  3. GW not working after upgrade 1.x -> 2.1
20 Posts 4 Posters 4.6k Views 4 Watching
  • C
    C
    Cinpou
    wrote on last edited by Cinpou
    Hi!
    I've made a few nodes and a gateway, many years ago.
    Today i would like to add a function to one of the nodes, and upgrade the whole system to the release 2.1.
    Everything seems to work, but i've lost the connexion between the gateway and the Controller (Jeedom and MYScontroller).
    I can see the gateway and the node speaking together.
    I made a serial gateway, and the node appears in MYScontroller, then i think it's not a node's problem.
    I can ping the gateway...
    I can't point the mistake.
    Here is the debug's gateway :
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.xx.19
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=2,t=6,pt=1,l=1,sg=0:0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=4,c=2,t=40,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    Thanks for your suggestions
      Have you tried the latest 2.2 version? You could also try to make an ethernet gateway to see if it makes any changes
      • C
        C
        Cinpou
        Thanks for your reply.
        The release 2.2 is the development branch?
        I will try it.
        My question wasn't clear. I've built an ethernet gw which don't return the information to the controller (MYSc or Jeedom), but the information between the gw and the node appears in the serial console.
        I've built a serial gw, and the node's information works fine with MYS (my Jeedom box can't use serial gw). Then i concluded that's the ethernet gw is the problem, not the controller.
          try development branch first, then we continue from there
          • C
            C
            Cinpou
            Ok, here is the serial monitor from the ethernet gateway with library 2.2
            0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0-rc.1
            3 TSM:INIT
            4 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSM:INIT:GW MODE
            15 TSM:READY:ID=0,PAR=0,DIS=0
            17 MCO:REG:NOT NEEDED
            IP: 192.168.xx.19
            1320 MCO:BGN:STP
            1323 MCO:BGN:INIT OK,TSP=1
            45763 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            45768 TSF:MSG:BC
            45770 TSF:MSG:FPAR REQ,ID=1
            45772 TSF:PNG:SEND,TO=0
            45775 TSF:CKU:OK
            45776 TSF:MSG:GWL OK
            46502 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            47808 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            47813 TSF:MSG:PINGED,ID=1,HP=1
            47817 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            47831 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            47838 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            47845 TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
            47853 TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
            49857 TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=11,sg=0:SmartLighgt
            49866 TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
            49873 TSF:MSG:READ,1-1-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
            49882 TSF:MSG:READ,1-1-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
            49889 TSF:MSG:READ,1-1-0,s=3,c=0,t=23,pt=0,l=0,sg=0:
            49897 TSF:MSG:READ,1-1-0,s=4,c=0,t=26,pt=0,l=0,sg=0:
            49913 TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
            49921 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
            49938 TSF:MSG:READ,1-1-0,s=3,c=2,t=24,pt=0,l=0,sg=0:
            49946 TSF:MSG:READ,1-1-0,s=4,c=2,t=40,pt=0,l=0,sg=0:
            And the log from MYScontroller :
             [2017-11-22 09:57:40.352 Info] INFO	Connected to 192.168.xx.19:5003
             [2017-11-22 09:58:01.379 Info] ERROR	Error on connect: connection refused
            I've tried with and without UDP adress.
            About that, is it necessary for jeedom?
              wrote on last edited by gohan
              It is refusing the connection, did you check if you have a firewall closing ports?
              What parameters did you set in the configure?
              • C
                C
                Cinpou
                I've desactivated the firewall, same results.
                here is the parameters :
                The source code of the ethernet gw :
                 * Version 1.0 - Henrik EKblad
                 * Contribution by Tomas Hozza <thozza@gmail.com>
                 * LED purposes:
                 * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
                //#define MY_RADIO_NRF5_ESB
                //#define MY_RADIO_RFM95
                #define MY_GATEWAY_W5100
                //#define MY_W5100_SPI_EN 4
                // radio on the same spi bus.
                #define MY_SOFTSPI
                #ifndef MY_RF24_CE_PIN
                #define MY_RF24_CE_PIN 5
                #ifndef MY_RF24_CS_PIN
                #define MY_RF24_CS_PIN 6
                // Enable UDP communication
                #define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                #define MY_IP_ADDRESS 192,168,xx,19
                //#define MY_IP_GATEWAY_ADDRESS 192,168,xx,254
                #define MY_PORT 5003
                #define MY_CONTROLLER_IP_ADDRESS 192, 168, xx, 149
                #define MY_MAC_ADDRESS 0xAE, 0xAD, 0xEB, 0xAF, 0xAE, 0xAD
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
                #if defined(MY_USE_UDP)
                #include <EthernetUdp.h>
                #include <Ethernet.h>
                  Are you sure the MY_USE_UDP and my controller ip address are needed?
                  • C
                    C
                    Cinpou
                    not at all, that's why i try with or without these settings
                      These are the only defines I set about the ethernet
                      I am using DHCP reservation on my WiFi router.
                      • dbemowskD
                        dbemowskD
                        Just trying to think outside the box. Did you try to ping the node? If you have access to nmap, scan the node to see if it shows the correct open port on your network. Since you are setting a static IP, you should make sure that the IP is not in your DHCP pool, otherwise it could get pushed to another device to where the two devices could fight on the network. If your router is capable of doing DHCP reservations, it may be better to set a reservation as @gohan did.
                        • C
                          C
                          Cinpou
                          Everything went worse...
                          I've tried to change the W5100 module, the arduino, the radio, erase eeprom, update the soft, change the ethernet calble, nothing...
                          In the monitor, i see the ip displaying random value, actually 255.255.255.255.
                          I tried DHCP, it can't obtain an IP.
                          Before things get worst, i've pinged the gateway successfully. And it obtained an IP in DHCP.
                          I've lost the day on it... Will try tomorrow from the beginning...
                          I check the router, i can't se
                            what ide version are you using? and what boards definitions are you using?
                            • C
                              C
                              Cinpou
                              Once it randomly turn on an ip compatible with my network. I can connect with MYScontroller, and view the node.But the information returned has a bad encoding. Part of the message contained strange characters.
                              The DHCP mode can't take an ip from the server. In my router, i've found a trace of the gw. The name of the node contains also invalid characters.
                              I've install ubuntu on an other computer to test the environnement.
                              Same results. The arduino return a random ip.
                              I've tested with 1.6.7 and 1.8.5 IDE.
                              What do you mean by board definition? I've tested with a nano 32, a uno and a mega.
                              On both ubuntu and windows, i've an error in the console while transmitting the code to the board : "ATTENTION : Faux .mystools dossier dans la bibliothèque 'MySensors'" (Bad .mystools directory in the library MySensors)
                                In Arduino ide, look in board manager and check what is the version of the arduino board version you are using.
                                The warning you get is not an issue, I have it too, just ignore it.
                                • C
                                  C
                                  Cinpou
                                  Arduino AVR release 1.6.20, is it what you mean?
                                    Try installing the 1.6.11 or 1.6.13
                                    • C
                                      C
                                      Cinpou
                                      nope... i've tested 1.6.11 .13 and .2
                                      thanks for your help. Do you have another idea?
                                        I'm running out of options...
                                        • bisschopsrB
                                          bisschopsrB
                                          bisschopsr
                                          Hi all,
                                          I. m facing similar problems. like you. I was working on upgrading my network to 2.1.1. I got stuck with strange behaviour of the GW. I programmed it with:
                                          IDE version: 1.8.4
                                          Arduino AVR release: 1.6.20
                                          The latest 2.1.1 downloaded libraries and the latest GW version.
                                          After connecting the GW to my network, i was perfectly able to ping it. MYScontroller could connect, however sending a command to the gateway rusults in an error (ERROR 10054).
                                          I've been fighting with it for a day, exchanging compontents, rebuilding SW, etc.
                                          Here is what solved it!
                                          Changed the AVR release to 1.6.11
                                          I know there are problems in AVR 1.6.X, but these should have been solved in 1.6.18 and higher. Apperantly that is not the case.
                                          I hope this helps!
                                          Ralph
                                          Domoticz, P1 meter interface, MySensors and more to come!
