  3. Connect esp nodes to ethernet gateway
10 Posts 3 Posters 3.1k Views 3 Watching
  • T
    Tommas
    Dear All!
    I have a mysensors ethernet gateway with nrf24. Now all my nodes communicate with it via nrf24.
    I think that i would like to use some esp sensor nodes.
    how can i connect these new esp nodes to this same gateway over wifi?
    Thanks,
    • T Tommas
      Dear All!
      Thanks,
      @Tommas you can't. Each esp would be its own gateway.
      • korttomaK
        korttomaK
        korttoma
        @Tommas said in Connect esp nodes to ethernet gateway:
        nrf24
        Actually you can connect the ESP to your ethernet GW but then you also need to attach a nrf24 to your ESP and treat it as a normal node. Here is an example.
        • Tomas
        T 1 Reply Last reply
        • korttomaK korttoma
          nrf24
          Tommas
          @korttoma
          Thank for all!
          Can i use the ESP node over wifi without controller? Can i register these to openhab2?
          • T Tommas
            @korttoma
            Thank for all!
            @Tommas could you rephrase your question? openhab is a controller so I' not sure what you are asking.
            T 2 Replies Last reply
              Tommas
              wrote on last edited by Tommas
              @mfalkvidd
              Can I control/monitor the esp based sensors (which are connected to my AP, same network as openhab server) with openhab2 without any GATEWAY?
                Tommas
                Dear @mfalkvidd !
                Is it under understandable?
                Have a good day!
                • korttomaK
                  korttomaK
                  korttoma
                  If you want to use the MySensors library and connect each ESP directly to your controller you will have to use the Gateway code with local sensors on all of your ESPs. Then you do not need any NRF24 radios. Check that your controller is capable to handle multiple MySensors Gateways.
                  • Tomas
                    Tommas
                    @korttoma
                    So if i would like to use gateway for esp nodes i have to create an only esp gateway?
                    • korttomaK
                      korttomaK
                      korttoma
                      If you wan to run all nodes throug one gateway you need NRF24 on all of your devices. Both gateway and sensor nodes. But you only use the Gateway code on the Gateway and sensor code on the rest of them and only the Gateway needs a connection to your WiFi.
                      • Tomas
