  3. What are these modules?
8 Posts 4 Posters 2.6k Views 5 Watching
  • NeverDieN
    NeverDieN
    https://www.aliexpress.com/item/LCD-Board-T420XW01-V2-06A39-1A-42WL68C-Logic-board-New-In-stock-In-stock-Best-price/583655445.html?spm=a2g0s.9042311.0.0.LmSC1G
    I got some just to try. They definitely are not nRF24L01: if treated as such, they don't appear talk even to each other. What are they?
    • Nca78N
      Nca78N
      The infamous blob clones :)
      • NeverDieN
        NeverDieN
        I have some different blob modules which work quite well. Maybe the pinout on these are different.... Or maybe they're just complete junk. Is anyone here using them for anything?
          I always believed they are just a bunch of junk soldered on a pcb 😌
            manutremo
            I had those blobs modules in the past and returned them because they were fake (sold as nrf24L01). In fact, they worked quite well between them with the proper library; however they were unable to connect to genuine nrf24L01's.
            Those modules tend to contain chip Si24R1, which seems to be a copy of the legit nrf24L01's but they forgot (maybe intentionally?) a small detail which makes them incompatible. This is documented in many internet sites. I actually used those sites to support my claim to get my money returned. I remember I was able to find some library around which had been hacked to make them work, and some workarounds were even mentioned in this forum - see this.
            If they are not even able to connect with each other, the ones you received may just be 100% junk so you should just claim the seller for reimbursement.
            NeverDieN 1 Reply Last reply
            • M manutremo
              NeverDieN
              NeverDieN
              Sigrok lists some of the known clones: https://sigrok.org/wiki/Protocol_decoder:Nrf24l01 Only two of them are COB though. Of course, Sigrok may not have a complete list.
              • NeverDieN
                NeverDieN
                Looks as though they are very likely SE8R01's. This link contains a datasheet for the SE8R01 and a pinout for the SMD module: http://community.atmel.com/forum/help-identifying-nrf24l01-compatible-modules It does not appear that it can interoperate with an nRF24L01.
                • NeverDieN
                  NeverDieN
                  There's a library specifically designed to work with them: https://github.com/Sofcom/NRF24Lmodule-SE8R01
                  Also found another interesting library for working with other, different, "clones" of the nRF24L01: https://github.com/jnk0le/RFM7x-lib
