  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
  • A allysmith
    @tekka As requested, cleared EEPROM via MYSBootloader, assigned blink FW.
    Attached is the log.
    Device shows up in the nodes window as Booting: 65535:65535 (BL1.1)
    MySensors_20150902-055736.log
    allysmith
    @tekka Have made a change to how I was powering the NRF and now straight from battery.
    Looks like it was a power issue. Sufficient for transmit from the node ut not for receiving the updates.
    See attached log.
    Now got a different issue when I tried to reassign the FW from link to Timereporter.
    I think I am moving in the right direction now.
    Thanks for your help so far.
    Keep up this great work.Deug.txt
    • E
      E
      ericvdb
      wrote on last edited by ericvdb
      #228
      WOOOHOOO, i got OTA working :dancers:
      This is awesome guys
      BTW, I guess OTA will not work if there's a repeater in the middle?
      tekkaT 1 Reply Last reply
      • E ericvdb
        tekkaT
        tekkaT
        tekka
        congrats! :)
        OTA updates will also work with repeating nodes in between...
        • E
          E
          ericvdb
          @tekka i guess OTA is not available when using a MQTT gateway?
          I would like to switch my whole setup to MQTT, but don't wanna loose the super fantastic OTA feature.
          • E ericvdb
            tekkaT
            tekkaT
            tekka
            @ericvdb in theory possible, but AFAIK not supported by any controller...at the moment :)
            • E
              E
              ericvdb
              @tekka would you mind describing in detail the process (on the controller side) how the OTA works?
              • C
                C
                cdr
                Can somebody explain to me how the "Reassing ID" function works in MYScontroller? I haven't been able to change a ID remotely.
                ID's keep the same after reboots or power cycles, with or without the AutoID option on.
                SparkmanS tekkaT 2 Replies Last reply
                • C cdr
                  SparkmanS
                  SparkmanS
                  Sparkman
                  @cdr IDs are assigned the first time the node starts up and then stored in the Arduino EEPROM. To get a new ID, you would have to clear (that portion of) the EEPROM, or you can upload a copy of the sketch with the ID hard-coded.
                  Al
                  • F
                    F
                    Fabien
                    It's possible to reassign ID if you use MYSBootloader.
                    • C
                      C
                      cdr
                      I use MYSbootloader, but can neither get "reassign ID", nor "clear eeprom" functions to work.
                      I guess I could make a cleareeprom hex, but that feels like a workaround.
                      • F
                        F
                        Fabien
                        I just try (never before) and it doens't work for me too.
                          mvader
                          wrote on last edited by mvader
                          #238
                          quite a few post. so apologies if this has been asked before.
                          I'm trying to upload a sketch(hex) to one of my nano's
                          it's going but froze at 70%
                          i had to reboot the gateway.
                          this time it got to 87% and seems froze again.
                          any thoughts/suggestions on why the gateway is freezing up?
                          edit: i can't seem to get a sketch to upload. it gets to some random % and then the gateway freezes.
                          a push of the gateway reset button seems to start it over. but then freezes at random.
                          edit 2: must have been a distance thing.. i put the bridge right next to the gateway and the code uploaded quickly without freezing.
                          however, i still am curious as to why the gateway fails to respond/freezes if the firmware is not able to be uploaded.
                          • C cdr
                            tekkaT
                            tekkaT
                            tekka
                            wrote on last edited by tekka
                            #239
                            Reassign ID & clear EEPROM are commands implemented in MYSBootloader 1.1: A special ST_FIRMWARE_CONFIG_RESPONSE sequence (see the source code for detail) will instruct the bootloader to either change the ID in EEPROM or clear the EEPROM. The reassign ID command will only have effect, if the firmware has does not have static a ID setting. In order to use the bootloader commands the controller should be able to reboot the node.
                            • C
                              C
                              cdr
                              Hi @tekka,
                              Thanks for the reply, I created a "clear eeprom" hex and after uploading it is working as expected, the ID resets.
                              Using the function in Mycontroller however, does not work. Not sure if this is a bug, or perhaps an error caused by an Arduino clone, but the "reassign ID" function is not working as intended here.
                              Anyone here that got it working as intended?
                              • C cdr
                                Hi @tekka,
                                tekkaT
                                tekkaT
                                tekka
                                @cdr please post the MYScontroller log to figure out what's going on. Thanks
                                • F
                                  F
                                  Fabien
                                  wrote on last edited by Fabien
                                  #242
                                  @Tekka Same "bug" here" with MYSBootloader 1.1 (hex from github) on arduino nano. Try to change ID of node N°1, Log :
                                   [2015-09-21 21:52:57.053 Info] INFO	*** Logging START ***
                                   [2015-09-21 21:52:57.053 Info] VERSION	MYSController 0.1.2.282
                                   [2015-09-21 21:52:57.053 Info] STARTUP	INI file loaded
                                   [2015-09-21 21:52:57.053 Info] STARTUP	Loading FW repository...
                                   [2015-09-21 21:52:57.054 Info] REPO	FW "Blink" loaded. t=10, v=1, blocks=72, crc=0xD098
                                   [2015-09-21 21:52:57.064 Info] REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
                                   [2015-09-21 21:52:57.076 Info] REPO	FW "Motion" loaded. t=30, v=1, blocks=1024, crc=0xD1BF
                                   [2015-09-21 21:52:57.092 Info] REPO	FW "Sensebender Micro" loaded. t=100, v=1, blocks=1344, crc=0x3482
                                   [2015-09-21 21:52:57.108 Info] REPO	FW "Sensebender Blink" loaded. t=110, v=1, blocks=768, crc=0x1314
                                   [2015-09-21 21:52:57.108 Info] REPO	FW repository loaded. Items=5
                                   [2015-09-21 21:52:57.111 Info] STARTUP	Initialize message types
                                   [2015-09-21 21:52:57.111 Info] NODE	New node discovered, node id=0
                                   [2015-09-21 21:52:57.111 Info] NODE	New node discovered, node id=255
                                   [2015-09-21 21:52:59.606 Info] INFO	Connected to 192.168.1.90:5003
                                   [2015-09-21 21:53:04.373 Info] NODE	New node discovered, node id=1
                                   [2015-09-21 21:53:04.376 Info] CHILD	New child discovered, node id=1, child id=internal
                                   [2015-09-21 21:53:04.379 Info] INFO	BL version=257
                                   [2015-09-21 21:53:04.380 Info] INFO	No FW assigned
                                   [2015-09-21 21:53:04.383 Info] RX	1;255;4;0;0;1E0001000004BFD10101
                                   [2015-09-21 21:53:04.681 Info] NODE	New node discovered, node id=4
                                   [2015-09-21 21:53:04.685 Info] CHILD	New child discovered, node id=4, child id=1
                                   [2015-09-21 21:53:04.688 Info] RX	4;1;1;0;0;21.6
                                   [2015-09-21 21:53:04.691 Info] CHILD	New child discovered, node id=4, child id=2
                                   [2015-09-21 21:53:04.694 Info] RX	4;2;1;0;1;71
                                   [2015-09-21 21:53:06.421 Info] INFO	BL version=257
                                   [2015-09-21 21:53:06.424 Info] INFO	No FW assigned
                                   [2015-09-21 21:53:06.427 Info] RX	1;255;4;0;0;1E0001000004BFD10101
                                   [2015-09-21 21:53:08.470 Info] INFO	BL version=257
                                   [2015-09-21 21:53:08.472 Info] INFO	No FW assigned
                                   [2015-09-21 21:53:08.476 Info] RX	1;255;4;0;0;1E0001000004BFD10101
                                   [2015-09-21 21:53:14.903 Info] UPDATE	4295098650
                                   [2015-09-21 21:53:14.906 Info] INFO	BL version=257
                                   [2015-09-21 21:53:14.909 Info] INFO	No FW assigned
                                   [2015-09-21 21:53:14.913 Info] RX	1;255;4;0;0;1E0001000004BFD10101
                                   [2015-09-21 21:53:14.916 Info] INFO	BL version=257
                                   [2015-09-21 21:53:14.918 Info] INFO	No FW assigned
                                   [2015-09-21 21:53:14.922 Info] RX	1;255;4;0;0;1E0001000004BFD10101
                                   [2015-09-21 21:53:14.925 Info] DEBUG	Update child id=255, type=ARDUINO_NODE
                                   [2015-09-21 21:53:14.929 Info] RX	1;255;0;0;17;1.5
                                   [2015-09-21 21:53:14.933 Info] TX	1;255;3;0;6;M
                                   [2015-09-21 21:53:14.937 Info] RX	1;255;3;0;6;0
                                   [2015-09-21 21:53:14.945 Info] CHILD	New child discovered, node id=0, child id=0
                                   [2015-09-21 21:53:14.950 Info] RX	0;0;3;0;14;Gateway startup complete.
                                   [2015-09-21 21:53:16.680 Info] RX	1;255;3;0;11;Motion Sensor
                                   [2015-09-21 21:53:16.691 Info] RX	1;255;3;0;12;1.0
                                   [2015-09-21 21:53:16.695 Info] CHILD	New child discovered, node id=1, child id=1
                                   [2015-09-21 21:53:16.701 Info] DEBUG	Update child id=1, type=MOTION
                                   [2015-09-21 21:53:16.714 Info] RX	1;1;0;0;1;
                                   [2015-09-21 21:53:16.718 Info] RX	1;1;1;0;16;0
                                   [2015-09-21 21:53:38.779 Info] INFO	Node trigger set, node=1, trigger=1
                                   [2015-09-21 21:53:39.793 Info] INFO	Retained message triggered for release, node=1
                                   [2015-09-21 21:53:39.796 Info] CHILD	New child discovered, node id=1, child id=1
                                   [2015-09-21 21:53:39.800 Info] TX	1;0;3;0;13;0
                                   [2015-09-21 21:53:39.805 Info] RX	1;1;1;0;16;1
                                   [2015-09-21 21:53:39.808 Info] CHILD	New child discovered, node id=1, child id=internal
                                   [2015-09-21 21:53:39.811 Info] DEBUG	Update child id=255, type=ARDUINO_NODE
                                   [2015-09-21 21:53:39.815 Info] RX	1;255;0;0;17;1.5
                                   [2015-09-21 21:53:56.729 Info] INFO	Disconnected
                                   [2015-09-21 21:53:58.924 Info] INFO	*** Logging STOP ***```
                                  • F Fabien
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Fabien I have an idea what is going wrong here: To confirm please enable DEBUG in the gateway and kindly re-post the full log again. The issue is related to signing...
                                    • F
                                      F
                                      Fabien
                                      @tekka, I can't enable debug if I'm right. Not enouch space for the sketch.
                                      • F Fabien
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #245
                                        Issue is signing-related and fixed in the new version. MYSBootloader 1.5. release pending. Thanks to @Fabien for testing.
                                        • J
                                          J
                                          jkandasa
                                          @tekka Is it possible to upgrade MYSbootloader from 1.1 to 1.5 via OTA?
