  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 33.5k Views 2 Watching
  • N Offline
    N Offline
    Here Plot.Ly has been working:
    https://plot.ly/~WhiteRabbit/997
    About 6 months or so ago it seemed to stop plotting, and it wouldn't resume even if I rebooted the Arduino. So, I requested all new stream tokens, plugged those into the Arduino program, rebooted, and it has been working since. What I like about Plot.ly is that I can both pan and zoom the data.
    I'm presently driving Plot.ly using just the Arduino API. I get the impression I'd have finer grained control if I were to drive it using Python instead.
    • K Offline
      K Offline
      korttoma
      @NeverDie Thanks for posting, I created a new API key and deleted my old plot and so far so good, it is working again.
      Like you I also prefer the UI and plots produced by plot.ly but I'm not convinced by the reliability so far.
      • Tomas
      N 1 Reply Last reply
      • HoffanH Offline
        HoffanH Offline
        Hoffan
        Hi Guys
        How much work is it in Plot.ly to get in to work
        Becuase i test to Copy the examples upper here and put my INFO in the text
        But nothing happens, Must i change a lot of thing on the Plot.ly page
        • K korttoma
          N Offline
          N Offline
          I share your concern. It has been a bumpy ride. If it weren't for the pan and zoom UI, I would have tried switching to another free service.
          • HoffanH Offline
            HoffanH Offline
            Hoffan
            Any one that can explain for me how to get plot.ly to work, I really don't get it :(
            • K Offline
              K Offline
              korttoma
              @Hoffan if you have an APIKey and username from plot.ly all you need to do is to change the following from the first post in this thread:
              ("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 83) If you don't know what this should be let me know so I can explain further.
              <username>
              <APIKey>
              <nameForGraph>
              <graphTitle>
              You should make sure you remove all the < >
              Also I noticed that you can only have one private graph so if you already have one the second one will not get created.
              Try changing "world_readable":false to "world_readable":true
              Now test your lua code from apps -> develop apps -> test loop code (lua). Do you get any errors?
              • Tomas
              • HoffanH Offline
                HoffanH Offline
                Hoffan
                @korttoma
                So if i understand this right, If i have a User and a APIKey, i dont need to do
                anything on plot.ly page
                I will test to change false to True when i get back home tonight :)
                • K Offline
                  K Offline
                  korttoma
                  @Hoffan no you should not need to change anything at plot.ly your graph should just appear among "YOUR RECENT FILES" on the right when you go to "https://plot.ly/".
                  • Tomas
                  • HoffanH Offline
                    HoffanH Offline
                    Hoffan
                    @korttoma
                    Big thanks. Now its working :)
                    • S Offline
                      samppa
                      It seems that plot.ly has new limitations to the free API in their price plan:
                      • Only one free private graph
                      • API rate limits: 50 per day or 30 per hour
                      Then you have to pay 20 USD/month to get unlimited access.
                      Damn. There goes the cheap solution.
                      • S samppa
                        N Offline
                        N Offline
                        Nuubi
                        @samppa Yeah, one another, again. Personally, started with Pachube a few years ago. Gone, a long time ago.
                        • K Offline
                          K Offline
                          korttoma
                          Thanks @samppa I was wondering why my plots were not working properly, this explains it.
                          • Tomas
                          • S Offline
                            samppa
                            I converted my code to use ThingSpeak.
                            It is even simpler to call since the formatting is done on the website. Here is how I use it:
                            local url = "https://api.thingspeak.com/update?api_key=_YOUR_KEY_HERE_"
                            result, status = http.request(url,'field1='..HotWaterTemp..'&field2='..HotWaterPump..'&field3='..HotWaterLimit..'&field4='..PumpTime)
                            On the https://thingspeak.com website you just define the "channel" that receives all the data and copy the example "plugin" and modify it to render your graph.
                            Quite easy. And free at least so far..
                            • K Offline
                              K Offline
                              korttoma
                              I converted some to ThingSpeak now also but I could not get it to work using your example @samppa ,don't know why but this works for me:
                              local http = require("socket.http")
                              result, status = http.request("http://api.thingspeak.com/update?key=<API_KEY>&field1="..TankTopp.."&field2="..TankMitten.."&field3="..TankBotten.."&field4="..StatTemp.."&field5="..StatMode.."&field6="..Solpanel.."&field7="..Solpump.."&field8="..CirkPump.."", "run=run")```
                              • Tomas
                              S 1 Reply Last reply
                              • M Offline
                                M Offline
                                MikeF
                                Like others, I've (regrettably) given up on plot.ly, and gone over to ThingSpeak.
                                I'm using the following Python code to send values from Domoticz:
                                thingURL =  'https://api.thingspeak.com/update?api_key=_YOUR_KEY_HERE'
                                url = thingURL + "&field1=%s&field2=%s&field3=%s&field4=%s&field5=%s" \
                                	% (inside, target, outside, lounge, heating)
                                f = urllib2.urlopen(url)
                                f.close()
                                • K korttoma
                                  samppa
                                  @korttoma The only difference I see is that you put the entire url with parameters in the first argument of the http.request call and "run=run" as the second (don't know why you have that?). I use the base url as the first argument and the field list as the second
                                   r, s = http.request(baseUrl, "field1=XX&field2=XX")
                                  Hope that fixes the issue.
                                  Also You have to setup the "Channel" and "Plugin" in the website accordingly and name the fields there.
