  3. Supercap Solar Powered Mysensors nodes as cheap as possible
98 Posts 6 Posters 32.8k Views 8 Watching
    wrote on last edited by gohan
    #81
    Do you have any suggestion on something of decent quality and not too high price? I mean something of at least 100F but that doesn't cost like 10$
    mfalkviddM N 2 Replies Last reply
      @gohan do you really need 100F? How much energy does your node consume? Maybe it is easier to get the energy consumption down than to find a cheap huge capacitor wih low self-discharge?
      N 1 Reply Last reply
        Well it probably doesn't need that much, but I plan to add more sensors and I need to compensate for the winter days when it's cloudy and the daylight is shorter. Of course I could expose the solar panel to direct sunlight to optimize the charging but it would be exposed to harsher weather conditions and the sun will cause the temperature reading to be higher.
          N Offline
          N Offline
          #84
          @gohan said in Supercap Solar Powered Mysensors nodes as cheap as possible:
          https://www.digikey.com/products/en/capacitors/electric-double-layer-capacitors-edlc-supercapacitors/61?k=avx+supercap&k=&pkeyword=avx+supercap&pv2049=u100F&mnonly=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
          AVX is a good brand. At least worth a shot to test your idea. If it doesn't meet your expectations, then it's not the supercap's fault. If it turns out to be overkill, you can downgrade from there. Or just start with the higheswt capacity AVX supercap that you think is affordable and make your give-up decision after first testing with that.
          gohanG N 2 Replies Last reply
            N Offline
            N Offline
            #85
            @mfalkvidd said in Supercap Solar Powered Mysensors nodes as cheap as possible:
            I agree, but I think he just wants to quickly test his proof-of-concept first without thinking about it too hard. Kinda a first-fit rather than best-fit search pattern. We've all done it, I'm sure.
            • N NeverDie
              #86
              @neverdie 8$ it is not bad but still 6x the initial price I was thinking. Also 8$ is the cost of 3 or 4 LiFePo4 AA batteries that are less temperature sensitive than lipo but can still hold a lot more energy than a supercapacitor and have the right 3.3v working voltage avoiding the need for a voltage regulator/booster . I'll think about it
              • N NeverDie
                N Offline
                N Offline
                #87
                @neverdie said in Supercap Solar Powered Mysensors nodes as cheap as possible:
                Or just start with the highest capacity AVX supercap that you think is affordable
                  I always like to stay on the safe side and plan ahead. Now I need to find out quickly if the solar panel is actually able to provide enough power to keep the node running even with short daylight ( I am thinking about using the LiFePO4 battery charged at 3.1V and see if it can reach the 3.3V or if it drops below 3V); meanwhile I'll try to do a runtime test on the supercaps and try to see how long I can power a node without sleep and make an estimate for a target capacity of a good quality supercap
                    The LiFePO4 battery setup was unable to charge the battery (maybe because I didn't study how to charge those batteries). I am now back to the 5V supercaps but with the HW radio to see how it works and I noticed the TX power dropped from 40% to 0% so the power amplifier is actually doing its job
                      Also the buck/boost module has some low voltage issues when voltage drops below 1.4V it start drawing 130/140mA and I needed to increase voltage to 1.7V (where it was drawing 240mA) before it started to supply the correct voltage for the node to boot and have the current back to a normal 20/40mA.
                      I need to find a solution for recovering the node after the booster goes crazy and that would require for sure using a voltage detector like @NeverDie suggested but that is going to require making a custom PCB with integrated booster for the 3.3v output and the supercap charger mentioned earlier.
                      Is anybody willing to help? :sweat_smile:
                        Ok, after almost a year 3 out of 5 5.5v supercaps started leaking... Rip
                        M 1 Reply Last reply
                          M Offline
                          M Offline
                          Mathea90
                          @gohan that's a pity. Do you know what the root cause could be? Temperature? Charging cycles? Bad part quality?
                          • N Offline
                            N Offline
                            #93
                            Andreas Spiess did a whole video on how to properly charge supercaps in series. Gohan's supercaps were just soldered together without those protections to get their 5.5v rating. Maybe it was that. Or, since it was outdoors, maybe corrosion got to them.... It would be interesting to hear what Gohan's post-mortem reveals. As Edison would say, Gohan learned a new way of how not to do it. That still leaves a lot of ways that it could be done though.
                              No idea really, the box was sealed. I suspect they might have gotten unbalanced. About charge cycles I don't think they were a problem since they probably had less than 400 (1 cycle a day). They were cheap Chinese parts, so poor quality for sure given the self discharge rate they had. Given the cost of a LiFePO4 battery compared to supercaps, I think I'm going to take the battery route and ditch the whole solar power. I have an identical node running on a single AA LiFePO4 and in 8 months it barely discharged even if it is sending 4 values every 10 minutes
                              • N Offline
                                N Offline
                                I've forgotten, but didyou do any protection circuit for your supercaps to keep each one from overcharging? Julien Ilett tested some and found that not all of Chinee circuits stopped the charging at 2.7v, but instead allowed them to go to 2.8 or 2.9v instead:
                                https://www.youtube.com/watch?v=r7M6Pb2roLs&t=180s
                                So, maybe that's what happened to the yours that leaked.
                                  I couldn't because they are packed together, but it was something I was expecting anyway. I had them completely discharged every now and then when the arduino went crazy and drained them out.
                                    Small update after some time running on 2 100F supercaps in parallel
                                    Voltage seems consistent over time
                                    Here you can see the transition from the 5.5v supercaps to the normal ones, the odd thing is that it seems the supercaps took a few days to accept higher charge voltage
                                    • wallyllamaW Offline
                                      wallyllamaW Offline
                                      wallyllama
                                      I may misunderstand how they work, but I've had the idea that (super)caps are better in short term high current situations. Like regenerative brakes for robot lawnmowers, not slow drain low power devices. It sounds to me like the life boat is the lifepo4 batteries. I'm all for experiments, so please dont stop, but unless the environmental conditions are intolerable for the batteries, I'd say you found your answer.
                                      12.2k
