  3. Sensor on gateway
Sensor on gateway
3 Posts 3 Posters 2.0k Views 1 Watching
  • D
    D
    dareks79
    Is it possible to add some sensors (for example: DS18B20) physically to gateway?
    I am using Pidome as a controller and I am able to pass the data from other NRF24 connected with arduino through gateway(with standard sketch), however I do not know how to send the data stored locally form sensors on the gateway and pass it to controller.
    Best regards
    Darek
    • daulagariD
      daulagariD
      daulagari
      It should be possible to connect sensors to the gateway and pass it to the controller but I have not seen anybody doing it so probably you will have to write/merge the code yourself.
      • O
        O
        olaeke
        wrote on last edited by olaeke
        You have to rewrite part of MyGateWay.cpp or create your own class. It is not that easy that it looks like at first glance. I did it but it didn't end up in that good functionality so I skipped it and made a separte sensor and keept the Gateway unchanged.
        You have another answer in the same direction here: http://forum.mysensors.org/topic/722/is-it-possible-to-have-an-ethernet-gateway-also-act-as-a-node-single-arduino-setup/4
