  3. ESP8266 gateway crashes while the node is in FOTA progress.
rfm69otamqttesp8266
6 Posts 2 Posters 3.1k Views 2 Watching
  • A
    A
    Abdu Sahin
    wrote on last edited by Abdu Sahin
    Hi there,
    I recently started using the library and i wanted to use firmware OTA feature. However I'm getting error at gateway whenever the node requests firmware OTA update. I can see from gateway logs firmware OTA is initiated and data is exchanged between the gateway and node, but unfortunatelly the gateway crashes every time and resets. I appreciate any help as I have spent many hours but couldn't find a solution yet.
    Setup:
    Gateway : Wemos D1 Mini + RFM69
    Node : ButtonSize Node (a custom Arduino Pro mini + RFM69 + Flash + Dualboot)
    Controller: MyController
    Transport: MQTT
    Power : Through USB port from the computer for both gateway and node
    ets Jan 8 2013,rst cause:4, boot mode:(3,6)
    wdt reset
    4_1511569006091_stacktrace.txt
    3_1511569006091_gw-log.txt
    2_1511569006090_node-log.txt
    1_1511569006090_gw.ino
    0_1511569006090_node.ino
    0_1511567682094_dump.txt
      It seems a watchdog reset. Try increase the timer before the watchdog resets the chip
      A 1 Reply Last reply
        A
        A
        Abdu Sahin
        @gohan thanks for the suggestion. Would you mind giving a code example please. I don't; know much about the esp8266 :(
          I don't know much about the esp8266 watchdog too... Sorry
            A
            A
            Abdu Sahin
            @gohan I've added ESP.wdtFeed() and tried with another memos d1 mini + rfm69, but it didn't help, still getting ets Jan 8 2013,rst cause:4, boot mode:(3,6) message.
            @yury / @Koresh do you have any idea about it ?
            • A
              A
              Abdu Sahin
              After upgrading Wemos from 2.3.0 to 2.4.0-RC2 version, OTA works well know :smiley:
