  3. 💬 Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel
117 Posts 18 Posters 43.3k Views 17 Watching
  • NeverDieN
    NeverDieN
    #21
    Aha! Found one: https://www.digikey.com/product-detail/en/samtec-inc/FTSH-105-01-F-DV-K/SAM8796-ND/2649974
    Not cheap on Digikey though.
    • NeverDieN
      NeverDieN
      #22
      Also, since the back of it is almost entirely ground plane anyway, it seems ripe for using a smaller profile CR2032 battery holder, such as: https://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=243085164&uq=636456618668326452
      Not only would it be thinner, but maybe (?) I could also shave a few millimeters off the PCB diameter .
      So, yeah, I'm definitely open to improving the design.
      Nca78N 1 Reply Last reply
      • Nca78N
        Nca78N
        Hello @NeverDie, the Molex connector was used to replace the I2C connector that you have used, not the IDC one.
        Good link you have found for the SMD version, didn't notice the one I found was through holes, SMD version is much better I agree.
        That 2.75$ thing on Digikey is way too expensive, I would go for the box version.
        • NeverDieN NeverDie
          Nca78N
          Nca78N
          @NeverDie said in 💬 CR2032 Small Wireless Temperature-Humidity Sensor:
          Your link is broken, looks like a search result and not a product page ;)
          • Nca78N Nca78
            NeverDieN
            NeverDieN
            #25
            @Nca78 said in 💬 CR2032 Small Wireless Temperature-Humidity Sensor:
            Thanks for letting me know. Not sure what's going wrong. When I click on the link, it takes me right there.
            Hmmmmm... The manufacturer's part number is "BK-913-TR". Try entering that into the search field on digikey. It's the one for $0.38.
            • NeverDieN
              NeverDieN
              #26
              I've just now uploaded Version 3, which fixes an overlap issue in Version 2 between the 10-pin connector and the optional Si7021/BME280. AFAIK, everything should work now.
              • Nca78N Nca78
                Thanks for the suggestion. What would the hall sensor be used for?
                For a door sensor. This PCB is small enough to be hidden inside a door edge, if you put it on top with a small magnet in the frame it's completely invisible and you've got that mythical 100% WAF level :D
                There is a cheap version, TLE4913 that's available on AliExpress (less than 2$ for 10 with shipping), it's consuming around 4uA so it's not extremely energy efficient but you can't beat the price on AliExpress.
                https://www.aliexpress.com/item/in-stock-can-pay-TLE4913-4913-SOT-23/32823499977.html
                Then there's the DRV5032 from TI that had the lowest power consumption a few month ago when I bought it, it's 0.5$ on Arrow and needs only 0.54uA in the FB (5Hz) version
                https://www.arrow.com/en/products/drv5032fbdbzr/texas-instruments
                And now I see the si7201 for 1$ on Arrow, using only 400nA.
                My choice would still be for the DRV5032, but the good news is all those sensors are using the same package with the same pin assignment. There are a few others (including one that scalz used in one of his design) also with the same pin assignment.
                NeverDieN
                NeverDieN
                Thanks for the links. I think I'll first try putting the Version 3 TH sensor into the deadbolt cavity and see what kind of range I get with that. It might be seriously impaired, since it will have metal on 2-3 sides. If I'm getting usable signal though at a decent range, then at that point I'll look into adding the DRV5032 to the board.
                • NeverDieN
                  NeverDieN
                  #28
                  Yesterday I received an CR2477 button cell holder, and it appears that it can easily substitute for the CR2032 in the BOM: the pins seem very much aligned.
                  https://www.digikey.com/product-detail/en/mpd-memory-protection-devices/BH1000G/BH1000G-ND/140383
                  Therefore, if you want a battery with roughly 4x the mah and which can also support a higher current drain than a CR2032, it's a good option. :)
                  • Nca78N Nca78
                    NeverDieN
                    NeverDieN
                    Try this: https://www.digikey.com/product-detail/en/mpd-memory-protection-devices/BK-913-TR/BK-913-CT-ND/6200236
                    • NeverDieN
                      NeverDieN
                      I just now uploaded some demo source code that will make the node into a proper MySensors temperature node.
                      • NeverDieN
                        NeverDieN
                        I just now uploaded the Version 4 files. The new design uses the more compact CR2032 battery holder discussed above. :)
                        • Nca78N Nca78
                          Also, what about moving the led to the center next to its resistor, it would leave enough space to squeeze in a SOT 23 ultra low power hall sensor and it's 100nF capacitor.
                          NeverDieN
                          NeverDieN
                          Yes, with the Version 4 design serving as the basis, I think there will be enough room to do this.
                          I'd also like to add a light sensor of some kind: something that will trigger an interrupt when, say, a refrigerator light goes on or off (for the case where the temperature node is in a refrigertor or freezer). Do you have any particular suggestions for that? A simple photoresistor, or would there be something better (lower current)?
                          NeverDieN 1 Reply Last reply
                          • Nca78N
                            Nca78N
                            Low current light sensor with interrupt, you have OPT3001 and MAX44009. MAX44009 has the lowest power but it doesn't have the same availability (not on Arrows for example).
                            If you're planning to use it from breakout board (as they are boath really tiny) then MAX44009 is the best choice as it's cheaper on AliExpress.
                            If you want one that you can solder by hand you can check VEML7700, it's cheap, has low power consumption (2uA) if you use a low refresh rate. But it goes only down to 2.5V so you will lose a bit of the capacity of the button cell, and it has no interrupt pin.
                            • Nca78N Nca78
                              NeverDieN
                              NeverDieN
                              Done. I just now uploaded Version 5, which has the TI hall effect sensor.
                              • Nca78N Nca78
                                NeverDieN
                                NeverDieN
                                #35
                                Looks as though if I add just one more header pin, then I can use this board:
                                https://www.aliexpress.com/item/MAX44009-Ambient-Light-Sensor-Module-with-4P-Pin-Header-Module/32729312303.html?spm=2114.search0204.3.47.XOZuu8&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10344_10068_10130_10345_10324_10342_10547_10325_10343_10546_10340_10341_10548_10545_10541_10562_10084_10083_10307_10178_10060_10155_5680017_10154_10056_10055_10539_10537_10312_10536_10059_10313_10314_10534_10533_100031_10103_10073_10102_10557_10558_10142_10107-10178,searchweb201603_25,ppcSwitch_4_ppcChannel&btsid=ca20f561-ad43-4536-b09f-7856bf41fbb2&algo_expid=0601cfd8-6d07-4336-aefc-c06bc54166ac-2&algo_pvid=0601cfd8-6d07-4336-aefc-c06bc54166ac
                                That way I could capture the interrupt.
                                • NeverDieN
                                  NeverDieN
                                  OK, I just now uploaded the files for Version 6, which does just that. Unless someone can think of another sensor to add, I think this will be the final version (unless errors are discovered). :)
                                  • G
                                    G
                                    ghiglie
                                    I'm quite a noob, but totally with the NRF. Interesting PCB, I'll try asap to put a sensor together!
                                    atmega328p serial killer
                                    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                                    • NeverDieN
                                      NeverDieN
                                      I made one last change to add water leak detection to it. I just now uploaded the version 7 files. :)
                                      • NeverDieN
                                        NeverDieN
                                        I have the Version 1 design now working with the si7021 breakout board that I got from Aliexpress. Note that if you use these breakout boards, remember to remove the voltage regulator and solder bridge across the two pins as shown in the photo below:
                                        This is because the coin-cell voltage is already in the desired range, and so there's no need for further voltage reduction.
                                        • T
                                          Toyman
                                          Is v7 already for CR2477? BOM still mentions CR2032
