  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 33.5k Views 2 Watching
  • S Offline
    samppa
    My graphs stopped as well. I have asked what is going on.. Let's see when it gets back up again..
    • K Offline
      K Offline
      korttoma
      I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
      • Tomas
      D S 2 Replies Last reply
      • K korttoma
        Dwalt
        wrote on last edited by Dwalt
        #23
        @korttoma
        I tried to set up a new graph using the REST API and could not get it to register with Plot.ly. Without any explanation from Plot.ly, I tried sending the same data streams to ThingSpeak.com and it set up with out any trouble. The API is slightly different but just as easy to use. I set up a scene to run every 15 minutes with the following code:
        -- Get Light Levels
        local LR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
        local BR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 55)
        - - Get Temps
        local LR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 46)
        local BR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 54)
        local OUT_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 23)
        -- Send data to ThingSpeak.com
        local http = require("socket.http")
        http.TIMEOUT = 5
        result, status = http.request("http://api.thingspeak.com/update?key=Insert Your API Key here&field1="..LR_TEMP.."&field2="..BR_TEMP.."&field3="..OUT_TEMP.."&field4="..LR_LIGHT_LEVEL.."&field5="..BR_LIGHT_LEVEL.."", "run=run") ````
        The service has a limited functionality to manipulate your data but the base configuration is easy to tweak and can be made public or private.  See [here for my sample data](https://thingspeak.com/channels/25629).
        ...plus it is free to use.
        • K korttoma
          samppa
          wrote on last edited by samppa
          #24
          @korttoma
          Now plot.ly is back up again.
          Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
          • K Offline
            K Offline
            korttoma
            Yes, now it is working again. Maybe you should try again @Dwalt ?
            • Tomas
            D 1 Reply Last reply
            • K korttoma
              Dwalt
              @korttoma
              I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
              I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
              • K Offline
                K Offline
                korttoma
                There was an outage again last night. No data uploaded for 3h. Was it just me or plot.ly?
                • Tomas
                • K korttoma
                  Dwalt
                  @korttoma I got it too.
                  • D Offline
                    derrij
                    This post is deleted!
                    • K Offline
                      K Offline
                      korttoma
                      Did plot.ly change something or did I brake my own ploting somehow? Anyone else having problems?
                      • Tomas
                      • K korttoma
                        Dwalt
                        @korttoma
                        My plots are still working.
                        • K Offline
                          K Offline
                          korttoma
                          @Dwalt would you mind charing your lua? Remember to remove your username and api key ;)
                          Here is a nexample of what I'm using and it stoped working on 9th of this month.
                          local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
                          local TankTopp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 174)
                          local TankMitten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 179)
                          local TankBotten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 175)
                          local Solpanel = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 28)
                          local Solpump = luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", 212) * 50
                          local CirkPump = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 98)
                          local ts = os.date("%Y-%m-%d %X")
                          http.TIMEOUT = 8
                          result, status = http.request("https://plot.ly/clientresp", 'un=useruser&key=keykeyszx&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..OutTemp..'],"name":"Ute Temp"},{"x":["'..ts..'"],"y":['..TankTopp..'],"name":"Tank Topp"},{"x":["'..ts..'"],"y":['..TankMitten..'],"name":"Tank Mitten"},{"x":["'..ts..'"],"y":['..TankBotten..'],"name":"Tank Botten"},{"x":["'..ts..'"],"y":['..Solpanel..'],"name":"Solpanel Temp"},{"x":["'..ts..'"],"y":['..Solpump..'],"name":"Sol Pump"},{"x":["'..ts..'"],"y":['..CirkPump..'],"name":"Cirkulationspump"}]&kwargs={"filename":"Varme","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4,5,6],"layout":{"title":"Värme Systemet"},"world_readable":false}')```
                          I get 2 values correct to the graph but after this it somehow screws up the time axis of the graph.
                          • Tomas
                          • K korttoma
                            http.TIMEOUT = 8
                            Dwalt
                            #33
                            @korttoma
                            Here is my code.
                            This only tracks light level from one sensor. I did have a data outage that lasted 3 days last month (5/24 - 5/27) and I did not notice it at the time so I am unable to determine exact cause. It resumed plotting after 3 days and I assume the error was on plotly's side. Plotly had some 'offline' issues last year as well.
                            local Light_level = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                            http.TIMEOUT = 5
                            result, status = http.request("https://plot.ly/clientresp",'un=XXXXX&key=XXXXX&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..Light_level..']}]&kwargs={"filename":"MHLux","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"MHLux_Test"},"world_readable":false}')```
                            • K Offline
                              K Offline
                              korttoma
                              Bingo. You only have one data source. That I can get to work also. I had over 10 different data in one graph and it was working fine but it is not anymore.
                              • Tomas
                              • 5546dug5 Offline
                                5546dug5 Offline
                                5546dug
                                @samppa just wondering what the numbers at the end of the luup code refers to is 83. 347 etc?
                                I am reading and what to try to graph my temp/hum.
                                • 5546dug5 5546dug
                                  Dwalt
                                  @5546dug
                                  The numbers are the device id numbers within Vera. They tell the 'Get' command exactly which sensors/devices to pull the data from. They can be found under the 'Advanced' tab under each devices' 'settings'.
                                  • K Offline
                                    K Offline
                                    korttoma
                                    I gave up on plot.ly. I can no longer send many data to one graph using their API so I started looking in to ThingSpeak.com that @Dwalt mentioned. I seems like you can use plugins to create graphs with multiple series, seems to work nicely.
                                    • Tomas
                                    B N 2 Replies Last reply
                                    • K korttoma
                                      B Offline
                                      B Offline
                                      BulldogLowell
                                      @korttoma
                                      maybe try the new Maker channel on IFTTT and send data to google spreadsheet.
                                      then just feed your plotting software (or excel) from the data on your google drive.
                                      • K korttoma
                                        N Offline
                                        N Offline
                                        Did you get it to work?
                                        K 1 Reply Last reply
                                        • N NeverDie
                                          K Offline
                                          K Offline
                                          korttoma
                                          @NeverDie ThingSpeak is workin but not plot.ly
                                          • Tomas
