  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 817.1k Views 27 Watching
  • NeverDieN
    NeverDieN
    Well, I'm sold. I just ordered one. @andrew I hope you're still around after it arrives. :)
    andrewA 1 Reply Last reply
    • NeverDieN NeverDie
      andrewA
      andrewA
      andrew
      @neverdie I'll be here :)
      you'll love the stuff, I bet for it.
      in the meantime I'll try to finish a howto on the cnc assembly/setup and on other tricks, such as firmware upgrade (which is not officially documented).
      I received the pack like the pics below, it took me two nights to assemble it.
      I would recommend not to use the provided SW pack. or maybe just in a dedicated VM, without internet connection... who knows...
      • andrewA andrew
        @neverdie just search for "cnc 2418" on ebay and you can find a lot. almost all of these are Chinese stuff, but works without any issue. based on your needs you can find bigger or smaller versions, such as cnc 1610 or cnc 3020.
        the chosen one should be USB connected and GRBL firmware controlled (check it in the description), so you can use it with open source tools, such as bCNC (https://github.com/vlachoudis/bCNC), chilipeppr (chilipeppr.com/grbl). for isolation milling you should use flatcam (http://flatcam.org/) for the G code preparation based on the gerber and drill files exported from KiCAD/eagle/etc.
        drill sets, milling bit sets and engraving bit sets could be ordered from China for couple of bucks only.
        e.g.:
        • drill bits: https://www.aliexpress.com/item/Free-Shipping-10-Pcs-0-3mm-1-2mm-Import-Carbide-PCB-Drill-Bits-Print-Circuit-Board/32717739217.html
        • carving bits https://www.aliexpress.com/item/New-10pcs-New-Mini-PCB-wood-drill-Bits-Tungsten-Steel-Carbide-PCB-CNC-drill-Bit-Milling/32702792947.html
        • milling bits https://www.aliexpress.com/item/10Pcs-Set-1-8-0-8-3-175mm-Drill-Bits-Engraving-Cutter-Rotary-PCB-CNC-End/32774556522.html
        NeverDieN
        NeverDieN
        @andrew said in CNC PCB milling:
        Which of the 6 "models" should I pick?
          andrewA
          andrewA
          andrew
          wrote on last edited by andrew
          #24
          @neverdie it depends :)
          for fine isolation routing I use 2001 bits (20 deg, 0.1 width), this gives you 0.1363970234mm (5.369961552mil) width at 0.05mm cutting/carving depth. the more sharped bits are more precise but more fragile as well.
          for hole milling, outline milling I typically use 0.8mm end mill.
          it is good to have multiple items from each different tools / sizes, so you can vary them, based on the needs, and replace them if necessary (broken or blunt tools).
          NeverDieN 1 Reply Last reply
          • andrewA andrew
            NeverDieN
            NeverDieN
            #25
            @andrew OK, so do you recommend getting one set of each model, or multiple sets of the two models you indicated? Or...?
            • NeverDieN
              NeverDieN
              https://www.youtube.com/watch?v=QXxM4F_7KIk
              • NeverDieN
                NeverDieN
                #27
                @andrew I'll probably buy these to mill unless you recommend getting something else: https://www.aliexpress.com/item/75x100x1-5mm-FR4-Copper-Clad-Laminate-Sheet-Circuit-Double-side-PCB-10X7-5cm/32750849179.html?spm=2114.search0204.3.58.zZsg7D&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_5000015_10151_10344_10068_10130_10345_10324_10342_10547_10325_10343_51102_10546_10340_10341_10548_10545_5130015_10541_10084_10083_10307_5690015_10539_5080015_10312_10059_10313_10314_10534_100031_10604_10603_10103_10605_10594_5060015_10596_10142_10107,searchweb201603_25,ppcSwitch_4_ppcChannel&algo_expid=2370c55b-79dc-485c-b61d-52453b31f1d1-7&algo_pvid=2370c55b-79dc-485c-b61d-52453b31f1d1&rmStoreLevelAB=0
                Looking at reviews on Amazon, it seems that some boards use a bad adhesive, resulting in pads lifting during soldering. I don't know whether these use a good or a bad adhesive. I'd prefer to buy boards that are "known good" rather than roll the dice.
                • NeverDieN
                  NeverDieN
                  @andrew Anything else I should order while I'm at it?
                    andrewA
                    andrewA
                    andrew
                    #29
                    @neverdie I would say, as for a starter kit you should have:
                    • drill bit set from 0.3mm to 1.2mm, e.g. this, which I already mentioned before. for vias, through hole components you will use a couple from them. I recommend to have at least 2 pack from this. if you make any mistake (e.g. while moving the cnc head to the relative home without properly realigning the z axis after a tool change /yes, it happened with me :)/) then you can easily break a bit. so have a spare set, just in case...
                    • 0.8mm end mills for slot milling, edge cuts and to mill holes which are bigger than your drill bits (e.g. mounting holes). the previously mentioned set is good, as you have multiple options for different tasks, but I still recommend to have some spare one from the 0.8mm end mill in advance.
                    • same applies to the carving bit sets. buy one set with multiple size variants (in the given link it is "model 6"), and buy another which just contains 2001 bits (model 2) as these bits will be used the most.
                    • PCBs. I usually buy mine from local stores, but your linked one seems to be fine. nothing special, single side or double sided FR4 PCBs, based on your needs (size, thickness). I use 1.6mm thick 1oz FR4 boards, others should work as well.
                    you will/might need double sided adhesive tape, and a sacrificial layer for the cnc, to protect your cnc's bed. I applied a wood board cut for proper bed size for this purpose (see before / after pics below). when you drill holes or mill edges/slots then the drilling/milling tools should go through on your PCB, so there should be a sacrificial layer between your cnc's aluminium bed and the PCB. this layer should be replaced when it become very used.
                    basically that is it, no rocket science :)
                    • dbemowskD
                      dbemowskD
                      I have been working on gathering parts to build either another 3D printer or CNC machine like this. I think I am sold on a CNC. A question I have on this is what kind of control board does this use? Is it just a standard RAMPS 1.4 board like ones used in 3D printers? Also, is that just a piece of MDF mounted for the build plate? Curious why you didn't just put some T-nuts with clamps on the V-slot plate? Is there an advantage to using the MDF?
                      NeverDieN andrewA 3 Replies Last reply
                      • dbemowskD dbemowsk
                        NeverDieN
                        NeverDieN
                        @dbemowsk said in CNC PCB milling:
                        Without the sacrificial MDF material (where, presumably, MDF is flatter than ordinary wood), then when you drill through the PCB material, wouldn't you also be drilling into the v-slot support metal? i.e. presumably you need some kind of sacrificial layer, and the flatter the better.
                        dbemowskD 1 Reply Last reply
                          NeverDieN
                          NeverDieN
                          #32
                          One WoodPecker GRBL 0.9 controller and 3 stepper motor drivers:
                          0_1512921107273_USB-port-cnc-engraving-machine-control-board-3-axis-control-laser-engraving-machine-board-GRBL-control.jpg
                          https://www.aliexpress.com/store/product/Freeshipping-USB-port-cnc-engraving-machine-control-board-3-axis-control-laser-engraving-machine-board-GRBL/424291_32809235879.html?spm=2114.12010615.0.0.6d908f98CJc2us
                            andrewA
                            andrewA
                            andrew
                            #33
                            @dbemowsk that is just a simple laminated MDF, but other materials could also work. the only advantage it has is that it is not a very strong material (when the drill or milling bit go into that) and it is flat.
                            I used T-nuts at the bottom, but I did not receive clamps, so this is why I drilled the MDF and fixed like this. my original screws were longer than necessary, so later I replaced them with a shorter version (see the picture below), so it is not disturbing now.
                            you can use clamps, but if you would like to drill or mill as well and not just isolation routing on the top layer, then you need a sacrificial layer between the PCB and the cnc bed. this could be also fixed with the clamps, so it is basically up to you how to solve this.
                            I went for this solution as it is flat, fix and very stable. for the double sided PCBs I can (and have to) use alignment holes with an additional tool in the holes to position the PCB, then a simple double sided adhesive tape makes the job to fix the PCB.
                            this cnc comes with the controller board which is mentioned by @NeverDie, it is basically a GRBL compatible board. you can also use different controllers such as arduino based ones, Pi CNC Hat, TinyG and others. it uses Pololu drivers like the RAMPS, but for the RAMPS I'm not sure in the communication protocol.
                              dbemowskD
                              dbemowskD
                              @neverdie Good point. I hadn't thought about that.
                              • dbemowskD
                                dbemowskD
                                A RAMPS board is much cheaper, but I don't know if that can be used for CNC.
                                • NeverDieN
                                  NeverDieN
                                  @andrew Thanks for all the links. I've ordered everything on your list. Which software will be the first I use? Maybe I can start learning a bit about it while I wait for the deliveries to arrive.
                                  • V
                                    V
                                    Vince
                                    If you are doing only 1 pcb or 2 it is oke to use a cnc milling machine,
                                    i needed a bunch of boards for my home automation project and it took way to long.
                                    Changing bits for engraving/drilling etc and then the costs of the pcb itself.
                                    I went to https://www.itead.cc/open-pcb/pcb-prototyping.html , double sided smaller circuits then with your milling machine and coating , looks like factory pcbs.
                                    it is fun to see the machine working though, made some timelapse videos.
                                    click for the video
                                      andrewA
                                      andrewA
                                      andrew
                                      @neverdie cool, you will have a nice Christmas then :)
                                      I guess you have experience with EDA tools, such as KiCAD or Eagle. this should be the first point. you should export your PCB related gerber and excellon files (top and bottom copper layers, edge cuts) from the given EDA software, then flatcam is the next one.
                                      in flatcam you have to import the exported files and do all of the necessary preparation work, to create the necessary G codes for every tasks, including isolation routing, milling and drilling.
                                      this will be your main tool, so discover it as much as possible, including the double sided pcb handling part. most of the manual preparation happens here. maybe this tool is the most important in the whole process.
                                      after this, you just have to use a G code sender tool which will control the CNC based on the G code, but this is the easy part. you need a CNC for that, so let's get back to this once you have a working setup. maybe in the meantime you can check e.g. bCNC's and chilipeppr's general howtos.
                                      without a working cnc you can also visualise and simulate the G code, e.g. with CAMotics.
                                      YveauxY 1 Reply Last reply
                                      • V Vince
                                        click for the video
                                        NeverDieN
                                        NeverDieN
                                        #39
                                        @vince I think it's meant for prototyping, not production. At least for that purpose, the reduction in turnaround time should be huge. If, instead, you send everything to the fab at every step, then you need the patience of a saint to iteratively evolve a PCB design.
                                        V 1 Reply Last reply
                                        • andrewA andrew
                                          YveauxY
                                          YveauxY
                                          @andrew you wrote you sourced your cnc from the EU. Could you share where you bought it?
                                          andrewA NeverDieN 2 Replies Last reply
