  3. MQTT Epic Fail
MQTT Epic Fail
4 Posts 2 Posters 1.3k Views 2 Watching
  • D
    D
    danE
    I have several sensors and alarms running very similar code, I'm using a wemos d1 mini for this one and Arduino ide for the code. Problem is mqtt client disconnects repeatedly throwing a socket error in the server side logs. I've changed the variables and the void reconnect code and the delay times around a bunch as well as uploading parts of the code separately to try and debug, so far nothing has helped the issue.
    Here's the code I'm currently trying to run...
    #include <PubSubClient.h>
    #include <ESP8266WiFi.h>
    #define MQTT_SERVER "192.168.0.123"
    const char* ssid = "censored";
    const char* password = "censored";
    const int indpin = 15;
    const int indpin2 = 12;
    const int indpin3 = 16;
    const int alrmpin1 = 2;
    const int alrmpin2 = 0;
    const int button1 = 14;
    const int button2 = 13;
    int button1Stat = 0;
    int button1Count = 0;
    int button1last = 0;
    int button2Stat = 0;
    int button2Count = 0;
    int button2last = 0;
    void callback(char* topic, byte* payload, unsigned int length);
    WiFiClient wifiClient;
    PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
    pinMode(indpin2, OUTPUT);
    pinMode(indpin, OUTPUT);
    pinMode(indpin3, OUTPUT);
    pinMode(alrmpin1, OUTPUT);
    pinMode(alrmpin2, OUTPUT);
    pinMode(button1, INPUT);
    pinMode(button2, INPUT);
    digitalWrite(indpin, LOW);
    digitalWrite(indpin2, LOW);
    digitalWrite(indpin3, LOW);
    digitalWrite(alrmpin1, LOW);
    digitalWrite(alrmpin2, LOW);
    Serial.begin(115200);
    delay(100);
    WiFi.mode(WIFI_STA);
    WiFi.begin(ssid, password);
    reconnect();
    delay(2000);
    void loop(){
    if (!client.connected() && WiFi.status() == 3) {reconnect();}
    client.loop();
    delay(1000);
    button1Stat = digitalRead(button1);
    if (button1Stat != button1last) {
    if (button1Stat == HIGH) {
      button1Count++;
    delay(50);
    button1last = button1Stat;
    if (button1Count % 2 == 0) {
    client.publish("indoor", "0");
    } else {
    client.publish("indoor", "1");
    button2Stat = digitalRead(button2);
    if (button2Stat != button2last) {
    if (button2Stat == HIGH) {
      button2Count++;
    delay(50);
    button2last = button2Stat;
    if (button2Count % 2 == 0) {
    client.publish("Smotion", "0");
    } else {
    client.publish("Smotion", "1");
    void callback(char* topic, byte* payload, unsigned int length) {
    String topicStr = topic;
    Serial.println("Callback update.");
    Serial.print("Topic: ");
    Serial.println(topicStr);
    if(payload[0] == '1' && topic[0] == 'i'){
    digitalWrite(indpin, HIGH);
    if (payload[0] == '0' && topic[0] == 'i'){
    if(payload[0] == '1' && topic[0] == 'S'){
    digitalWrite(indpin2, HIGH);
    if(payload[0] == '0' && topic[0] == 'S'){
    if (payload[0] == '1' && topic[0] == 's'){
    digitalWrite(indpin3, HIGH);
    if (payload[0] == '0' && topic[0] == 's'){
    if (payload[0] == '1' && topic[0] == 'o'){
    digitalWrite(alrmpin1, HIGH);
    if (payload[0] == '0' && topic[0] == 'o'){
    if (payload[0] == 'o' && topic[0] == 'o'){
    if (payload[0] == 'f' && topic[0] == 'o'){
    if (payload[0] == '2' && topic[0] == 'm'){
    digitalWrite(alrmpin2, HIGH);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    delay(500);
    void reconnect() {
    if(WiFi.status() != WL_CONNECTED){
    Serial.print("Connecting to ");
    Serial.println(ssid);
    while (WiFi.status() != WL_CONNECTED) {
      delay(500);
      Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
    if(WiFi.status() == WL_CONNECTED){
    while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    String clientName;
    clientName += "Master-";
    uint8_t mac[6];
    WiFi.macAddress(mac);
    clientName += macToStr(mac);
    if (client.connect((char*) clientName.c_str())) {
    Serial.print("\tMTQQ Connected");
        client.subscribe("indoor");
        client.subscribe("Smotion");
        client.subscribe("sec2");
        client.subscribe("motion");
        client.subscribe("outdoor");
        client.subscribe("outdoor2");
      else{Serial.println("\tFailed."); abort();}
    String macToStr(const uint8_t* mac){
    String result;
    for (int i = 0; i < 6; ++i) {
    result += String(mac[i], 16);
    if (i < 5){
    result += ':';
    return result;
      wrote on last edited by gohan
      Wellcome to the forum, but how is this related to mysensors?
      D 1 Reply Last reply
        D
        D
        danE
        @gohan didn't realize this was a forum for a specific development environment came here following a trail of other esp 8266 related issues and threw down a post. I see now I'm in the wrong place.
          well, if you are willing to make your alarm system to use Mysensors we would be very happy to help and learn from other people experience :)
