  3. Solar Powered Mini-Weather Station
111 Posts 39 Posters 152.0k Views 27 Watching
  • E Elfnoir
    @Renard : Bonjour! Je fais le raccordement cette semaine j'espère, je galère sur la déclaration dans Domoticz et l'étalonnage pour controler la charge de la batterie, mais je dirais:
    • OUT+ et - sur RAW et GND de l'Arduino
    • B+ B- à la batterie
    • "+ et -" au panneau solaire, c'est ce qu'il me semble sur les photos.
    @bisschopsr : Hi, There is no charge controler 5 or 12 volts. On my Fritzing to understand better the scheme (Post #70), I draw batteries and solar panel, but Fritzings following are with 12volts charger, I don't know why. If you purchased a solar lamp, it's to avoid 5 or 12volts charger and use the sun ;-)
    bisschopsrB
    bisschopsrB
    bisschopsr
    Thanks for the anwer @Elfnoir. I looked back at your schedule and there is some logic between the solar panel, the batteries and the other components (as the power consumers). That logic in the middle is what I refered to as charge controller. I would like to know what part this is.
    Thanks again.
    Ralph
    Domoticz, P1 meter interface, MySensors and more to come!
    • E
      E
      Elfnoir
      @Renard c'est bien l'arduino qui gère la décharge et envoi l'info à Domoticz; c'est pour cela que tu dois étalonner le min/max avec le potentiomètre
      it is the Arduino which manages the discharge and send the info to Domoticz ; that's why you have to calibrate the min / max with the potentiometer
      @bisschopsr If I well understand your question, the module which take the solar power to charge the battery with providing in the same time power to the arduino, and provide power of the battery to the arduino when there is no sun or at night: it's the Lipo Ride. There is no monitoring from the Arduino to the Lipo, but the Arduino read the level of voltage coming from the battery and send it to Domoticz.
      Do I understand well your question please?
      bisschopsrB 1 Reply Last reply
      • E Elfnoir
        bisschopsrB
        bisschopsrB
        bisschopsr
        @Elfnoir You understood the question correct :). That was the answer I was looking for. So your battery is something like a 3.7V LiOn?
        Thanks again
        Ralph
        E 1 Reply Last reply
        • bisschopsrB bisschopsr
          Thanks again
          Ralph
          E
          E
          Elfnoir
          @bisschopsr yes, the battery inside the “16 LED Solar Power Motion Sensor Security Lamp Outdoor Waterproof Light” (http://www.ebay.com/itm/271693521438) is 3.7v 800mAh.
          • E Elfnoir
            bisschopsrB
            bisschopsrB
            bisschopsr
            @Elfnoir Thank you very much. I found a local LED lamp with 3.6V 600mAh NiMh battery. I'm going to try and make a simular solution from that one.
            • PetjepetP
              PetjepetP
              Petjepet
              @Salmoides I built this weather station (exactly as decribed above in the initial message) and have some problems with the radio when going about 15 meters from the gateway.
              I have several other nodes on similar distance working just fine.
              I guess the metal top of the case (where the solar panel is in) is causing the issue. Is there a way to change that? Maybe an additional antenna wire (how)?
              • PetjepetP Petjepet
                bisschopsrB
                bisschopsrB
                bisschopsr
                @Petjepet The metal is definitely influencing the radio performance. It’s 2.4 GHz like the home wifi signal, so you might understand the impact if you compare these two. A solution to use a radio with an external antenna that can be placed outside the metal case. There is a radio with ext. antenna available, you might need an additional extension cable of say 15-30 cm. Does this help.
                Regards,
                Ralph
                • PetjepetP
                  PetjepetP
                  Petjepet
                  @bisschopsr That must be the same one I use for the gateway with the external antenna.
                  I also saw once a wire connected to the standard radio but can't recall where I saw that.
                    bisschopsrB
                    bisschopsrB
                    bisschopsr
                    @Petjepet Yes, you are probably using this version for the GW (I know I am :-)). I have also see people hacking the original module by attaching a wire antenna instead of the on board printed antenna. The advantage of the other antenna based board is, you can actually bring the antenna to the outside. Something more difficult to do with a wire hack.
                    • mrc-coreM
                      mrc-coreM
                      mrc-core
                      I have been adapting this mini-weather station code to he API 2.0 and add it the battery sensor. Here's my first attemp
                      #define MY_NODE_ID 2
                      #define MY_PARENT_NODE_ID  0
                      #include <DHT.h>
                      #include <BH1750.h>
                      #include <Wire.h>
                      #include <Adafruit_BMP085.h>
                      #define round(x) ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 1
                      #define CHILD_ID_LIGHT 2
                      #define CHILD_ID_BARO 3
                      #define CHILD_ID_BTEMP 4
                      #define CHILD_ID_WINDSPEED 5
                      #define CHILD_ID_BATTERY 6
                      #define MESSAGEWAIT 500
                      #define DHT_DATA_PIN 3          // Pin 3 digital = DHT11 or DHT12
                      #define windSpeedPin 4          // Pin 4 digital = Anenometer
                      #define SENSOR_TEMP_OFFSET 0
                      #define STABILIZATION_TIME 500  // Let the sensor stabilize 0.5 seconds before reading
                      #define BATTERY_FULL 7400 // 3,000 millivolts when battery is full (assuming 2xAA)
                      #define BATTERY_ZERO 2800 // 1,700 millivolts when battery is empty (reqires blown brownout detection fuse, use 2,800 otherwise)
                      const float ALTITUDE = 162; // <-- adapt this value to your own location's altitude.
                      int windSpeedPinCounter = 0;        // impuls counter
                      int windSpeedPinStatus = 0;         // actual impuls
                      int windSpeedPinStatusAlt = 0;      // oude Impuls-Status
                      unsigned long windmeterStart;
                      unsigned long windmeterStartAlt = 0;
                      int windSpeed;                      // Variable voor Wind Speed
                      int beaufort = 0;                   // Variable Wind in Beaufort
                      const int windmeterTime = 10000;
                      //float knoten = 0.0;
                      //float wind = 0.0;
                      unsigned int knoten;
                      unsigned int wind;
                      long oldvoltage = 0;
                      bool metric = true;
                      float lastBmpTemp;
                      float lastPressure;
                      float lastHum;
                      float lastTemp;
                      uint8_t nNoUpdatesTemp;
                      uint8_t nNoUpdatesHum;
                      int updateAll = 60;
                      int updateCount = 0;
                      uint16_t lastLux;
                      unsigned long SLEEP_TIME = 60000;
                      Adafruit_BMP085 bmp = Adafruit_BMP085();
                      BH1750 lightSensor;
                      DHT dht;
                      MyMessage voltage_msg(CHILD_ID_BATTERY, V_VOLTAGE);
                      MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                      MyMessage msgBtemp(CHILD_ID_BTEMP, V_TEMP);
                      MyMessage msgPressure(CHILD_ID_BARO, V_PRESSURE);
                      MyMessage msgWindSpeed(CHILD_ID_WINDSPEED, V_WIND);
                      MyMessage msgWGust(CHILD_ID_WINDSPEED, V_GUST);
                      MyMessage msgWDirection(CHILD_ID_WINDSPEED, V_DIRECTION);
                        analogReference(INTERNAL);
                        if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod())
                        if (!bmp.begin())
                          Serial.println("Could not find a valid BMP085 sensor, check wiring!");
                          while (1) {}
                        metric = getConfig().isMetric;
                        lightSensor.begin();
                        sendSketchInfo("Weather Sensor", "4.1.C");
                        present(CHILD_ID_HUM, S_HUM, "WS Humidity");
                      //  present(CHILD_ID_TEMP, S_TEMP, "WS Temperature");
                        present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "WS Lux");
                        present(CHILD_ID_BARO, S_BARO, "WS Pressure");
                        present(CHILD_ID_BTEMP, S_TEMP, "WS P Temperature");
                        present(CHILD_ID_WINDSPEED, S_WIND, "WS Windspeed");
                        present(CHILD_ID_BATTERY, S_CUSTOM, "WS Battery");
                      // Wind Meter https://github.com/chiemseesurfer/arduinoWeatherstation/blob/master/weatherstation/weatherstation.ino
                      float windmeter()
                        windmeterStart = millis(); // Actual start time measuringMessung
                        windmeterStartAlt = windmeterStart; // Save start time
                        windSpeedPinCounter = 0; // Set pulse counter to 0
                        windSpeedPinStatusAlt = HIGH; // Set puls status High
                        while ((windmeterStart - windmeterStartAlt) <= windmeterTime) // until 10000 ms (10 Seconds) ..
                          windSpeedPinStatus = digitalRead(windSpeedPin); // Read input pin 2
                          if (windSpeedPinStatus != windSpeedPinStatusAlt) // When the pin status changed
                            if (windSpeedPinStatus == HIGH) // When status - HIGH
                              windSpeedPinCounter++; // Counter + 1
                           windSpeedPinStatusAlt = windSpeedPinStatus; // Save status for next loop
                           windmeterStart = millis(); // Actual time
                         windSpeed =  ((windSpeedPinCounter * 24) / 10) + 0.5; //  WindSpeed - one Pulse ~ 2,4 km/h,
                         windSpeed = (windSpeed / (windmeterTime / 1000)); // Devided in measure time in seconds
                         Serial.print("wind Speed : ");
                         Serial.println(windSpeed);
                         knoten = windSpeed / 1.852; //knot's
                         return windSpeed;
                        updateCount += 1;
                        if (updateCount == updateAll)
                          lastTemp = -1;
                          lastHum = -1;
                          lastLux = -1;
                          lastBmpTemp = -1;
                          lastPressure = -1;
                          updateCount = 0;
                         long voltage = readVcc();
                         if (oldvoltage != voltage) { // Only send battery information if voltage has changed, to conserve battery.
                            send(voltage_msg.set(voltage / 1000.0, 3)); // redVcc returns millivolts and set wants volts and how many decimals (3 in our case)
                            sendBatteryLevel(round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO)));
                            oldvoltage = voltage;
                         delay(2000);
                         dht.readSensor(true);
                         if (isnan(temperature))
                         else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
                          lastTemp = temperature;
                          if (!metric)
                          // Reset no updates counter
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          Serial.print("T: ");
                          Serial.println(temperature);
                          else
                            nNoUpdatesTemp++;
                          if (isnan(humidity))
                          else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          Serial.print("H: ");
                          Serial.println(humidity);
                          else
                            nNoUpdatesHum++;
                          uint16_t lux = lightSensor.readLightLevel();
                          if (lux != lastLux)
                            send(msgLux.set(lux));
                            lastLux = lux;
                          float pressure = bmp.readSealevelPressure(ALTITUDE) * 0.01;
                          float bmptemp = bmp.readTemperature();
                          if (!metric)
                            bmptemp = bmptemp * 1.8 + 32.0;
                          if (bmptemp != lastBmpTemp)
                            send(msgBtemp.set(bmptemp,1));
                            lastBmpTemp = bmptemp;
                          if (pressure != lastPressure)
                            send(msgPressure.set(pressure, 0));
                            lastPressure = pressure;
                          wind = windmeter();
                          Serial.print("Wind : ");
                          Serial.println(wind);
                          int wdirection = 1;
                          int wgust = 1;
                          send(msgWindSpeed.set(wind, 1));
                          send(msgWGust.set(wgust, 1));
                          send(msgWDirection.set(wdirection, 1));
                          sleep(SLEEP_TIME);
                      void incomingMessage(const MyMessage & message)
                        if (message.isAck())
                      long readVcc()
                        // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                      #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                        ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
                      #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                        ADMUX = _BV(MUX5) | _BV(MUX0);
                      #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                        ADMUX = _BV(MUX3) | _BV(MUX2);
                      #else
                        while (bit_is_set(ADCSRA, ADSC)); // measuring
                        long result = (high << 8) | low;
                      It a little big but does what i need and the best thing it's that the anenometer works :+1:
                      • ร
                        ร
                        รอเรือ
                        wrote on last edited by รอเรือ
                        #111
                        My experience with using a "Micro USB 5V 1A 18650 Lithium Battery Charger Board With Protection Module" together with the "16 LED Solar Power Motion Sensor Security Lamp Outdoor Waterproof Light"s solar panel is that it's not charging the battery as well as the original built in PCB. Due to the varying voltage (up to 6V) of the solar panel it's not so well suited as a power source for "Micro USB 5V 1A 18650 Lithium Battery Charger Board With Protection Module". I experimented with diodes in serial (2 diodes gave best result) to lower the voltage. However using the original board allowed the battery to charge with a much higher current. I just cut of the motion sensor, and the power switch. It seems to work well. It's even charging a few mA now here when it's raining. My conclusion is that the "Micro USB 5V 1A 18650 Lithium Battery Charger Board With Protection Module" might be used but the original PCB makes a better job charging the battery.
                        Cheers!
