  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.1k Views 13 Watching
  • Christian TollasC Christian Tollas
    @petewill greetings sir.. Im getting error in your source code.. Maybe imported a wrong library.. Sir can i ask where did u get your MySensors.h library.. I get mine in codebender..
    My error is..
    MySensor does not a nametype
    petewillP
    petewillP
    petewill
    @Christian-Tollas This code has not yet been updated for MySensors version 2.0. I am still on version 1.5. When I finally upgrade my setup to 2.0 I will post the updated code but I'm not sure when that will be. If you want to go back to 1.5 for the time being that should work for you.
    • D
      D
      dseveriano
      wrote on last edited by dseveriano
      #102
      I'm newbie at this and I'm trying to make this, but I think my hardware needs to be different sinces my home voltage is arround 220V, does this hardware can handle this voltage or do I need to buy other capacitators ?
      petewillP 1 Reply Last reply
      • D dseveriano
        petewillP
        petewillP
        petewill
        @dseveriano as always you need to be very careful when using these voltages. That being said, this should work without any other hardware except for a phone charger rated for 220 (which I believe most are). The relay I used was rated for 10A 250VAC. I wouldn't go as high as 10A though.
        D 1 Reply Last reply
        • petewillP petewill
          D
          D
          dseveriano
          @petewill Thank you, just one more question!
          What board is that, the red one where the relay is ? Is that necessary or can I put the relay in the same board ?
          • D dseveriano
            petewillP
            petewillP
            petewill
            @dseveriano Sorry, I'm not sure what you're asking. What board are you referring to?
              D
              D
              dseveriano
              #106
              @petewill Sorry the board I was refering was the relay board!!
              Regarding the current detection module wich one do you recommend ?
              • D dseveriano
                petewillP
                petewillP
                petewill
                @dseveriano Yes, the red board is the relay board which will control your 220V power.
                I haven't done much with current detecting but the module I was playing with was the ACS712. I found that even when no power was running through it there was still a few watts reported. Maybe that's a simple fix but I never really looked into it.
                • jeremushkaJ
                  jeremushkaJ
                  jeremushka
                  Did you integrate power meter function to your systeme?
                  • jeremushkaJ jeremushka
                    petewillP
                    petewillP
                    petewill
                    @jeremushka I haven't done it on the smart outlet but I did do it on my "Whole House Fan" project. You can check out the code from that if you're interested. Here is a link to the video if you wanted to check that out: https://youtu.be/KVsUe7sOCPo
                    Also, just make sure you check out the specs on the acs712 and don't pass through more current than is safe. I don't remember the specs off the top of my head but I knew my whole house fan was safe because of what it would be drawing
