  3. Solar Powered Mini-Weather Station
111 Posts 39 Posters 152.0k Views 27 Watching
  • soifS
    soifS
    soif
    wrote on last edited by soif
    #61
    @Yveaux thank you for the amazing fast and really helpful answer.
    Droping the voltage by 0.7v would certainly change the charger beahaviour to behave properly, and not be in "protection mode", Definitively better than inserting a stepDown module.
    I assume that I put the diode in serie from the VCC+ out of the Solar panel TO the VCC+ IN of the charger (right?), ie:
    Solar VCC out ------ --->| ---- Charger VCC in.
    3 questions:
    • Is there any diode reference recommendation, or any value do the job (1N400x) ?
    • Will the diode "eat" some current, ot just drop the voltage -0,7v. ?
    • BTW what is a "Silicon" diode?
    thank you very much for your valuable support !
    Berst regards,
    YveauxY 1 Reply Last reply
    • soifS soif
      3 questions:
      Berst regards,
      YveauxY
      YveauxY
      @soif Your connection idea is correct. If you mount it in reverse, it simply won't work.
      The actual voltage drop over the diode will depend on the amount of current flowing through it, so that's why you might require 2 in series.
      An 1N400x will do just fine. The higher the x, the more current it can handle.
      The diode will consume some current, but that will be less then a step-down converter.
      Most diodes nowadays use silicon as semiconductor. Years ago Germanium diodes were used, which have a lower voltage drop.
      As a reference: everything you need to know about diodes
      soifS 1 Reply Last reply
      • YveauxY Yveaux
        soifS
        soifS
        soif
        @Yveaux Thank you very much for the diode explanation, as well as the very interesting diode tutorial.
        Thanks to you, I've learned something more today.
        I'm gonna test it very soon, and will report back.
        • bisschopsrB bisschopsr
          The lamp is not shipped to NL and many other countries :unamused: . Did anyone find it in Europe?
          YveauxY
          YveauxY
          @bisschopsr @RiVoW @korttoma Accidentally ran into this one: http://www.aliexpress.com/store/product/1set-Garden-Security-Lamp-16-LED-Solar-Power-Motion-Sensor-Outdoor-Waterproof-Light/124364_32274407358.html
          Looks identical, and free shipment to The Netherlands :+1:
          • soifS
            soifS
            soif
            This is similar to the one I have also bought at aliexpress ;-)
            • thmT
              thmT
              thm
              Hello, thank you for this beautiful project.
              I have recreated it with a DHT22, a BMP180 and a BH1750FVI on a breadboard. From there everything is transferred to Domoticz via WiFi gateway. Everything is working properly. Only the light sensor makes problems ...
              The reading of the sensor gives correct values in Lux. These are sent right to the gateway. The Gateway appears to be wrong to interpret these values. It transmits incorrect values via WiFi.
              What can I do against it? Did anyone have an idea?
              I'm using MySensors 1.5 on Arduino 1.6.7.
              Thomas
              • SalmoidesS Salmoides
                @floris, Thank you for your kind words. The luxmeter faces down, so the light is indirectly collected through the diffuser. If I were to build V2.0, I would look into adding a light pipe to provide more direct lighting on the sensor.
                maciejka
                @Salmoides
                Hi, where i can find light pipe lie this?
                • C
                  C
                  chickey
                  I have one of these lights and got it with the plan of dissembling it for this very project but it was too good lol so think I'll buy another to dissect. The only disappointing thing is how the light is always on at a dim level so drains the battery. I'd much rather have it only activate on motion detection with the PIR.
                  • D
                    D
                    Dylano
                    Dear...
                    Great project...[ when i got my stuff i am going to build to...
                    Only how do you use the motionsensor of this light...[ new one or do you use the build in one ]
                    In the sketch is can not see this motionsensor?
                    Only in our Vera controller is see arm and bypass?
                    Can you set the level of the lights, in vera?
                    Two times temperature?
                    And how is your battery action in the winter-period?
                    Domoticz, with a lot of working hardware, include mysensors :-)
                    OpenPLI, RuneAudio, Solarmeter, etc......
                    Not a great builder of software and hardware, more a user...
                    Only i try to do my best :-(
                    • E
                      E
                      Elfnoir
                      wrote on last edited by Elfnoir
                      #70
                      Here is the fritzing shema ; could you please tell me if it is correct before I begin the building of the weather station ?
                      Thanks for your support !
                      D 1 Reply Last reply
                      • E Elfnoir
                        D
                        D
                        Dylano
                        @Elfnoir
                        This is great.....[ and great for a dummy like me ]
                        Would you please tell me all the hardware you use?
                        Or the strength of the resistor etc etc
                        • E
                          E
                          Elfnoir
                          The left resistor is a 1Mohm 2W(I'll confirm the power value once I'll received it), the right one is 4,7kohm, 1/4W.
                          For the Hardware, I read the beginning of the post, but unfortunately I'm also a newby, and need to have a validation of this diagram, because I'm not sure if it is correct, and I don't want to burn my house if I'll do cabling mistakes ;-)
                          I am not able to put the file created under fritzing, but if someone wants it, tell me how to do it please.
                          Thanks for your feedback!
                          Regards.
                          • bisschopsrB
                            bisschopsrB
                            bisschopsr
                            Hi all,
                            the lamp used as a basis for this desing is now frequently offered at Aliexpress. Price is around $10,-. DOn't know about quality, but looks very simular.
                            Ralph
                            Domoticz, P1 meter interface, MySensors and more to come!
                            • peerkersezuukerP
                              peerkersezuukerP
                              peerkersezuuker
                              Hello All,
                              Long time reader, first time poster.
                              I've been building my-sensors in combo with Domoticz for a while now , and this project is one of my favorites.
                              I can confirm that the fritzing schema is correct, i checked it against the one i build. (whish i had the schema earlier, it would have been so much easier ;-))
                              I used the followin library from Rob Tillaart for the DHT22 (http://playground.arduino.cc/Main/DHTLib / https://github.com/RobTillaart/Arduino/tree/master/libraries/DHTlib) because the standard was not working...
                              Change line 37 to dht DHT;
                              comment out line 51
                              From line 78 i changed the code to this :
                              delay(2000);
                                    int chk = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
                                    temp = DHT.temperature;
                                           //Serial.print("Temperature DHT :");
                                           //Serial.println(temp);
                                    if (isnan(temp)) {
                                        lastTemp = -1;
                                    } else if (temp != lastTemp) {
                                      lastTemp = temp;
                                      if (!metric) {
                                        temp = temp * 1.8 + 32.0;
                                      gw.send(msgTemp.set(temp, 1));
                                    hum = DHT.humidity;
                                    if (isnan(hum)) {
                                        lastHum = -1;
                                    } else if (hum != lastHum) {
                                        lastHum = hum;
                                        gw.send(msgHum.set(hum, 1));
                              And it is working like a charm.
                              Now i ordered one of these : Wind Sensor
                              I want to trie to get it working with this build.
                              And indeed the lamp is stil available Solar Lamp
                              Hope this helps,
                              With Regard's
                              Peer
                              Domoticz / My Sensors / Z-Wave
                              https://www.kermisbuks.nl
                              peerkersezuukerP 1 Reply Last reply
                              • E
                                E
                                Elfnoir
                                #75
                                Thanks for your help! I'm waiting for the LiPo charger, because I purchased a wrong one to pursue my implementation...
                                • Could you tell me how I can comment our line 51 please? Just like this?
                                  'dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
                                • Also, do you have already implement the Wind Speed Module, or it's under shipment? Do you use Domoticz as domotic software? It's to know how to implement this kind of child on it?
                                • Is the solar panel providing enough power to have the weather station always working? (I'm living in France on Paris latitude, and I would like to know if the quantity of sun is enough, or I need a second solar panel)
                                • And it appears my Barometric Pressure sensor gave me also the humidity and temperature; Why do we have 1DHT22 and 1BMP180 ?
                                • And finally, how do you deal with the battery level, as I didn't see at the beginning of this post how it is implemented inside Vera? Because I would like to implement it in Domoticz
                                  Many thanks for your feedback!
                                • peerkersezuukerP peerkersezuuker
                                  Hello All,
                                  comment out line 51
                                  delay(2000);
                                        if (isnan(temp)) {
                                            lastTemp = -1;
                                          lastTemp = temp;
                                          if (!metric) {
                                        hum = DHT.humidity;
                                        if (isnan(hum)) {
                                            lastHum = -1;
                                            lastHum = hum;
                                  Hope this helps,
                                  With Regard's
                                  Peer
                                  peerkersezuukerP
                                  peerkersezuukerP
                                  peerkersezuuker
                                  Commenting is done with //
                                  so //dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
                                  The wind sensor is stil in shipment, so can't tell you anything about it, and i use Domoticz as controler software.
                                  I presume you have your gateway setup and connected, so the node should show up in domoticz with all the childs.
                                  I tested the the weather station only a few day's past monyh, because it is still under construction, but those day's it held out (I live near Eindhoven the Netherlands, so weather conditions are almost the same as yours ;-)).
                                  The battery reports through the potentiometer to A0, if the battery level = 100% the readout of A0 should be 1023 (adjustable with the portentio meter.
                                  Here is my sketch in total, althoug verry crude it works, it yust needs a lot of cleanup when i am done, but i need the sensor first to work.
                                      #include <dht.h>
                                      #include <BH1750.h>
                                      #include <Wire.h>
                                      #include <Adafruit_BMP085.h>
                                      #define CHILD_ID_HUM 0
                                      #define CHILD_ID_TEMP 1
                                      #define CHILD_ID_LIGHT 2
                                      #define CHILD_ID_BARO 3
                                      #define CHILD_ID_BTEMP 4
                                      #define CHILD_ID_WINDSPEED 5
                                      #define CHILD_ID_RAIN 6
                                      #define CHILD_ID_RAINRATE 7
                                      #define MESSAGEWAIT 500
                                      #define nRainIn A2
                                      #define DIGITAL_INPUT_RAIN_SENSOR 3
                                      #define HUMIDITY_SENSOR_DIGITAL_PIN 5
                                      #define ENCODER_PIN 2
                                      #define INTERRUPT DIGITAL_INPUT_RAIN_SENSOR-2
                                      //int encoder_pin = 7; // pulse output from the module
                                      unsigned int rpm; // rpm reading
                                      volatile byte pulses; // number of pulses
                                      unsigned long timeold;
                                      // number of pulses per revolution
                                      // based on your encoder disc
                                      unsigned int pulsesperturn = 1;
                                      boolean metric = false;
                                      int altitude = 16; // meters above sealevel
                                      float lastBmpTemp = -1;
                                      float lastPressure = -1;
                                      float lastHum = -1;
                                      float lastTemp = -1;
                                      double temp;
                                      double hum;
                                      int BATTERY_SENSE_PIN = A0;
                                      int lastRainValue = -1;
                                      int nRainVal;
                                      boolean bIsRaining = false;
                                      String strRaining = "NO";
                                      int lastBatteryPcnt = 0;
                                      int updateAll = 60;
                                      int updateCount = 0;
                                      uint16_t lastLux;
                                      // unsigned long SLEEP_TIME = 60000;
                                      unsigned long SLEEP_TIME = 600;
                                      int batteryBasement = 800;
                                      float batteryConstant = 100.0 / (1023 - batteryBasement);
                                      Adafruit_BMP085 bmp = Adafruit_BMP085();
                                      BH1750 lightSensor;
                                      dht DHT;
                                      MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                                      MyMessage msgBtemp(CHILD_ID_BTEMP, V_TEMP);
                                      MyMessage msgPressure(CHILD_ID_BARO, V_PRESSURE);
                                      MyMessage msgWindSpeed(CHILD_ID_WINDSPEED, V_WIND);
                                      MyMessage msgRain(CHILD_ID_RAIN, V_TRIPPED);
                                      MyMessage msgRainRate(CHILD_ID_RAINRATE, V_RAIN);
                                      void counter()
                                        //Update count
                                        pulses++;
                                        analogReference(INTERNAL);
                                        gw.begin(incomingMessage, 3, true);
                                        bmp.begin();
                                        gw.sendSketchInfo("Weather Sensor", "1.0");
                                        gw.present(CHILD_ID_HUM, S_HUM, "WS Humidity");
                                        gw.present(CHILD_ID_TEMP, S_TEMP, "WS Temperature");
                                        gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "WS Lux");
                                        gw.present(CHILD_ID_BARO, S_BARO, "WS Pressure");
                                        gw.present(CHILD_ID_BTEMP, S_TEMP, "WS P Temperature");
                                        gw.present(CHILD_ID_WINDSPEED, S_WIND, "WS Windspeed");
                                        gw.present(CHILD_ID_RAIN, S_MOTION, "WS Rain");
                                        gw.present(CHILD_ID_RAINRATE, S_RAIN, "WS RainRate");
                                        pinMode(DIGITAL_INPUT_RAIN_SENSOR, INPUT);
                                        lightSensor.begin();
                                        pinMode(ENCODER_PIN, INPUT);
                                        //Interrupt 0 is digital pin 2
                                        //Triggers on Falling Edge (change from HIGH to LOW)
                                        attachInterrupt(0, counter, FALLING);
                                        // Initialize
                                        pulses = 0;
                                        rpm = 0;
                                        timeold = 0;
                                        updateCount += 1;
                                        if (updateCount == updateAll) {
                                          lastTemp = -1;
                                          lastHum = -1;
                                          lastLux = -1;
                                          lastBmpTemp = -1;
                                          lastPressure = -1;
                                          lastRainValue = -1;
                                          lastBatteryPcnt = -1;
                                          updateCount = 0;
                                        delay(2000);
                                        if (isnan(temp)) {
                                            lastTemp = -1;
                                          lastTemp = temp;
                                          if (!metric) {
                                        hum = DHT.humidity;
                                        if (isnan(hum)) {
                                            lastHum = -1;
                                            lastHum = hum;
                                        uint16_t lux = lightSensor.readLightLevel();
                                        if (lux != lastLux) {
                                            gw.send(msgLux.set(lux));
                                            lastLux = lux;
                                        float pressure = bmp.readSealevelPressure(altitude) * 0.01;
                                        float bmptemp = bmp.readTemperature();
                                        if (!metric) {
                                          bmptemp = bmptemp * 1.8 + 32.0;
                                        if (bmptemp != lastBmpTemp) {
                                          gw.send(msgBtemp.set(bmptemp,1));
                                          lastBmpTemp = bmptemp;
                                        if (pressure != lastPressure) {
                                          gw.send(msgPressure.set(pressure, 0));
                                          lastPressure = pressure;
                                        nRainVal = analogRead(nRainIn);
                                               Serial.print("RainVal :");
                                               Serial.println(nRainVal);
                                        bIsRaining = !(digitalRead(DIGITAL_INPUT_RAIN_SENSOR));
                                               Serial.print("Is Raining :");
                                               Serial.println(bIsRaining);
                                        if(bIsRaining){
                                            strRaining = "YES";
                                        else{
                                            strRaining = "NO";
                                    //Serial.print("Raining?: ");
                                    //Serial.print(strRaining);
                                    //Serial.print("\t Moisture Level: ");
                                    //Serial.println(nRainVal);
                                    //http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-rain-sensor-module-guide-and-tutorial/
                                        gw.send(msgRain.set(bIsRaining));
                                        nRainVal = nRainVal * -1;
                                        gw.send(msgRainRate.set(nRainVal));
                                        int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                                        if (lastBatteryPcnt != batteryPcnt) {
                                          lastBatteryPcnt = batteryPcnt;
                                       if (millis() - timeold >= 1000) {
                                          //Don't process interrupts during calculations
                                          detachInterrupt(0);
                                          rpm = (60 * 1000 / pulsesperturn )/ (millis() - timeold)* pulses;
                                          timeold = millis();
                                          Serial.print("RPM = ");
                                          Serial.println(rpm,DEC);
                                          Serial.println(pulses);
                                          pulses = 0;
                                          rpm = rpm,DEC;
                                          if (rpm == 0) {
                                            rpm = 1;
                                          gw.send(msgWindSpeed.set(rpm, 1));
                                          //Restart the interrupt processing
                                        gw.sleep(SLEEP_TIME);
                                      void incomingMessage(const MyMessage & message) {
                                       if (message.isAck()) {
                                  And there is the puls counter which i abandoned for the wind speed meter (wanted to build my own with a optocoupler, but changed my mind).
                                  Hope this is helpfull.
                                  Regard's
                                  Peer
                                  • peerkersezuukerP
                                    peerkersezuukerP
                                    peerkersezuuker
                                    @Elfnoir,
                                    Could you please send me the fritzing schema, or attach it here ?
                                    I want to add the windmeter i bought.
                                    I got it today, and with a little help from google i got it working.
                                    Greetz Peer
                                    E 1 Reply Last reply
                                      @Elfnoir,
                                      Greetz Peer
                                      E
                                      E
                                      Elfnoir
                                      @peerkersezuuker 0_1459719366114_Weather Station.fzz
                                      And thanks for your feedback and support!
                                      • peerkersezuukerP
                                        peerkersezuukerP
                                        peerkersezuuker
                                        So here it is :
                                        0_1459792588384_upload-3adeb2e3-0d4c-41e1-a7d7-e973e5081210
                                        And the code (still very rude but it works)
                                            #include <dht.h>
                                            #include <BH1750.h>
                                            #include <Wire.h>
                                            #define nRainIn A2
                                            const int  windSpeedPin = 2; // contact on pin 2 digital
                                            int windSpeedPinCounter = 0; // impuls counter
                                            int windSpeedPinStatus = 0; // actual impuls
                                            int windSpeedPinStatusAlt = 0; // oude Impuls-Status
                                            unsigned long windmeterStart;
                                            unsigned long windmeterStartAlt = 0;
                                            int windSpeed; // Variable voor Wind Speed
                                            int beaufort = 0; // Variable Wind in Beaufort
                                            const int windmeterTime = 10000;
                                            //float knoten = 0.0;
                                            //float wind = 0.0;
                                            int knoten = 0.0;
                                            int wind = 0.0;
                                            float lastHum = -1;
                                            double temp;
                                            double hum;
                                            int nRainVal;
                                            int updateAll = 60;
                                            uint16_t lastLux;
                                            BH1750 lightSensor;
                                            dht DHT;
                                              bmp.begin();
                                            // Wind Meter https://github.com/chiemseesurfer/arduinoWeatherstation/blob/master/weatherstation/weatherstation.ino
                                            float windmeter()
                                                windmeterStart = millis(); // Actual start time measuringMessung
                                                windmeterStartAlt = windmeterStart; // Save start time
                                                windSpeedPinCounter = 0; // Set pulse counter to 0
                                                windSpeedPinStatusAlt = HIGH; // Set puls status High
                                                while ((windmeterStart - windmeterStartAlt) <= windmeterTime) // until 10000 ms (10 Seconds) ..
                                                    windSpeedPinStatus = digitalRead(windSpeedPin); // Read input pin 2
                                                    if (windSpeedPinStatus != windSpeedPinStatusAlt) // When the pin status changed
                                                        if (windSpeedPinStatus == HIGH) // When status - HIGH
                                                            windSpeedPinCounter++; // Counter + 1
                                                    windSpeedPinStatusAlt = windSpeedPinStatus; // Save status for next loop
                                                    windmeterStart = millis(); // Actual time
                                                windSpeed =  ((windSpeedPinCounter * 24) / 10) + 0.5; //  WindSpeed - one Pulse ~ 2,4 km/h,
                                                windSpeed = (windSpeed / (windmeterTime / 1000)); // Devided in measure time in seconds
                                                Serial.print("wind Speed :");
                                                Serial.println(windSpeed);
                                                knoten = windSpeed / 1.852; //knot's
                                                return knoten;
                                              updateCount += 1;
                                                lastTemp = -1;
                                                lastHum = -1;
                                                lastLux = -1;
                                                lastBmpTemp = -1;
                                                lastPressure = -1;
                                                lastRainValue = -1;
                                                updateCount = 0;
                                              delay(2000);
                                              if (isnan(temp)) {
                                                  lastTemp = -1;
                                                lastTemp = temp;
                                                if (!metric) {
                                              hum = DHT.humidity;
                                              if (isnan(hum)) {
                                                  lastHum = -1;
                                                  lastHum = hum;
                                                  lastLux = lux;
                                              if (!metric) {
                                              if(bIsRaining){
                                                  strRaining = "YES";
                                              else{
                                                  strRaining = "NO";
                                              wind = windmeter();
                                              Serial.print("Wind :");
                                              Serial.println(wind);
                                              gw.send(msgWindSpeed.set(wind));
                                        Still need some cleaning and calibrating (rain and wind sensor)
                                        [0_1459792799776_Weather-station.fzz](/uploads/files/1459792799984-weather-station.fzz)
                                        Regard's Peer
                                        • peerkersezuukerP
                                          peerkersezuukerP
                                          peerkersezuuker
                                          Oh yeah, a little source mentioning :
                                          Weather Station
                                          Weather Station Code
                                          Greetz Peer
