  3. 💬 MySensors Gateway for Raspberry PI
raspberrymysensors gateway
49 Posts 14 Posters 16.8k Views 12 Watching
  • TriXwooDT
    TriXwooDT
    TriXwooD
    Way cool!
    I definitely have to learn this skill in next couple of months.
      have you tried both rfm69 and nrf24 working on the same time?
      TriXwooDT 1 Reply Last reply
        TriXwooDT
        TriXwooDT
        TriXwooD
        wrote on last edited by TriXwooD
        #23
        @gohan the spi0 and spi1 busses are two separate devices from the pi's perspective and the two MySensors gateways running*. So if v2 worked with a rfm69, and the v3 extra! wiring is good. (didn't check but 99.9999...%, even the logo is there :-).
        Yes it will work. There is no conflict there.
        • Is it possible to make it one gateway running on the pi for both chips?**
        ** How do I build a mysensor bridge between 433 and nrf24l01 nodes anyway? I can run domoticz on a pi to be the intermediate. But if I am not running a pi but an arduino gateway?
        • TriXwooDT
          TriXwooDT
          TriXwooD
          But if someone could enlighten me why I could not use two nrf24l01 devices working on the same bus using the select... (spi0.0 and spi0.1 and using CS?/CE?) (it really seems that data from the two radio's got mangled together somehow, I notice that cuz sometimes it did work... probably when only one radio was sending)
          I would me most gratefull :-)
          • llegoffL
            llegoffL
            llegoff
            The v1 (without regulator) works for me with an rfm69, so the v2 must work, because is the same wiring. (I have to receive the pcb v2 these days)
            TriXwood tested the operation of a second module nrf24l01 on the spi1
            see https://forum.mysensors.org/topic/7702/double-spi-radio-raspberry-pi
            when I have time, I will test the rfm69 with nrf24l01.
              I am hoping for the good test results as it would save me quite some wiring/mess for my dual network setup. Will it be able to run both NRF24 PA LNA and RFM69HW both at max power?
              • qqlapralineQ
                qqlapralineQ
                qqlapraline
                Very nice design ! I will buy a bunch of these.
                I'm using a BMP180 on my raspberry now, that would be great to add an I2C port somewhere in a potential v5 :)
                • qqlapralineQ
                  qqlapralineQ
                  qqlapraline
                  I did a quick update of the PCB.
                  It's not perfect but it does fullfill my (selfish) needs ;)
                  0_1509659115842_MySensorsPiGw.kicad_pcb
                  QQ.
                  • H
                    H
                    hiddenuser
                    @llegoff nice board!!! I think 🤔 I am going to build this. However just wondering if this will support rfm69hcw?
                      Why do you need to have it compatible with the C version?
                      H 1 Reply Last reply
                        H
                        H
                        hiddenuser
                        @gohan I have a lot c version with me :)
                          Are there any news on this project?
                          • pepsonP
                            pepsonP
                            pepson
                            Hi
                            Can i replace AP1117 to AMS1117 ?
                            • pepsonP
                              pepsonP
                              pepson
                              And we can use in one gateway radio RFM69HW and NRF24L01 ? And use node with radio 2,4GHz and node with RFM69HW ?
                                I have both radio modules working on my raspberry
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Can you give me more info how configure it and build ?
                                    Look on the link on the opening post
                                    pepsonP 1 Reply Last reply
                                      pepsonP
                                      pepsonP
                                      pepson
                                      wrote on last edited by pepson
                                      #38
                                      @gohan
                                      You mean this
                                      https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI
                                      Install RFM69HW and then create the same for NRF24L01 on SPI1 ?
                                      • llegoffL
                                        llegoffL
                                        llegoff
                                        hello,
                                        i have update the description page (it is not automaticaly syncronize with my github page)
                                        OK for AMS1117-3.3
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          What you update info ?
