  3. Sensor ACK responses
3 Posts 2 Posters 1.8k Views 1 Watching
  • B Offline
    B Offline
    batfasturd
    First post so I want to say Hi to everyone and also ask a question. When building a relay switch node I noticed while toggling back and forth that there is the possibility for openhab to show that I turned a relay on but the module/sensor never received the command. Can the sensors respond back with an ACK in anyway letting me know that it received the command? Or is there a workaround that anyone has come up with to make sure that a sensor received the command it was sent?
    Thank you!
    B 1 Reply Last reply
    • B batfasturd
      Thank you!
      B Offline
      B Offline
      BulldogLowell
      wrote on last edited by BulldogLowell
      @batfasturd
      you can ack... learn about them here under Sending Data
      • B Offline
        B Offline
        batfasturd
        Thank you for the quick response, I will have to look that over and see if I can implement it into openhab or if anyone else has done it. So far my desk looks like a mad scientists lab with arduino parts and sensors scattered about. I do have to say I am having a blast so far digging into the code and playing with hardware.
