  3. My Node doesn't talk to Gateway!
5 Posts 2 Posters 1.6k Views 3 Watching
  • G
    G
    ghiglie
    Hi all,
    I've just jumped in, so I'm starting to build some gateways and nodes. The first pair I'm bauilding is nRF based, an NodeMCU w/ MQTT gateway, and a ProMini with an easy DHT11. Both sketches are "vanilla" from Examples; the nRFs are socketed to an adapter with an AMS for 5->3v with a 10uF capacitor, each no more that 20cm far from each other.
    So, they pairing - the node finds its parent, but they get stuck during communication:
    gateway:
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0
    0;255;3;0;9;!TSF:MSG:LEN,7!=32
    0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:MSG:GWL OK ```
    and node:
    693319 TSM:FAIL:PDT
    753324 TSM:FAIL:RE-INIT
    753326 TSM:INIT
    753334 TSM:INIT:TSP OK
    753336 TSM:FPAR
    753338 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    754536 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    754542 TSF:MSG:FPAR OK,ID=0,D=1
    755347 TSM:FPAR:OK
    755349 TSM:ID
    755349 TSM:ID:REQ
    755353 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    757362 TSM:ID
    757362 TSM:ID:REQ
    757366 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    759375 TSM:ID
    759375 TSM:ID:REQ
    759379 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    761389 TSM:ID
    761389 TSM:ID:REQ
    761393 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    763402 !TSM:ID:FAIL
    763404 TSM:FAIL:CNT=7
    763406 TSM:FAIL:PDT 693319 TSM:FAIL:PDT
    753326 TSM:INIT
    753336 TSM:FPAR
    755347 TSM:FPAR:OK
    755349 TSM:ID
    755349 TSM:ID:REQ
    757362 TSM:ID
    757362 TSM:ID:REQ
    759375 TSM:ID
    759375 TSM:ID:REQ
    761389 TSM:ID
    761389 TSM:ID:REQ
    763402 !TSM:ID:FAIL
    753326 TSM:INIT
    753336 TSM:FPAR
    755347 TSM:FPAR:OK
    755349 TSM:ID
    755349 TSM:ID:REQ
    757362 TSM:ID
    757362 TSM:ID:REQ
    759375 TSM:ID
    759375 TSM:ID:REQ
    761389 TSM:ID
    761389 TSM:ID:REQ
    763402 !TSM:ID:FAIL
    763406 TSM:FAIL:PDT ```
    I've added some extra debug switches found here on the forum, but it's not adding nothing interesting o readable.
    I've tried switching some nFR, I have some more at home (I'm a traveller!) I could try this weekend....
    Maybe the DHT is not reading, so the payload is shorter - 7 chars instead of 32 ?
    Any other suggestions to debug this?
    Thanks all!
    Marco
    atmega328p serial killer
    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
      have you tried with the mockmysensor sketch just to see if there are any changes?
      • G
        G
        ghiglie
        Uh, no! I didn't read about it. Gosh, I could have tried the sensors net much sooner! :( :D
        I'll try it... hopely tonite.
        TIA!
          you would have still needed the arduino and radio modules to run the mockmysensor sketch
          G 1 Reply Last reply
            G
            G
            ghiglie
            A small update. well, uploaded the mockmysensor sketch and gateway and nodes are talking flawlessly!
            I should take note: first, power the antennas directly from source. 2. upload mockmysensors
            Thanks @gohan !
