  3. NodeManager
  4. Error compiling NodeManager DHT22 sensor
3 Posts 2 Posters 2.5k Views 2 Watching
  • G Offline
    G Offline
    Getz99
    Error compiling DHT22 sensor
    I'm trying to make a simple DHT22 sensor Nodemanagersketch
    nodeManager.registerSensor(SENSOR_DHT22,6);
    But when I try to compile I get a warning in the NodeManager.cpp file:
    _dht->setup(_pin,_dht_type);
    and in the bottom field 'class DHT' has no member named 'setup'
    Does anyone know what I'm doing wrong?
    U 1 Reply Last reply
    • G Getz99
      U Offline
      U Offline
      user2684
      Hi @Getz99, are you sure MODULE_DHT is enabled? Also ensure that you are using the right DHT package referenced in the documentation. Please note the package has changed from v1.6 to v1.7. Thanks!
      G 1 Reply Last reply
      • U user2684
        G Offline
        G Offline
        Getz99
        Thanks @user2684 for your reply,
        I was using the wrong package, downloaded the latest version and now it works!
        Thanks again for your help and for the development of NodeManager!
