  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • A allysmith
    I have followed the procedure listed and that mentioned in post 77. Pro Mini 3.3v 8mhz Arduino.
    I keep getting the following message in the debug window every few minutes. Have repeated the process in post 77 several times however get the same results.
    [2015-09-01 18:09:17.276 Info] DEBUG Undefined firmware/type for node=2
    [2015-09-01 18:09:17.323 Info] INFO BL version=257
    [2015-09-01 18:09:17.354 Info] INFO Send FW info to node 2: type=A, version=1, blocks=0x0048, CRC=0xD098
    [2015-09-01 18:09:17.386 Info] TX 2;0;4;0;1;0A000100480098D0
    [2015-09-01 18:09:17.417 Info] RX 2;255;4;0;0;FFFFFFFFFFFFFFFF0101
    Any pointers??
    tekkaT
    tekkaT
    tekka
    @allysmith please provide more information about the setup and upload the MYSController log for further troubleshooting
    A 1 Reply Last reply
    • E
      E
      ericvdb
      @tekka What kind of SPI flash is needed for this OTA stuff? Can you provide part numbers?
      tekkaT 1 Reply Last reply
      • E ericvdb
        tekkaT
        tekkaT
        tekka
        @ericvdb MYSBootloader works without external flash, in contrary to the sensebender board and dualoptiboot bootloader
        • tekkaT tekka
          A
          A
          allysmith
          @tekka Thanks for getting back to me. This is my my first go at this bootloader. Hope I am not doing something daft!
          I have Arduino IDE 1.6.5, MySensors 1.5, MYSBootloader 1.1, MYSController_0_1_2_282 running on Windows 8, USBasp to urn bootloader.
          Arduino Pro Mini 3.3v 8mhz board. I am using the standard settings in your write up for the boards.txt
          Log file hopefully attached.
          MySensors_20150901-185920.log
          • A allysmith
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            #225
            @allysmith Try clearing EEPROM via MYSBootloader command, assign blink FW and upload the entire log again....
            • tekkaT tekka
              A
              A
              allysmith
              @tekka As requested, cleared EEPROM via MYSBootloader, assigned blink FW.
              Attached is the log.
              Device shows up in the nodes window as Booting: 65535:65535 (BL1.1)
              MySensors_20150902-055736.log
              • A allysmith
                A
                A
                allysmith
                @tekka Have made a change to how I was powering the NRF and now straight from battery.
                Looks like it was a power issue. Sufficient for transmit from the node ut not for receiving the updates.
                See attached log.
                Now got a different issue when I tried to reassign the FW from link to Timereporter.
                I think I am moving in the right direction now.
                Thanks for your help so far.
                Keep up this great work.Deug.txt
                • E
                  E
                  ericvdb
                  wrote on last edited by ericvdb
                  #228
                  WOOOHOOO, i got OTA working :dancers:
                  This is awesome guys
                  BTW, I guess OTA will not work if there's a repeater in the middle?
                  • E ericvdb
                    tekkaT
                    tekkaT
                    tekka
                    congrats! :)
                    OTA updates will also work with repeating nodes in between...
                    • E
                      E
                      ericvdb
                      @tekka i guess OTA is not available when using a MQTT gateway?
                      I would like to switch my whole setup to MQTT, but don't wanna loose the super fantastic OTA feature.
                      • E ericvdb
                        tekkaT
                        tekkaT
                        tekka
                        @ericvdb in theory possible, but AFAIK not supported by any controller...at the moment :)
                        • E
                          E
                          ericvdb
                          @tekka would you mind describing in detail the process (on the controller side) how the OTA works?
                          • C
                            C
                            cdr
                            Can somebody explain to me how the "Reassing ID" function works in MYScontroller? I haven't been able to change a ID remotely.
                            ID's keep the same after reboots or power cycles, with or without the AutoID option on.
                            SparkmanS tekkaT 2 Replies Last reply
                            • C cdr
                              SparkmanS
                              SparkmanS
                              Sparkman
                              @cdr IDs are assigned the first time the node starts up and then stored in the Arduino EEPROM. To get a new ID, you would have to clear (that portion of) the EEPROM, or you can upload a copy of the sketch with the ID hard-coded.
                              Cheers
                              Al
                              • F
                                F
                                Fabien
                                It's possible to reassign ID if you use MYSBootloader.
                                • C
                                  C
                                  cdr
                                  I use MYSbootloader, but can neither get "reassign ID", nor "clear eeprom" functions to work.
                                  I guess I could make a cleareeprom hex, but that feels like a workaround.
                                  • F
                                    F
                                    Fabien
                                    I just try (never before) and it doens't work for me too.
                                      mvader
                                      wrote on last edited by mvader
                                      #238
                                      quite a few post. so apologies if this has been asked before.
                                      I'm trying to upload a sketch(hex) to one of my nano's
                                      it's going but froze at 70%
                                      i had to reboot the gateway.
                                      this time it got to 87% and seems froze again.
                                      any thoughts/suggestions on why the gateway is freezing up?
                                      edit: i can't seem to get a sketch to upload. it gets to some random % and then the gateway freezes.
                                      a push of the gateway reset button seems to start it over. but then freezes at random.
                                      edit 2: must have been a distance thing.. i put the bridge right next to the gateway and the code uploaded quickly without freezing.
                                      however, i still am curious as to why the gateway fails to respond/freezes if the firmware is not able to be uploaded.
                                      M 1 Reply Last reply
                                      • C cdr
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #239
                                        Reassign ID & clear EEPROM are commands implemented in MYSBootloader 1.1: A special ST_FIRMWARE_CONFIG_RESPONSE sequence (see the source code for detail) will instruct the bootloader to either change the ID in EEPROM or clear the EEPROM. The reassign ID command will only have effect, if the firmware has does not have static a ID setting. In order to use the bootloader commands the controller should be able to reboot the node.
                                        • C
                                          C
                                          cdr
                                          Hi @tekka,
                                          Thanks for the reply, I created a "clear eeprom" hex and after uploading it is working as expected, the ID resets.
                                          Using the function in Mycontroller however, does not work. Not sure if this is a bug, or perhaps an error caused by an Arduino clone, but the "reassign ID" function is not working as intended here.
                                          Anyone here that got it working as intended?
