  3. Soft Signing vs. the hardware ATSHA
16 Posts 5 Posters 3.2k Views 5 Watching
  • ThetaDevT
    ThetaDevT
    ThetaDev
    Hi there,
    I have recently studied the MySensors signing library and found it quite interesting. It might be helpful to build a secure, remote controlled garage door opener (the old one suffers from lack of RF range).
    However I dont know if I should buy one of these ATSHA chips or just use the software library.
    As far as I understood, the advantage of the ATSHA is, that it provides a secure vault for the private key, as well as a unique serial number and hardware RNG. Plus all the SHA operations are executed on the chip, so the private key never leaves the ATSHA during operation.
    So if nobody gets access to the MySensor device without breaking into my property, nobody can stole the private key anyway, even if it is stored unencrypted on an AVR EEPROM and could simply be dumped by an attacker. Thus an ATSHA would be pointless, if the device is operated in a safe location, am I right?
    Then lets talk about MySensor nodes that might get stolen, for example a remote control for the above mentioned garage door.
    If an attacker gets one of these nodes with the private key stored inside, he could steal it and create his own signed messages for my network. However, even if this remote would have an ATSHA inside, he could still make use of that chip and sign messages with it
    This could of course be prohibited with node whitelisting, but that would work with the Soft Signing method as well - just remove the serial number of the lost node from the gateway and an attacker cant do anything with the stolen key.
    The only attack I can think of, that can be prohibited by the ATSHA, is the brute-forcing of serial numbers with a known private key. But that would probably take a very long time. Plus if you change both the serial number and private key in your system after a lost device, that wouldnt work, too.
    So my question is whether using an ATSHA chip is worth the effort and really gives you extra security.
    Thanks for your answers
    ThetaDev
    • ThetaDevT ThetaDev
      Hi there,
      ThetaDev
      AnticimexA
      AnticimexA
      Anticimex
      @ThetaDev Hi, you are correct in your assumptions. It basically comes down to where you place your nodes and how much effort it would take to replace the hmac key on your network, if it was compromised.
      As for the future, atsha204 based security will be obsolete in mysensors v3 (unless you plan to keep using atmga328p based devices).
      More powerful chips give us the possibility to use better security schemes.
      NeverDieN 1 Reply Last reply
        Hi there,
        ThetaDev
        AnticimexA
        AnticimexA
        Anticimex
        @ThetaDev also, like you say, you would get a better cryptographic operation using the atsha204a since it handles the mathematics (or most of it).
        • AnticimexA Anticimex
          NeverDieN
          NeverDieN
          @Anticimex said in Soft Signing vs. the hardware ATSHA:
          What mpu's other than the atmega328p does version 3 envision might be used?
          AnticimexA 1 Reply Last reply
          • NeverDieN NeverDie
            AnticimexA
            AnticimexA
            Anticimex
            @NeverDie Not much different than we already support right now. So there are plenty (nrf5, SAMD, ESP, etc).
              NeverDieN
              NeverDieN
              @Anticimex Do you happen to know whether the nrf5 has this sort of capability built into it already? It's already so integrated that it would be great if it did.
                AnticimexA
                AnticimexA
                Anticimex
                @NeverDie What sort of capability?
                We are completely rethinking security for v3, and it will be a cross-device compatible format. However, atmega328p is too resource limited to be able to handle this in a good way, so we will not support that particular chip-set. The legacy signing options will remain for those devices.
                • ThetaDevT
                  ThetaDevT
                  ThetaDev
                  So what would be the microcontroller of choice for MySensors V3?
                  Using an ESP or NRF5 would be useless if you dont need WIFI or bluetooth (which isnt much use for home automation anyway, because bluetooth has a low range and wifi is a power hog).
                  Maybe the new 32bit ARM stuff?
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @ThetaDev There is no recommended one, since it is totally up to you and your specific needs. What we aim for from a security point of view (and this thread is dealing with that, and not general v3 discussions) is a solution that is device independent (to some extent, it does put requirements on memory and performance, hence the support for atmega328p is dropped from this new security feature).
                    It will be HW independent in the sense that it won't support any specific security devices, like the ATSHA. It will be a purely software implemented feature. It may leverage chipset features, such as RNGs or HW accelerated calculators though.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @ThetaDev
                      NRF5 is not only bluetooth.. It can also be used with the "old" nrf24 protocol.
                        And it has 8x ram and 8x flash compared to atmega328
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          And if it is still undesirable there is always the samd which the SenseBender gateway is based on. Then you get the same freedom of choice as with a atmega since the radio is not built in.
                            NeverDieN
                            NeverDieN
                            Actually you still have freedom of choice with the nRF5. You can use its mpu to control other radios, just as you would with an atmega. You could either ignore its existing radio, or you could have a node with two different kinds of radios (i.e. built-in plus add-on). That's the beauty of it. You can learn just one mpu and be done.
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @NeverDie yes of course. Just seem a bit excessive to drag in a complicated chip if you don't intend to use all of it. Especially for battery powered applications.
                              But from a security point of view (again, which is what this thread is all about) it does not matter what chip you stick to. But if you want to use the "next level" security, don't expect it to support atmga328p.
                                NeverDieN
                                NeverDieN
                                @Anticimex So, to sum it up, will the "next level" be doing all the security inside a more more advanced mpu, or do you envision it will still involve the use of external chips, like the ATSHA chip or similar?
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @NeverDie like I said above, it will be a software based solution, without dependencies to external chips. It may still leverage chipset specific features such as RNGs and crypto accelerators.
