  3. 💬 Ebyte nRF52832 Prototyping Board
7 Posts 3 Posters 1.9k Views 2 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
    • NeverDieN Offline
      NeverDieN Offline
      I suppose panelizing this board together with a pure prototype board might achieve the objective I was aiming for....
      • NeverDieN Offline
        NeverDieN Offline
        It works. Project completed. :)
        • NeverDieN Offline
          NeverDieN Offline
          I recommend snipping off the DTR pin using flush cutters. Given the current configuration, it isn't going to work properly.
          • ahmedadelhosniA Offline
            ahmedadelhosni
            Can you please propose what type of inductors and capacitors did you use ?
            A BOM will be great.
            Actually I am asking because I knew there is something called SRF from this topic https://devzone.nordicsemi.com/question/171472/filter-inductor-requirement-for-nrf52832-in-dcdc-mode/
            Thanks.
            NeverDieN 1 Reply Last reply
            • ahmedadelhosniA ahmedadelhosni
              Thanks.
              NeverDieN Offline
              NeverDieN Offline
              @ahmedadelhosni said in 💬 Ebyte nRF52832 Prototyping Board:
              It is exactly the same BOM as this: https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board#tabs-bom
              ahmedadelhosniA 1 Reply Last reply
              • NeverDieN NeverDie
                ahmedadelhosni
                @NeverDie thanks
