9;SHA256: 5F0BE66667527FF2C4639DE12B6BC39F8D99C00AF30C785D676246CF86FF6046
            0;255;3;0;9;Signature bad: 010BE66667527FF2C4639DE12B6BC39F8D99C00AF30C785D
            0;255;3;0;9;SHA256: CD1F75695EDE349716A2C0939011673583E68955F1226D2845AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:CD1F75695EDE349716A2C0939011673583E68955F1226D2845
            0;255;3;0;9;Signature in message: 01A2AB3419826F0361B5E6
            0;255;3;0;9;Message to process: 010076030BFF52656C6179202620427574746F6E
            0;255;3;0;9;Current nonce: CD1F75695EDE349716A2C0939011673583E68955F1226D2845AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 8F08FA3DF87C992BD66F382D912B862536EB79750BE8B7DF2699330FA6204251
            0;255;3;0;9;SHA256: 5A123CB37F6CA6D015B6E61D48E1F2F64E3BA890FE614B4C92AE3972B28FE061
            0;255;3;0;9;Signature bad: 01123CB37F6CA6D015B6E6
            0;255;3;0;9;SHA256: 4AA750027BA8D55571FEAB998D9EAA50C11D040628125C3AD3AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:4AA750027BA8D55571FEAB998D9EAA50C11D040628125C3AD3
            0;255;3;0;9;Signature in message: 0186E4183F7C79D8E810E7B3F1ACBDA258FFEDBF7BFB
            0;255;3;0;9;Message to process: 01001E030CFF312E30
            0;255;3;0;9;Current nonce: 4AA750027BA8D55571FEAB998D9EAA50C11D040628125C3AD3AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 16142EF6048B9BD4FFB7541F38E250DB3569FDC548E476933255B579668769BE
            0;255;3;0;9;SHA256: DB85915DF555538FA84F4F6BF810FC646C2E94B1F0333862ED67F0DC8559A921
            0;255;3;0;9;Signature bad: 0185915DF555538FA84F4F6BF810FC646C2E94B1F033
            0;255;3;0;9;SHA256: 591F249BF6AA89AFADCF3213B362C2011D78F009E371E2893CAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:591F249BF6AA89AFADCF3213B362C2011D78F009E371E2893C
            0;255;3;0;9;Signature in message: 012F3F8F18555E4872180C9A3F6BB69FCBCB520B13A9A5E0BF
            0;255;3;0;9;Message to process: 010006000305
            0;255;3;0;9;Current nonce: 591F249BF6AA89AFADCF3213B362C2011D78F009E371E2893CAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: AE537B78F59F3BBF57CE197D7233315CD924DC04470F86A4CC92D57184E546D7
            0;255;3;0;9;SHA256: 893FCC47C0EBD7EB457456F5498DB1DA0FE7C70B706AABE6D7E94CDA3477B291
            0;255;3;0;9;Signature bad: 013FCC47C0EBD7EB457456F5498DB1DA0FE7C70B706AABE6D7
            0;255;3;0;9;SHA256: E8D883F495AF21515C912E25659740392A47E35A433FDD99E7AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:E8D883F495AF21515C912E25659740392A47E35A433FDD99E7
            0;255;3;0;9;Signature in message: 013680
            0;255;3;0;9;Current nonce: E8D883F495AF21515C912E25659740392A47E35A433FDD99E7AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 58D0F9A87240B44F6A67C4282BCD28E1D7AD181EE0FB916A56AE931117FBAC43
            0;255;3;0;9;SHA256: E6E566363EF09FABD3DA06B632F95B620AE6DFA620BF14254D8A534C05BFE05D
            0;255;3;0;9;Signature bad: 01E566
            0;255;3;0;9;SHA256: 73E9D69B277B1E0BEB5ECAD5CD86DB4B249995508431170B0EAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:73E9D69B277B1E0BEB5ECAD5CD86DB4B249995508431170B0E
            0;255;3;0;9;Signature in message: 0194F9156C1D1CAB891F415C60278725B2A030DC3600
            0;255;3;0;9;Current nonce: 73E9D69B277B1E0BEB5ECAD5CD86DB4B249995508431170B0EAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: F2A05E6320CB0143CDD25C862489C3E3B711E654FCDBE93DAC77E5D2226441B3
            0;255;3;0;9;SHA256: 6EE086304E95BD00371FAC38825EB122C680B7A4CA6D1CA29C6F7E2D1D0D82A1
            0;255;3;0;9;Signature bad: 01E086304E95BD00371FAC38825EB122C680B7A4CA6D
            0;255;3;0;9;SHA256: 233BAC8C23F612E195F353CDDA4DC2372C87BC608E6D676878AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:233BAC8C23F612E195F353CDDA4DC2372C87BC608E6D676878
            0;255;3;0;9;Signature in message: 01046A6A668F9A4DA69DE94708162812A50ED241CB9395113B
            0;255;3;0;9;Current nonce: 233BAC8C23F612E195F353CDDA4DC2372C87BC608E6D676878AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: A131C90326E31F93B59455FD2152AD491C530667AF46B36BDA9300EFA5EEFD7B
            0;255;3;0;9;SHA256: 3BB11EB543513CAA63FDE1D695D4B575B613FA091680AA6769E88A12ABDEC903
            0;255;3;0;9;Signature bad: 01B11EB543513CAA63FDE1D695D4B575B613FA091680AA6769
            0;255;3;0;9;SHA256: 64191BC91B3DE6C290B9E7E1F67800BDB8E974E2EC2C036316AAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:64191BC91B3DE6C290B9E7E1F67800BDB8E974E2EC2C036316
            0;255;3;0;9;Signature in message: 01D710CFA4D8A468B30FA3BADDD985A6152FD3AE3A32385FCA
            0;255;3;0;9;Current nonce: 64191BC91B3DE6C290B9E7E1F67800BDB8E974E2EC2C036316AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 42A9625E80384D4A2F6F2DFF26C67CF8EC53C15AD1F34FF2C5BFE920E907E7A2
            0;255;3;0;9;SHA256: 6B5B67E9826562660840EB12BD25592DD94020FDB19DAD0F7C131833FC2EB761
            0;255;3;0;9;Signature bad: 015B67E9826562660840EB12BD25592DD94020FDB19DAD0F7C
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=17,pt=6,l=25,sg=0:58D7A7CB82C6F505B3DFA9FDBF9B5F4FA37EC9DD24E8678C97
            0;255;3;0;9;Current nonce: 58D7A7CB82C6F505B3DFA9FDBF9B5F4FA37EC9DD24E8678C97AAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: B37650AA6C8D0E1B5FAE0707F73A27DA692350D7B2B28E8BD28BF20BF5F29BEF
            0;255;3;0;9;SHA256: 49DFDE1EDF6520D9E631ED9273E6078024CB044F6B0DF64AB50F528E8D94A1CA
            0;255;3;0;9;Signature in message: 01DFDE1EDF6520D9E631ED9273E6078024CB044F6B0DF64A
            0;255;3;0;9;SHA256: 9D2BDD2FACC4709213B5B111A55C8CBEED0E413492D0DD1CDBAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:9D2BDD2FACC4709213B5B111A55C8CBEED0E413492D0DD1CDB
            0;255;3;0;9;Signature in message: 01E0544023E531C09CFE802850439D34997E85E0
            0;255;3;0;9;Current nonce: 9D2BDD2FACC4709213B5B111A55C8CBEED0E413492D0DD1CDBAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 776B37A0659B82546BA948FDD1677DD044FC3280D03AAE99F3B014CEB3A77A3F
            0;255;3;0;9;SHA256: 8303F1968F614D18BD23169B7334857E04A586C0520489061280682A86CF73EC
            0;255;3;0;9;Signature bad: 0103F1968F614D18BD23169B7334857E04A586C0
            0;255;3;0;9;SHA256: A58B01866F7DBF6E248DF75227EB49FBA430BFC144DFB85D4FAAAAAAAAAAAAAA
            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:A58B01866F7DBF6E248DF75227EB49FBA430BFC144DFB85D4F
            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=1:49.0
            0;255;3;0;9;Signature in message: 0148A1408041EBB978E098504E6342E2D09DA2F9
            0;255;3;0;9;Message to process: 01002EE101000000444201
            0;255;3;0;9;Current nonce: A58B01866F7DBF6E248DF75227EB49FBA430BFC144DFB85D4FAAAAAAAAAAAAAA
            0;255;3;0;9;HMAC: 2E879E98A64074D1C89CCC1391553D6216D59A01B0C8ADBD05D550ED3494C295
            0;255;3;0;9;SHA256: 166860778F1647E299AAF08F1521297128246EEA22A9148D2B8E44F940B7CC3D
            0;255;3;0;9;Signature bad: 016860778F1647E299AAF08F1521297128246EEA
            Sensor node:
            3 MCO:BGN:BFR
            5 TSM:INIT
            6 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            14 TSM:INIT:STATID=1
            16 TSF:SID:OK,ID=1
            18 TSM:FPAR
            19 Will not sign message for destination 255 as it does not require it
            60 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            531 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            536 Skipping security for command 3 type 8
            539 TSF:MSG:FPAR OK,ID=0,D=1
            2067 TSM:FPAR:OK
            2068 TSM:ID
            2069 TSM:ID:OK
            2071 TSM:UPL
            2072 Skipping security for command 3 type 24
            2078 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2097 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2102 Skipping security for command 3 type 25
            2106 TSF:MSG:PONG RECV,HP=1
            2108 TSM:UPL:OK
            2110 TSM:READY:ID=1,PAR=0,DIS=1
            2113 Signing required
            2115 Whitelisting required
            2117 Skipping security for command 3 type 15
            2123 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0103
            2129 Waiting for GW to send signing preferences...
            2159 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0103
            2164 Skipping security for command 3 type 15
            2168 Mark node 0 as one that require signed messages
            2173 Mark node 0 as one that require whitelisting
            2178 Skipping security for command 3 type 16
            2184 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
            2190 Nonce requested from 0. Waiting...
            2222 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=0:635ADD8607ED079B85C15D6CEF0303ECFD6389962B963EAA05
            2231 Skipping security for command 3 type 17
            2235 Nonce received from 0.
            2238 Proceeding with signing...
            HMAC: D2C5F779BE860E0BFB66A0F619BACB0B88B9104197DC43FAE0BB91D6F771130E
            SHA256: 67779AE68396C7000C2AA6302F0DE89070F7D8CB0DE16284892E168E2B02DDA0
            2344 Message signed
            2352 Message to send has been signed
            2357 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.1.1
            2364 Skipping security for command 3 type 16
            2370 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            2376 Nonce requested from 0. Waiting...
            2529 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:701A70E84569482F1E26A0C65DCC936B8248FD88168E723095
            2538 Skipping security for command 3 type 17
            2542 Nonce received from 0.
            2545 Proceeding with signing...
            HMAC: F0E805F26B0CD17B8282B3DBD98EA50BC4BD7AD5C3B946FF540FDE606ABFA34A
            SHA256: 74C9468DBD954A8DC8C7D38B144FD1303CAFD01EB84F3CB6306C4EA3F90D6394
            2652 Message signed
            2659 Message to send has been signed
            2665 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
            4671 Skipping security for command 3 type 16
            4677 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            4683 Nonce requested from 0. Waiting...
            4715 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:CD1F75695EDE349716A2C0939011673583E68955F1226D2845
            4725 Skipping security for command 3 type 17
            4729 Nonce received from 0.
            4731 Proceeding with signing...
            HMAC: 0C37B5A3CE49E63747A7298EA8733A27FD8AA4F52FCB188CFC92D9A77881B77F
            SHA256: 73A2AB3419826F0361B5E66936FC2F94E0C436E9CB6D61F1C7FA57C8A79A276A
            4838 Message signed
            4845 Message to send has been signed
            4851 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=14,sg=1,ft=0,st=OK:Relay & Button
            4858 Skipping security for command 3 type 16
            4866 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            4872 Nonce requested from 0. Waiting...
            5022 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:4AA750027BA8D55571FEAB998D9EAA50C11D040628125C3AD3
            5031 Skipping security for command 3 type 17
            5036 Nonce received from 0.
            5039 Proceeding with signing...
            HMAC: 143B7FA1E433427A97AF9085B47418088349385FD64B8A461E99A2FDB2E642A2
            SHA256: 3586E4183F7C79D8E810E7B3F1ACBDA258FFEDBF7BFB3CB9B1EAD8A645AF87F2
            5145 Message signed
            5152 Message to send has been signed
            5158 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
            5165 Skipping security for command 3 type 16
            5171 TSF:MSG:SEND,1-1-0-0,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            5177 Nonce requested from 0. Waiting...
            5329 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:591F249BF6AA89AFADCF3213B362C2011D78F009E371E2893C
            5340 Skipping security for command 3 type 17
            5344 Nonce received from 0.
            5346 Proceeding with signing...
            HMAC: E73D1E22383313729323B1295ADC66501F0840E4E3AD43BA755D5B556EF6608F
            SHA256: 7C2F3F8F18555E4872180C9A3F6BB69FCBCB520B13A9A5E0BF5B8FE4353203C4
            5452 Message signed
            5459 Message to send has been signed
            5466 TSF:MSG:SEND,1-1-0-0,s=5,c=0,t=3,pt=0,l=0,sg=1,ft=0,st=OK:
            5472 Skipping security for command 3 type 16
            5478 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            5484 Nonce requested from 0. Waiting...
            5638 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:E8D883F495AF21515C912E25659740392A47E35A433FDD99E7
            5647 Skipping security for command 3 type 17
            5651 Nonce received from 0.
            5654 Proceeding with signing...
            HMAC: 784C2D238D4B5C2233FC45251847A638A292EC4E308BC93A95055DEE5BC5FC14
            SHA256: 4136807B84DBF7CF7ABBCCD1CAC78E289FB39E060B699D7A6B10C9C5831994FF
            5761 Message signed
            5768 Message to send has been signed
            5774 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=1,ft=0,st=OK:TemperatureAndHumidity
            5782 Skipping security for command 3 type 16
            5788 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            5794 Nonce requested from 0. Waiting...
            5947 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:73E9D69B277B1E0BEB5ECAD5CD86DB4B249995508431170B0E
            5956 Skipping security for command 3 type 17
            5960 Nonce received from 0.
            5962 Proceeding with signing...
            HMAC: 378FEA52C9235CADF20041F6ED4FA21FB5FFFAF7B2E104ECD111049D3643B7CD
            SHA256: 7494F9156C1D1CAB891F415C60278725B2A030DC3600A2FEDC44E1CB88EE05B6
            6069 Message signed
            6077 Message to send has been signed
            6082 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
            6089 Skipping security for command 3 type 16
            6095 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            6102 Nonce requested from 0. Waiting...
            6254 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:233BAC8C23F612E195F353CDDA4DC2372C87BC608E6D676878
            6263 Skipping security for command 3 type 17
            6267 Nonce received from 0.
            6270 Proceeding with signing...
            HMAC: 65B760FEACE7F3773A162428F31841D7133E7E74E57FB0E4C58F5370EAC2C899
            SHA256: 16046A6A668F9A4DA69DE94708162812A50ED241CB9395113BCF2AAFAA8F9F6A
            6377 Message signed
            6384 Message to send has been signed
            6390 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=1,ft=0,st=OK:
            6395 Skipping security for command 3 type 16
            6403 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            6409 Nonce requested from 0. Waiting...
            6561 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:64191BC91B3DE6C290B9E7E1F67800BDB8E974E2EC2C036316
            6572 Skipping security for command 3 type 17
            6576 Nonce received from 0.
            6578 Proceeding with signing...
            HMAC: 9D76E2E5E11AF40E3663096488DBC4C8DF685497CA8C5071A472AC5E3F1F08E0
            SHA256: F4D710CFA4D8A468B30FA3BADDD985A6152FD3AE3A32385FCA5BC0698FF98FB3
            6684 Message signed
            6691 Message to send has been signed
            6697 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
            6704 MCO:REG:REQ
            6705 Skipping security for command 3 type 26
            6712 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
            6846 TSF:MSG:READ,0-0-1,s=255,c=3,t=16,pt=0,l=0,sg=0:
            6851 Skipping security for command 3 type 16
            SHA256: 58D7A7CB82C6F505B3DFA9FDBF9B5F4FA37EC9DD24E8678C9700000000000000
            6871 Skipping security for command 3 type 17
            6883 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:58D7A7CB82C6F505B3DFA9FDBF9B5F4FA37EC9DD24E8678C97
            6893 Transmitted nonce
            7026 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=1:1
            HMAC: C571E596B10436BEE9D0B919A8291506AAA575DF35440AD067A955F3DD59DC59
            SHA256: 8093DAB94D88CD2E779CB207C957276B474CD6D58877337A1F0E06412D098E05
            Signature bad: 0193DAB94D88CD2E779CB207C957276B474CD6D58877337A
            7141 Signature verification failed!
            7149 !TSF:MSG:SIGN VERIFY FAIL
            7152 MCO:BGN:STP
            7154 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
            7159 MCO:SLP:TPD
            7161 MCO:SLP:WUP=-1
            7163 MCO:BGN:INIT OK,TSP=1
            7187 Skipping security for command 3 type 16
            7194 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            7200 Nonce requested from 0. Waiting...
            7232 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:9D2BDD2FACC4709213B5B111A55C8CBEED0E413492D0DD1CDB
            7241 Skipping security for command 3 type 17
            7245 Nonce received from 0.
            7248 Proceeding with signing...
            HMAC: 13318A49861D23D2F161DC7CD30045236A29E6ABEACA8CBAB536D8C489354A94
            SHA256: 64E0544023E531C09CFE802850439D34997E85E0549E73CD10AABAC2F5DBDA1E
            7355 Message signed
            7362 Message to send has been signed
            7368 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:21.0
            T: 21.00
            7374 Skipping security for command 3 type 16
            7382 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
            7388 Nonce requested from 0. Waiting...
            7539 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:A58B01866F7DBF6E248DF75227EB49FBA430BFC144DFB85D4F
            7548 Skipping security for command 3 type 17
            7553 Nonce received from 0.
            7556 Proceeding with signing...
            HMAC: 999CC7109C1EABF2BE1E0EBE8E70AC2814D4A797C5D4B2EFEAECAEB0F312394A
            SHA256: FB48A1408041EBB978E098504E6342E2D09DA2F9C08E87D8C930344A6261C640
            7662 Message signed
            7669 Message to send has been signed
            7675 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=1,ft=0,st=OK:49.0
            H: 49.00
            7682 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            7687 MCO:SLP:TPD
            Could it be that the serial doesn’t match? Even though I copy/pasted the output from SecurityPersonalizer.ino, meaning it maybe did’t save into the EEPROM?
            Thanks!
            • K karelsmits
              Gateway:
              IP: 192.168.0.249
              Sensor node:
              3 MCO:BGN:BFR
              5 TSM:INIT
              6 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              16 TSF:SID:OK,ID=1
              18 TSM:FPAR
              2067 TSM:FPAR:OK
              2068 TSM:ID
              2069 TSM:ID:OK
              2071 TSM:UPL
              2108 TSM:UPL:OK
              2344 Message signed
              2652 Message signed
              4838 Message signed
              5145 Message signed
              5452 Message signed
              5761 Message signed
              6069 Message signed
              6377 Message signed
              6684 Message signed
              6704 MCO:REG:REQ
              7152 MCO:BGN:STP
              7159 MCO:SLP:TPD
              7161 MCO:SLP:WUP=-1
              7355 Message signed
              T: 21.00
              7662 Message signed
              H: 49.00
              7687 MCO:SLP:TPD
              Thanks!
              AnticimexA
              AnticimexA
              Anticimex
              @karelsmits it is very odd. I would expect the log mention whitelisting information. Yet there is nothing in the messages concerning signing that indicate it tries to find a entry or that it does not find an entry. It simply looks like the backend has not realized whitelisting is activated. Still, it communicate the requirements properly.
              If you look at the backends (MySigningAtsha204Soft.cpp) there are some conditional behaviour there with is activated if a whitelist is defined.
              • K
                K
                karelsmits
                What would be my options?
                Do you by any chance have a sample gateway and a node (both with whitelisting) that I could compare my code with, to see where it has gone wrong.
                And also what about how I verify the EEPROM serial-info.
                Thank you in advance.
                • K karelsmits
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @karelsmits I don't have something from the master branch. But I have verified that the beta (development branch) works with whitelisting. The personalizer dumps the eeprom contents and from the logs you posted above I verified that the contents match the configuration.
                  Could you try to add some additional prints in the back end to verify it actually executes the whitelisting logic? If I look at github there should be prints that I can't find in your logs. So I suspect the whitelisting management is not fully working, but I am pretty sure it has been verified in the latest release.
                  You are sure you run a vanilla release without local modifications?
                  • K
                    K
                    karelsmits
                    Okay here is the gateway code:
                     * Version 1.0 - Henrik EKblad
                     * Contribution by Tomas Hozza <thozza@gmail.com>
                     * LED purposes:
                     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
                    #define MY_DEBUG_VERBOSE_SIGNING
                    #define MY_GATEWAY_W5100
                    //#define MY_W5100_SPI_EN 4
                    // radio on the same spi bus.
                    #define MY_SOFTSPI
                    #ifndef MY_RF24_CE_PIN
                    #define MY_RF24_CE_PIN 5
                    #ifndef MY_RF24_CS_PIN
                    #define MY_RF24_CS_PIN 6
                    // Enable to UDP
                    //#define MY_USE_UDP
                    #define MY_IP_ADDRESS 192,168,0,249   // If this is disabled, DHCP is used to retrieve address
                    #define MY_PORT 5487
                    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                    //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
                    // Enable inclusion mode
                    // Set blinking period
                    // Flash leds on rx/tx/err
                    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                    #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
                    #if defined(MY_USE_UDP)
                    #include <EthernetUdp.h>
                    #include <Ethernet.h>
                    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 1,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD8}}} // for sensor
                    Here is the Sensor-node code:
                     * Version 1.0: Henrik EKblad
                    // Enable debug prints
                    //#define MY_RS485
                    #include <DHT.h>
                    #define DHT_DATA_PIN 3
                    #define SENSOR_TEMP_OFFSET 0
                    #define CHILD_ID_HUM 0
                    #define CHILD_ID_TEMP 1
                    float lastTemp;
                    float lastHum;
                    uint8_t nNoUpdatesTemp;
                    uint8_t nNoUpdatesHum;
                    bool metric = true;
                    DHT dht;
                      sendSketchInfo("TemperatureAndHumidity", "1.1");
                      present(CHILD_ID_HUM, S_HUM);
                      dht.readSensor(true);
                      if (isnan(temperature)) {
                        lastTemp = temperature;
                        if (!metric) {
                        // Reset no updates counter
                        nNoUpdatesTemp = 0;
                        #ifdef MY_DEBUG
                        Serial.print("T: ");
                        Serial.println(temperature);
                      } else {
                        nNoUpdatesTemp++;
                      if (isnan(humidity)) {
                        lastHum = humidity;
                        nNoUpdatesHum = 0;
                        #ifdef MY_DEBUG
                        Serial.print("H: ");
                        Serial.println(humidity);
                      } else {
                        nNoUpdatesHum++;
                      sleep(UPDATE_INTERVAL);
                    And here is the signing code at MyConfig.h:
                    #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD9}},{.nodeId = 1,.serial = {0xA0,0xB1,0x71,0xFA,0xC5,0x62,0x96,0xF1,0xD8}}}
                    And this is pretty much Vanilla, as you can see.
                    • K karelsmits
                       * LED purposes:
                      #define MY_SOFTSPI
                      // Enable to UDP
                      //#define MY_RS485
                      #include <DHT.h>
                      float lastTemp;
                      float lastHum;
                      bool metric = true;
                      DHT dht;
                          if (!metric) {
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                        } else {
                          nNoUpdatesTemp++;
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                        } else {
                          nNoUpdatesHum++;
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @karelsmits I am not talking about your sketch, I am talking about the MySensors library.
                      • K
                        K
                        karelsmits
                        what files in the library do you mean?
                        • K karelsmits
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @karelsmits the one I mentioned above.
                          However, I do notice one important thing here; you have made changes to MyConfig.h. You should not enable the flags for signing and whitelisting in that file. You do that in your sketch. If you have defined them in two places, you don't know which setting is used. Revert the signing settings you tweaked in MyConfig.h and use the settings in your sketches (the GW and the node).
                          • K
                            K
                            karelsmits
                            Thank you so much for your help so far, especially the myconfig.h file that it should not be modified regarding signing.
                            Now I have the following error:
                            Gateway:
                            IP: 192.168.0.249
                            0;255;3;0;9;Will not sign message for destination 1 as it does not require it
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                            0;255;3;0;9;Mark node 1 as one that do not require whitelisting
                            0;255;3;0;9;Informing node 1 that we do not require whitelisting
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                            0;255;3;0;9;SHA256: FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC7900000000000000
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC79
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=0,t=18,pt=0,l=5,sg=1:2.1.1
                            0;255;3;0;9;Signature in message: 01EDFE67C83BA7ADD4B868950DA55ADF92E74C2D
                            0;255;3;0;9;Message to process: 01002E0012FF322E312E31
                            0;255;3;0;9;Current nonce: FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC79AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 41EDFE67C83BA7ADD4B868950DA55ADF92E74C2D89903167166C396470C02F3E
                            0;255;3;0;9;SHA256: D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8AAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8
                            0;255;3;0;9;Signature in message: 01815088794CC5704C5790821D82DFD0435B5A47B4FBC14C
                            0;255;3;0;9;Current nonce: D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 1D815088794CC5704C5790821D82DFD0435B5A47B4FBC14C745AA2B639D4D9DA
                            0;255;3;0;9;SHA256: E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3EAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3E
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=5,sg=1:Relay
                            0;255;3;0;9;Signature in message: 01E3BCEFCF2F06C922BD6D487BBA7E67C9B717BC
                            0;255;3;0;9;Message to process: 01002E030BFF52656C6179
                            0;255;3;0;9;Current nonce: E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3EAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 4BE3BCEFCF2F06C922BD6D487BBA7E67C9B717BCF2852083854E7555620473AD
                            0;255;3;0;9;SHA256: 2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209FAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209F
                            0;255;3;0;9;Signature in message: 01DDCD53799743889B645AC6524B32B4AEB4B71E368C
                            0;255;3;0;9;Current nonce: 2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209FAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: F3DDCD53799743889B645AC6524B32B4AEB4B71E368CCE2BE60CC00E0AD2D183
                            0;255;3;0;9;SHA256: F1048244D308662147413A8531A71EF5C5E241710A859D7562AAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F1048244D308662147413A8531A71EF5C5E241710A859D7562
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=0,t=3,pt=0,l=0,sg=1:
                            0;255;3;0;9;Signature in message: 01E5C5B659AF41CC4B5C9315F94E1A22E2DF10FAD361061CB3
                            0;255;3;0;9;Message to process: 010006000301
                            0;255;3;0;9;Current nonce: F1048244D308662147413A8531A71EF5C5E241710A859D7562AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 4EE5C5B659AF41CC4B5C9315F94E1A22E2DF10FAD361061CB3DB7925952BFDAE
                            0;255;3;0;9;SHA256: 24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BDAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BD
                            0;255;3;0;9;Signature in message: 013E8E
                            0;255;3;0;9;Current nonce: 24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BDAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 513E8E942127E5E2D512CE288F2B7E6418B8809F69B8B1EAE20D97A4407F9C86
                            0;255;3;0;9;SHA256: F95653815901C8FACA219583E9C6FEA53596238E460528DA6AAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F95653815901C8FACA219583E9C6FEA53596238E460528DA6A
                            0;255;3;0;9;Signature in message: 01FD4A335914B1FA7065E23D2B0C98FFB67E06B582AA
                            0;255;3;0;9;Current nonce: F95653815901C8FACA219583E9C6FEA53596238E460528DA6AAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 22FD4A335914B1FA7065E23D2B0C98FFB67E06B582AA0C8B3865B44CE9E1D49E
                            0;255;3;0;9;SHA256: D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71BAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71B
                            0;255;3;0;9;Signature in message: 01E7923AA716F2CE850EB4A27962F15BF36941D559BA1DCF45
                            0;255;3;0;9;Current nonce: D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71BAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: F4E7923AA716F2CE850EB4A27962F15BF36941D559BA1DCF45C1821C7AD8E479
                            0;255;3;0;9;SHA256: E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BBAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BB
                            0;255;3;0;9;Signature in message: 01D9D7F016D4900614542F96199D1C1848E66826E164117C3F
                            0;255;3;0;9;Current nonce: E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BBAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 17D9D7F016D4900614542F96199D1C1848E66826E164117C3F91395B119DB817
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=17,pt=6,l=25,sg=0:70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB4
                            0;255;3;0;9;Current nonce: 70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB4AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 417F60D164B7EF1EE9F5664945AEE360F44F196E52428D274230D8D0DB830028
                            0;255;3;0;9;Signature in message: 017F60D164B7EF1EE9F5664945AEE360F44F196E52428D27
                            0;255;3;0;9;SHA256: B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1CAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1C
                            0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=1:24.0
                            0;255;3;0;9;Signature in message: 01E74C2A504B304F48E28201FBB2B85E10BD50EB
                            0;255;3;0;9;Message to process: 01002EE100010000C04101
                            0;255;3;0;9;Current nonce: B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1CAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 69EB3E1CFCF0B6629300837110B152CA8F7A0E2D53A4C8BFEBE4903F1B090864
                            0;255;3;0;9;Signature bad: 01EB3E1CFCF0B6629300837110B152CA8F7A0E2D
                            0;255;3;0;9;SHA256: AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39DAAAAAAAAAAAAAA
                            0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39D
                            0;255;3;0;9;Signature in message: 0151796D338A1717D7B544C78054CBE9E39D901D
                            0;255;3;0;9;Current nonce: AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39DAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: A54694E7B219D7065CFD2D3C449350372739185EAC6EE5376C0E10561344CB12
                            0;255;3;0;9;Signature bad: 014694E7B219D7065CFD2D3C449350372739185E
                            Node:
                            0 MCO:BGN:INIT REPEATER,CP=RNNRAS-,VER=2.1.1
                            3 MCO:BGN:BFR
                            5 TSM:INIT
                            6 TSF:WUR:MS=0
                            13 TSM:INIT:TSP OK
                            15 TSF:SID:OK,ID=1
                            16 TSM:FPAR
                            17 Will not sign message for destination 255 as it does not require it
                            59 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            203 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            207 Skipping security for command 3 type 8
                            211 TSF:MSG:FPAR OK,ID=0,D=1
                            2066 TSM:FPAR:OK
                            2067 TSM:ID
                            2068 TSM:ID:OK
                            2070 TSM:UPL
                            2071 Will not sign message for destination 0 as it does not require it
                            2079 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                            2096 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            2101 Skipping security for command 3 type 25
                            2105 TSF:MSG:PONG RECV,HP=1
                            2107 TSM:UPL:OK
                            2109 TSM:READY:ID=1,PAR=0,DIS=1
                            2112 Signing required
                            2114 Will not sign message for destination 0 as it does not require it
                            2121 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                            2128 Waiting for GW to send signing preferences...
                            2158 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                            2163 Skipping security for command 3 type 15
                            2167 Mark node 0 as one that require signed messages
                            2171 Mark node 0 as one that do not require whitelisting
                            2181 Skipping security for command 3 type 16
                            2186 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                            2192 Nonce requested from 0. Waiting...
                            2225 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=0:FA0CEF05B11135F19B646D3FA36FE1BCFCC8DAC1A3773BDC79
                            2234 Skipping security for command 3 type 17
                            2238 Nonce received from 0.
                            2240 Proceeding with signing...
                            2334 Message signed
                            2341 Message to send has been signed
                            2348 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=18,pt=0,l=5,sg=1,ft=0,st=OK:2.1.1
                            2354 Skipping security for command 3 type 16
                            2361 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            2367 Nonce requested from 0. Waiting...
                            2492 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:D92FBB57AB79BCCC3E9452F7E4B876FFFBC7FE47C2AD0613C8
                            2501 Skipping security for command 3 type 17
                            2505 Nonce received from 0.
                            2508 Proceeding with signing...
                            2601 Message signed
                            2609 Message to send has been signed
                            2615 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
                            4621 Skipping security for command 3 type 16
                            4627 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            4633 Nonce requested from 0. Waiting...
                            4665 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:E38FE6554A3AE6D02B91B69EE2B67602506D8308DB5D4EAF3E
                            4675 Skipping security for command 3 type 17
                            4679 Nonce received from 0.
                            4681 Proceeding with signing...
                            4775 Message signed
                            4783 Message to send has been signed
                            4789 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=5,sg=1,ft=0,st=OK:Relay
                            4795 Skipping security for command 3 type 16
                            4802 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            4808 Nonce requested from 0. Waiting...
                            4933 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:2385BA03A156C8D203085EE05B480A4819CC88E82D9BA6209F
                            4942 Skipping security for command 3 type 17
                            4946 Nonce received from 0.
                            4950 Proceeding with signing...
                            5043 Message signed
                            5050 Message to send has been signed
                            5056 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
                            5062 Skipping security for command 3 type 16
                            5069 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            5075 Nonce requested from 0. Waiting...
                            5200 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:F1048244D308662147413A8531A71EF5C5E241710A859D7562
                            5210 Skipping security for command 3 type 17
                            5214 Nonce received from 0.
                            5217 Proceeding with signing...
                            5310 Message signed
                            5317 Message to send has been signed
                            5323 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=1,ft=0,st=OK:
                            5329 Skipping security for command 3 type 16
                            5336 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            5342 Nonce requested from 0. Waiting...
                            5468 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:24D0165B9B9152F2003597B3747DC61B9C67C595A1518C31BD
                            5477 Skipping security for command 3 type 17
                            5481 Nonce received from 0.
                            5483 Proceeding with signing...
                            5577 Message signed
                            5584 Message to send has been signed
                            5591 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=1,ft=0,st=OK:TemperatureAndHumidity
                            5599 Skipping security for command 3 type 16
                            5605 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            5611 Nonce requested from 0. Waiting...
                            5736 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:F95653815901C8FACA219583E9C6FEA53596238E460528DA6A
                            5746 Skipping security for command 3 type 17
                            5750 Nonce received from 0.
                            5752 Proceeding with signing...
                            5847 Message signed
                            5854 Message to send has been signed
                            5860 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.1
                            5866 Skipping security for command 3 type 16
                            5872 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            5878 Nonce requested from 0. Waiting...
                            6003 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:D356C66B145EA4E7DCF69EC5B3C20E38D6046C50A4FEACE71B
                            6013 Skipping security for command 3 type 17
                            6018 Nonce received from 0.
                            6020 Proceeding with signing...
                            6114 Message signed
                            6121 Message to send has been signed
                            6127 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=1,ft=0,st=OK:
                            6132 Skipping security for command 3 type 16
                            6139 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            6146 Nonce requested from 0. Waiting...
                            6270 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:E4DDE1558F406F93C24ACC4978B5DAD078700CB3E898D665BB
                            6280 Skipping security for command 3 type 17
                            6284 Nonce received from 0.
                            6287 Proceeding with signing...
                            6380 Message signed
                            6387 Message to send has been signed
                            6393 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=1,ft=0,st=OK:
                            6400 MCO:REG:REQ
                            6401 Skipping security for command 3 type 26
                            6408 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                            6514 TSF:MSG:READ,0-0-1,s=255,c=3,t=16,pt=0,l=0,sg=0:
                            6519 Skipping security for command 3 type 16
                            SHA256: 70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB400000000000000
                            6539 Skipping security for command 3 type 17
                            6551 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:70A5921ABD527FBF58E2644ACAC3EB9D7D190A1ECFA2B45BB4
                            6561 Transmitted nonce
                            6681 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                            HMAC: 71BFB4D075B6FC246460FC35C2173D8DBD366ABF0A6ED0C23FA2F84AC4293267
                            Signature bad: 01BFB4D075B6FC246460FC35C2173D8DBD366ABF0A6ED0C2
                            6782 Signature verification failed!
                            6791 !TSF:MSG:SIGN VERIFY FAIL
                            6794 MCO:BGN:STP
                            6796 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            6801 !MCO:SLP:REP
                            7803 MCO:BGN:INIT OK,TSP=1
                            7827 Skipping security for command 3 type 16
                            7834 TSF:MSG:SEND,1-1-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            7840 Nonce requested from 0. Waiting...
                            7872 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:B946C285F3F5F9204731209AF33E759FF1F604EADDAC89BE1C
                            7881 Skipping security for command 3 type 17
                            7885 Nonce received from 0.
                            7888 Proceeding with signing...
                            HMAC: 4BE74C2A504B304F48E28201FBB2B85E10BD50EB7C577F3F443691573796A4F6
                            7982 Message signed
                            7989 Message to send has been signed
                            7995 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:24.0
                            T: 24.00
                            8002 Skipping security for command 3 type 16
                            8008 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            8014 Nonce requested from 0. Waiting...
                            8153 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:AC6CB618B3BB07F385D25228E62B753BF888DA6351087FD39D
                            8162 Skipping security for command 3 type 17
                            8166 Nonce received from 0.
                            8169 Proceeding with signing...
                            HMAC: EB51796D338A1717D7B544C78054CBE9E39D901D56F76EBA9A61CC753EFADB59
                            8262 Message signed
                            8269 Message to send has been signed
                            8275 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=1,ft=0,st=OK:46.0
                            H: 46.00
                            8283 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            8288 !MCO:SLP:REP
                            68311 Skipping security for command 3 type 16
                            68317 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            68323 Nonce requested from 0. Waiting...
                            68356 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:8A0A85658B3A6AA9ABBBDC34E3B6891159CF3BD3369A0334BA
                            68365 Skipping security for command 3 type 17
                            68369 Nonce received from 0.
                            68372 Proceeding with signing...
                            Message to process: 01002EE101000000344201
                            Current nonce: 8A0A85658B3A6AA9ABBBDC34E3B6891159CF3BD3369A0334BAAAAAAAAAAAAAAA
                            HMAC: 6D6A1E530B4840BFF51DD3D926CEE1761909EB6F458B16F0D7CF2EBBB48321CB
                            Signature in message: 016A1E530B4840BFF51DD3D926CEE1761909EB6F
                            68465 Message signed
                            68473 Message to send has been signed
                            68482 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=1,ft=0,st=OK:45.0
                            H: 45.00
                            68489 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            68494 !MCO:SLP:REP
                            This is without using whitelisting, just signing. The node and gateway are both working in regular mode. I am able to send a command through Domoticz to turn on/off the relay and also see the temperature sensor attached to the same arduino.
                            All I added to the scetches of the GW and node was the following:
                            // Select soft/hardware signing method
                            #define MY_SIGNING_SOFT //!< Software signing
                            //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
                            // Enable node whitelisting
                            //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
                            // Enable this if you want destination node to sign all messages sent to this node.
                            // SETTINGS FOR MY_SIGNING_SOFT
                            #define MY_SIGNING_SOFT_RANDOMSEED_PIN A5 //!< Unconnected analog pin for random seed
                            // SETTINGS FOR MY_SIGNING_ATSHA204
                            //#define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
                            What step am I missing?
                            AnticimexA 3 Replies Last reply
                            • K karelsmits
                              Gateway:
                              0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
                              0;255;3;0;9;TSM:INIT
                              0;255;3;0;9;TSF:WUR:MS=0
                              0;255;3;0;9;TSM:INIT:TSP OK
                              0;255;3;0;9;TSM:INIT:GW MODE
                              IP: 192.168.0.249
                              0;255;3;0;9;MCO:BGN:STP
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
                              0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.0
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=22,sg=1:TemperatureAndHumidity
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.1
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=0,t=7,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=0,t=6,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                              0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                              0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                              Node:
                              3 MCO:BGN:BFR
                              5 TSM:INIT
                              6 TSF:WUR:MS=0
                              13 TSM:INIT:TSP OK
                              15 TSF:SID:OK,ID=1
                              16 TSM:FPAR
                              2066 TSM:FPAR:OK
                              2067 TSM:ID
                              2068 TSM:ID:OK
                              2070 TSM:UPL
                              2107 TSM:UPL:OK
                              2334 Message signed
                              2601 Message signed
                              4775 Message signed
                              5043 Message signed
                              5310 Message signed
                              5577 Message signed
                              5847 Message signed
                              6114 Message signed
                              6380 Message signed
                              6400 MCO:REG:REQ
                              6794 MCO:BGN:STP
                              6801 !MCO:SLP:REP
                              7982 Message signed
                              T: 24.00
                              8262 Message signed
                              H: 46.00
                              8288 !MCO:SLP:REP
                              H: 45.00
                              68494 !MCO:SLP:REP
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @karelsmits Any configuration settings you do in your sketch MUST be placed before
                              • K karelsmits
                                Gateway:
                                IP: 192.168.0.249
                                0;255;3;0;9;Skipping security for command 3 type 16
                                Node:
                                3 MCO:BGN:BFR
                                5 TSM:INIT
                                6 TSF:WUR:MS=0
                                13 TSM:INIT:TSP OK
                                15 TSF:SID:OK,ID=1
                                16 TSM:FPAR
                                2066 TSM:FPAR:OK
                                2067 TSM:ID
                                2068 TSM:ID:OK
                                2070 TSM:UPL
                                2107 TSM:UPL:OK
                                2334 Message signed
                                2601 Message signed
                                4775 Message signed
                                5043 Message signed
                                5310 Message signed
                                5577 Message signed
                                5847 Message signed
                                6114 Message signed
                                6380 Message signed
                                6400 MCO:REG:REQ
                                6794 MCO:BGN:STP
                                6801 !MCO:SLP:REP
                                7982 Message signed
                                T: 24.00
                                8262 Message signed
                                H: 46.00
                                8288 !MCO:SLP:REP
                                H: 45.00
                                68494 !MCO:SLP:REP
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @karelsmits Also, you cannot have the same whitelist on both GW and node. Each have their own serial, and nodeId so they have different whitelists. You had this in your original settings. They were correct and in line with the personalization data you provided.
                                Just make sure that these settings take place before including MySensors.h and make sure you don't have settings in MyConfig.h that would override the settings you do in your sketch,
                                • K karelsmits
                                  Gateway:
                                  IP: 192.168.0.249
                                  0;255;3;0;9;Skipping security for command 3 type 17
                                  0;255;3;0;9;Transmitted nonce
                                  0;255;3;0;9;Message to process: 0100B6030BFF54656D7065726174757265416E6448756D6964697479
                                  0;255;3;0;9;Message to process: 01001E030CFF312E31
                                  Node:
                                  3 MCO:BGN:BFR
                                  5 TSM:INIT
                                  6 TSF:WUR:MS=0
                                  13 TSM:INIT:TSP OK
                                  15 TSF:SID:OK,ID=1
                                  16 TSM:FPAR
                                  2066 TSM:FPAR:OK
                                  2067 TSM:ID
                                  2068 TSM:ID:OK
                                  2070 TSM:UPL
                                  2107 TSM:UPL:OK
                                  2334 Message signed
                                  2601 Message signed
                                  4775 Message signed
                                  5043 Message signed
                                  5310 Message signed
                                  5577 Message signed
                                  5847 Message signed
                                  6114 Message signed
                                  6380 Message signed
                                  6400 MCO:REG:REQ
                                  6794 MCO:BGN:STP
                                  6801 !MCO:SLP:REP
                                  7982 Message signed
                                  T: 24.00
                                  8262 Message signed
                                  H: 46.00
                                  8288 !MCO:SLP:REP
                                  H: 45.00
                                  68494 !MCO:SLP:REP
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @karelsmits
                                  I have checked your most recent log and it looks very strange. Signatures are correctly verified in one direction but not the other.
                                  I honestly have no explanation for how this is possible.
                                  Could you try the beta version? That I have verified myself to be working.
                                  But be advised; you will have to re-run the personalization procedure if you do that. Details are here.
                                  The beta also provide some other security related options that you could try.
                                  Firstly I recommend that you define MY_SIGNING_WEAK_SECURITY since security is a bit tighter for the next release (a GW will remember and not reset the signing preferences of a node unless that flag is set, and that could be a pain when testing signing but not committing to stick with it).
                                  • K
                                    K
                                    karelsmits
                                    wrote on last edited by karelsmits
                                    okay will do and post you. thank again.
                                    BTW where do i find the beta link?
                                    • K
                                      K
                                      karelsmits
                                      sorry, but do you mind pointing the beta link you're referring to?
                                      thanks.
                                      AnticimexA 1 Reply Last reply
                                      • K karelsmits
                                        thanks.
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @karelsmits
                                        https://github.com/mysensors/MySensors/archive/development.zip
                                        • K
                                          K
                                          karelsmits
                                          Hi, thanks for your help so far.
                                          I am usinf the version you recommended. Now the signing seems to work, because I get a confirmation message from the gateway and the node. For some reason the gateway reports that the connection is dropped, it keeps on happening. What is wrong?
                                          I am only using signing, not whitelisting
                                          When signing is disabled, everything is working.
                                          Just FYI,I did not change anything in MyConfig.h
                                          Gateway:
                                          __  __       ____
                                                  |___/                      2.2.0-beta
                                          17 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0-beta
                                          49 SGN:PER:OK
                                          79 SGN:INI:BND OK
                                          81 TSM:INIT
                                          82 TSF:WUR:MS=0
                                          90 TSM:INIT:TSP OK
                                          91 TSM:INIT:GW MODE
                                          93 TSM:READY:ID=0,PAR=0,DIS=0
                                          96 MCO:REG:NOT NEEDED
                                          IP: 192.168.0.249
                                          1398 MCO:BGN:STP
                                          1400 MCO:BGN:INIT OK,TSP=1
                                          2089 TSF:MSG:READ,9-9-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          2095 TSF:MSG:BC
                                          2097 TSF:MSG:FPAR REQ,ID=9
                                          2099 TSF:CKU:OK,FCTRL
                                          2101 TSF:MSG:GWL OK
                                          2158 SGN:SKP:MSG CMD=3,TYPE=8
                                          2164 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          4141 TSF:MSG:READ,9-9-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          4146 SGN:SKP:MSG CMD=3,TYPE=24
                                          4149 TSF:MSG:PINGED,ID=9,HP=1
                                          4151 SGN:SKP:MSG CMD=3,TYPE=25
                                          4158 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          4180 TSF:MSG:READ,9-9-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                          4186 SGN:SKP:MSG CMD=3,TYPE=15
                                          4189 SGN:PRE:SGN REQ,FROM=9
                                          4192 SGN:PRE:SGN REQ,TO=9
                                          4194 SGN:PRE:WHI NREQ,TO=9
                                          4196 SGN:SKP:MSG CMD=3,TYPE=15
                                          4201 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                          4207 SGN:PRE:XMT,TO=9
                                          4215 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                          4220 SGN:SKP:MSG CMD=3,TYPE=16
                                          4238 SGN:SKP:MSG CMD=3,TYPE=17
                                          4246 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                                          4253 SGN:NCE:XMT,TO=0
                                          4355 TSF:MSG:READ,9-9-0,s=255,c=0,t=17,pt=0,l=10,sg=1:2.2.0-beta
                                          4361 SGN:BND:NONCE=4F5AD49AA0F433BE26060A9B1C55F23CC577EA281775DC0B02AAAAAAAAAAAAAA
                                          4448 SGN:BND:HMAC=78CCB5B0692D9B11DDE1FFB97C0DE0A17040DD6D55BC5BF357163635ACAAE484
                                          4456 SGN:VER:OK
                                          4458 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                          4462 SGN:SKP:MSG CMD=3,TYPE=16
                                          4480 SGN:SKP:MSG CMD=3,TYPE=17
                                          4486 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                                          4492 SGN:NCE:XMT,TO=0
                                          4594 TSF:MSG:READ,9-9-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                                          4599 SGN:BND:NONCE=A7CA0C7EF09F65DE5D02E9351E48E2A3D6DBF3537ECCF333F4AAAAAAAAAAAAAA
                                          4686 SGN:BND:HMAC=E731F01B8DF928A36DACBBCDE45651A4B7BE0B1D1248FAB2936CADC0BE85B9AF
                                          4694 SGN:VER:OK
                                          6606 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                          6611 SGN:SKP:MSG CMD=3,TYPE=16
                                          6628 SGN:SKP:MSG CMD=3,TYPE=17
                                          6634 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                                          6641 SGN:NCE:XMT,TO=0
                                          6743 TSF:MSG:READ,9-9-0,s=255,c=3,t=11,pt=0,l=11,sg=1:Secure Lock
                                          6749 SGN:BND:NONCE=CFCF368C893918E8B30F5BB9BD05BE2137CE6BC1C9D0A0C46AAAAAAAAAAAAAAA
                                          6836 SGN:BND:HMAC=E8CCAAE5D1577EFAE089947D520345555DF0A2A7038CDB17E8B9D897C41B5137
                                          6844 SGN:VER:OK
                                          6846 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                          6850 SGN:SKP:MSG CMD=3,TYPE=16
                                          6867 SGN:SKP:MSG CMD=3,TYPE=17
                                          6874 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                                          6880 SGN:NCE:XMT,TO=0
                                          6985 TSF:MSG:READ,9-9-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.0
                                          6990 SGN:BND:NONCE=81349D41F58F0A4219206D8C6A6C5CD822CD125BA0E22C1D08AAAAAAAAAAAAAA
                                          7077 SGN:BND:HMAC=144CC1F339C5D15BADE41B8CB8EC95FC6AAA37249EB4198169206F8D2116B6C0
                                          7085 SGN:VER:OK
                                          7087 TSF:MSG:READ,9-9-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                                          7092 SGN:SKP:MSG CMD=3,TYPE=16
                                          7109 SGN:SKP:MSG CMD=3,TYPE=17
                                          7114 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                                          7121 SGN:NCE:XMT,TO=0
                                          7224 TSF:MSG:READ,9-9-0,s=1,c=0,t=19,pt=0,l=14,sg=1:SecureActuator
                                          7230 SGN:BND:NONCE=80764434FE2DB0B952CE5DB13822E08EA76E4CC32848155EBCAAAAAAAAAAAAAA
                                          7317 SGN:BND:HMAC=7EBFF55E368306D2C1E9A0339DED228E80A0887140052FA13AABF1E5FE533218
                                          7324 SGN:VER:OK
                                          7326 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                                          7331 SGN:SKP:MSG CMD=3,TYPE=26
                                          7334 SGN:SKP:MSG CMD=3,TYPE=16
                                          7340 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                          7346 SGN:SGN:NCE REQ,TO=9
                                          9250 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                                          9255 SGN:SKP:MSG CMD=3,TYPE=26
                                          9259 SGN:SKP:MSG CMD=3,TYPE=16
                                          9264 TSF:MSG:SEND,58-80-9-77,s=67,c=7,t=32,pt=2,l=10,sg=0,ft=0,st=OK:17485
                                          9270 SGN:SGN:NCE REQ,TO=9
                                           __  __       ____
                                                  |___/                      2.2.0-beta
                                          18 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0-beta
                                          50 SGN:PER:OK
                                          77 SGN:INI:BND OK
                                          79 TSM:INIT
                                          80 TSF:WUR:MS=0
                                          88 TSM:INIT:TSP OK
                                          90 TSM:INIT:GW MODE
                                          91 TSM:READY:ID=0,PAR=0,DIS=0
                                          94 MCO:REG:NOT NEEDED
                                          IP: 192.168.0.249
                                          1397 MCO:BGN:STP
                                          1398 MCO:BGN:INIT OK,TSP=1
                                          1988 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                                          1993 SGN:SKP:MSG CMD=3,TYPE=26
                                          1996 SGN:SKP:MSG CMD=3,TYPE=16
                                          2000 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2007 SGN:SGN:NCE REQ,TO=9
                                          2030 TSF:MSG:READ,9-9-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                                          2035 SGN:SKP:MSG CMD=3,TYPE=17
                                          2038 SGN:NCE:FROM=9
                                          2040 SGN:NCE:15!=9 (DROPPED)
                                           __  __       ____
                                                  |___/                      2.2.0-beta
                                          51 SGN:PER:OK
                                          80 SGN:INI:BND OK
                                          82 TSM:INIT
                                          83 TSF:WUR:MS=0
                                          91 TSM:INIT:TSP OK
                                          92 TSM:INIT:GW MODE
                                          94 TSM:READY:ID=0,PAR=0,DIS=0
                                          97 MCO:REG:NOT NEEDED
                                          IP: 192.168.0.249
                                          1399 MCO:BGN:STP
                                          1401 MCO:BGN:INIT OK,TSP=1
                                          1956 TSF:MSG:READ,9-9-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                                          1961 SGN:SKP:MSG CMD=3,TYPE=26
                                          1965 SGN:SKP:MSG CMD=3,TYPE=16
                                          1969 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                          1975 SGN:SGN:NCE REQ,TO=9
                                          1998 TSF:MSG:READ,9-9-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                                          2003 SGN:SKP:MSG CMD=3,TYPE=17
                                          2007 SGN:NCE:FROM=9
                                          2009 SGN:NCE:7!=9 (DROPPED)
                                           __  __       ____
                                                  |___/                      2.2.0-beta
                                          51 SGN:PER:OK
                                          79 SGN:INI:BND OK
                                          81 TSM:INIT
                                          82 TSF:WUR:MS=0
                                          90 TSM:INIT:TSP OK
                                          92 TSM:INIT:GW MODE
                                          IP: 192.168.0.249
                                          1399 MCO:BGN:STP
                                          1965 TSF:MSG:READ,9-9-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                          1969 SGN:SKP:MSG CMD=3,TYPE=16
                                          1986 SGN:SKP:MSG CMD=3,TYPE=17
                                          1991 TSF:MSG:SEND,0-0-9-9,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                                          1998 SGN:NCE:XMT,TO=0
                                          2101 TSF:MSG:READ,9-9-0,s=255,c=3,t=23,pt=0,l=3,sg=1:LDB
                                          2107 SGN:BND:NONCE=82C773EAE20327A3D8AF62421F246E67B56C3B228CA6370164AAAAAAAAAAAAAA
                                          2194 SGN:BND:HMAC=52A2F9D7C90A5A8EB3B5820C654689041561D8FB42BCE89A7B9A91B3D73353E2
                                          2201 SGN:VER:OK
                                          Node:
                                          __  __       ____
                                                  |___/                      2.2.0-beta
                                          17 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.2.0-beta
                                          49 SGN:PER:OK
                                          77 SGN:INI:BND OK
                                          79 TSM:INIT
                                          80 TSF:WUR:MS=0
                                          88 TSM:INIT:TSP OK
                                          89 TSF:SID:OK,ID=9
                                          91 TSM:FPAR
                                          92 SGN:SGN:NREQ=255
                                          129 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2137 !TSM:FPAR:NO REPLY
                                          2139 TSM:FPAR
                                          2140 SGN:SGN:NREQ=255
                                          2177 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4185 !TSM:FPAR:NO REPLY
                                          4187 TSM:FPAR
                                          4188 SGN:SGN:NREQ=255
                                          4225 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4265 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          4270 SGN:SKP:MSG CMD=3,TYPE=8
                                          4273 TSF:MSG:FPAR OK,ID=0,D=1
                                          6233 TSM:FPAR:OK
                                          6234 TSM:ID
                                          6235 TSM:ID:OK
                                          6237 TSM:UPL
                                          6238 SGN:SKP:MSG CMD=3,TYPE=24
                                          6242 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          6259 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          6263 SGN:SKP:MSG CMD=3,TYPE=25
                                          6266 TSF:MSG:PONG RECV,HP=1
                                          6269 TSM:UPL:OK
                                          6270 TSM:READY:ID=9,PAR=0,DIS=1
                                          6274 SGN:PRE:SGN REQ
                                          6276 SGN:PRE:WHI NREQ
                                          6278 SGN:SKP:MSG CMD=3,TYPE=15
                                          6282 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                          6289 SGN:PRE:XMT,TO=0
                                          6291 SGN:PRE:WAIT GW
                                          6301 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                          6307 SGN:SKP:MSG CMD=3,TYPE=15
                                          6309 SGN:PRE:SGN REQ,FROM=0
                                          6312 SGN:SKP:MSG CMD=3,TYPE=16
                                          6317 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                          6323 SGN:SGN:NCE REQ,TO=0
                                          6347 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                                          6352 SGN:SKP:MSG CMD=3,TYPE=17
                                          6355 SGN:NCE:FROM=0
                                          6358 SGN:BND:NONCE=4F5AD49AA0F433BE26060A9B1C55F23CC577EA281775DC0B02AAAAAAAAAAAAAA
                                          6445 SGN:BND:HMAC=78CCB5B0692D9B11DDE1FFB97C0DE0A17040DD6D55BC5BF357163635ACAAE484
                                          6452 SGN:SGN:SGN
                                          6456 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=10,sg=1,ft=0,st=OK:2.2.0-beta
                                          6463 SGN:SKP:MSG CMD=3,TYPE=16
                                          6469 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                          6475 SGN:SGN:NCE REQ,TO=0
                                          6586 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                          6592 SGN:SKP:MSG CMD=3,TYPE=17
                                          6594 SGN:NCE:FROM=0
                                          6596 SGN:BND:NONCE=A7CA0C7EF09F65DE5D02E9351E48E2A3D6DBF3537ECCF333F4AAAAAAAAAAAAAA
                                          6684 SGN:BND:HMAC=E731F01B8DF928A36DACBBCDE45651A4B7BE0B1D1248FAB2936CADC0BE85B9AF
                                          6691 SGN:SGN:SGN
                                          6695 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
                                          8702 SGN:SKP:MSG CMD=3,TYPE=16
                                          8708 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                          8714 SGN:SGN:NCE REQ,TO=0
                                          8734 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                          8740 SGN:SKP:MSG CMD=3,TYPE=17
                                          8743 SGN:NCE:FROM=0
                                          8745 SGN:BND:NONCE=CFCF368C893918E8B30F5BB9BD05BE2137CE6BC1C9D0A0C46AAAAAAAAAAAAAAA
                                          8833 SGN:BND:HMAC=E8CCAAE5D1577EFAE089947D520345555DF0A2A7038CDB17E8B9D897C41B5137
                                          8840 SGN:SGN:SGN
                                          8844 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=11,sg=1,ft=0,st=OK:Secure Lock
                                          8851 SGN:SKP:MSG CMD=3,TYPE=16
                                          8857 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                          8863 SGN:SGN:NCE REQ,TO=0
                                          8974 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                          8980 SGN:SKP:MSG CMD=3,TYPE=17
                                          8982 SGN:NCE:FROM=0
                                          8984 SGN:BND:NONCE=81349D41F58F0A4219206D8C6A6C5CD822CD125BA0E22C1D08AAAAAAAAAAAAAA
                                          9071 SGN:BND:HMAC=144CC1F339C5D15BADE41B8CB8EC95FC6AAA37249EB4198169206F8D2116B6C0
                                          9079 SGN:SGN:SGN
                                          9086 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
                                          9093 SGN:SKP:MSG CMD=3,TYPE=16
                                          9098 TSF:MSG:SEND,9-9-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                          9104 SGN:SGN:NCE REQ,TO=0
                                          9216 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                          9221 SGN:SKP:MSG CMD=3,TYPE=17
                                          9224 SGN:NCE:FROM=0
                                          9226 SGN:BND:NONCE=80764434FE2DB0B952CE5DB13822E08EA76E4CC32848155EBCAAAAAAAAAAAAAA
                                          9313 SGN:BND:HMAC=7EBFF55E368306D2C1E9A0339DED228E80A0887140052FA13AABF1E5FE533218
                                          9320 SGN:SGN:SGN
                                          9324 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=19,pt=0,l=14,sg=1,ft=0,st=OK:SecureActuator
                                          9332 MCO:REG:REQ
                                          9333 SGN:SKP:MSG CMD=3,TYPE=26
                                          9339 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                                          9441 TSF:MSG:READ,0-0-9,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                          9445 !TSF:MSG:PVER,1=2
                                          11346 SGN:SKP:MSG CMD=3,TYPE=26
                                          11352 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                                          11364 TSF:MSG:READ,58-80-77,s=67,c=7,t=32,pt=2,l=10,sg=0:17485
                                          11369 !TSF:MSG:PVER,3=2
                                          13358 SGN:SKP:MSG CMD=3,TYPE=26
                                          13363 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                                          13374 TSF:MSG:READ,0-0-9,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                          13379 SGN:SKP:MSG CMD=3,TYPE=16
                                          13382 SGN:NCE:LEFT=4
                                          13399 SGN:SKP:MSG CMD=3,TYPE=17
                                          13404 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                                          13411 SGN:NCE:XMT,TO=9
                                          15369 SGN:SKP:MSG CMD=3,TYPE=26
                                          15374 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                                          15385 TSF:MSG:READ,0-0-9,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                          15390 SGN:SKP:MSG CMD=3,TYPE=16
                                          15393 SGN:NCE:LEFT=3
                                          15410 SGN:SKP:MSG CMD=3,TYPE=17
                                          15415 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                                          15422 SGN:NCE:XMT,TO=9
                                          17382 MCO:NLK:NODE LOCKED. TO UNLOCK, GND PIN 14 AND RESET
                                          17387 SGN:SKP:MSG CMD=3,TYPE=16
                                          17392 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                          17398 SGN:SGN:NCE REQ,TO=0
                                          17420 TSF:MSG:READ,0-0-9,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                          17425 SGN:SKP:MSG CMD=3,TYPE=17
                                          17428 SGN:NCE:FROM=0
                                          17430 SGN:BND:NONCE=82C773EAE20327A3D8AF62421F246E67B56C3B228CA6370164AAAAAAAAAAAAAA
                                          17517 SGN:BND:HMAC=52A2F9D7C90A5A8EB3B5820C654689041561D8FB42BCE89A7B9A91B3D73353E2
                                          17525 SGN:SGN:SGN
                                          17529 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=23,pt=0,l=3,sg=1,ft=0,st=OK:LDB
                                          17536 MCO:NLK:TSL
                                          Thank you
