  3. Repeater Node - Must Sensors use ACK to detect "3 failed" messages?
3 Posts 2 Posters 1.1k Views 2 Watching
  • S Offline
    Spanners
    wrote on last edited by Spanners
    I have a clarification question on this text in "The Sensor Network".
    If the sensor node later loses contact with the gateway or a repeater-sensor node, it will automatically repeat this procedure to determine the best path to the gateway - a sensor node considers contact with the gateway to be lost if it fails to send 3 consecutive messages.
    For messages to be detected as failed (and therefore the sensor tries to find a new gateway/repeater) must messages be sent with ACK requested as true?
    eg: send(msg1valve.setSensor(i).set(true), true);
    This question is for NRF24 radio in case that's significant.
    • S Spanners
      @Spanners no, there is no need to request ack.
      S 1 Reply Last reply
        Spanners
        Thanks @mfalkvidd
        Unfortunately that ruins my theory as to what I’m observing. I will keep experimenting.
