  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.5k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    @Dwalt would you mind charing your lua? Remember to remove your username and api key ;)
    Here is a nexample of what I'm using and it stoped working on 9th of this month.
    local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
    local TankTopp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 174)
    local TankMitten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 179)
    local TankBotten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 175)
    local Solpanel = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 28)
    local Solpump = luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", 212) * 50
    local CirkPump = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 98)
    local ts = os.date("%Y-%m-%d %X")
    local http = require("socket.http")
    http.TIMEOUT = 8
    result, status = http.request("https://plot.ly/clientresp", 'un=useruser&key=keykeyszx&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..OutTemp..'],"name":"Ute Temp"},{"x":["'..ts..'"],"y":['..TankTopp..'],"name":"Tank Topp"},{"x":["'..ts..'"],"y":['..TankMitten..'],"name":"Tank Mitten"},{"x":["'..ts..'"],"y":['..TankBotten..'],"name":"Tank Botten"},{"x":["'..ts..'"],"y":['..Solpanel..'],"name":"Solpanel Temp"},{"x":["'..ts..'"],"y":['..Solpump..'],"name":"Sol Pump"},{"x":["'..ts..'"],"y":['..CirkPump..'],"name":"Cirkulationspump"}]&kwargs={"filename":"Varme","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4,5,6],"layout":{"title":"Värme Systemet"},"world_readable":false}')```
    I get 2 values correct to the graph but after this it somehow screws up the time axis of the graph.
    • Tomas
    DwaltD 1 Reply Last reply
    • korttomaK korttoma
      http.TIMEOUT = 8
      DwaltD
      DwaltD
      Dwalt
      wrote on last edited by Dwalt
      #33
      @korttoma
      Here is my code.
      This only tracks light level from one sensor. I did have a data outage that lasted 3 days last month (5/24 - 5/27) and I did not notice it at the time so I am unable to determine exact cause. It resumed plotting after 3 days and I assume the error was on plotly's side. Plotly had some 'offline' issues last year as well.
      local Light_level = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
      http.TIMEOUT = 5
      result, status = http.request("https://plot.ly/clientresp",'un=XXXXX&key=XXXXX&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..Light_level..']}]&kwargs={"filename":"MHLux","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"MHLux_Test"},"world_readable":false}')```
      • korttomaK
        korttomaK
        korttoma
        Bingo. You only have one data source. That I can get to work also. I had over 10 different data in one graph and it was working fine but it is not anymore.
        • Tomas
        • 5546dug5
          5546dug5
          5546dug
          @samppa just wondering what the numbers at the end of the luup code refers to is 83. 347 etc?
          I am reading and what to try to graph my temp/hum.
          • 5546dug5 5546dug
            DwaltD
            DwaltD
            Dwalt
            @5546dug
            The numbers are the device id numbers within Vera. They tell the 'Get' command exactly which sensors/devices to pull the data from. They can be found under the 'Advanced' tab under each devices' 'settings'.
            • korttomaK
              korttomaK
              korttoma
              I gave up on plot.ly. I can no longer send many data to one graph using their API so I started looking in to ThingSpeak.com that @Dwalt mentioned. I seems like you can use plugins to create graphs with multiple series, seems to work nicely.
              • Tomas
              BulldogLowellB NeverDieN 2 Replies Last reply
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @korttoma
                maybe try the new Maker channel on IFTTT and send data to google spreadsheet.
                then just feed your plotting software (or excel) from the data on your google drive.
                  Did you get it to work?
                  korttomaK 1 Reply Last reply
                    korttomaK
                    korttomaK
                    korttoma
                    @NeverDie ThingSpeak is workin but not plot.ly
                    • Tomas
                      Here Plot.Ly has been working:
                      https://plot.ly/~WhiteRabbit/997
                      About 6 months or so ago it seemed to stop plotting, and it wouldn't resume even if I rebooted the Arduino. So, I requested all new stream tokens, plugged those into the Arduino program, rebooted, and it has been working since. What I like about Plot.ly is that I can both pan and zoom the data.
                      I'm presently driving Plot.ly using just the Arduino API. I get the impression I'd have finer grained control if I were to drive it using Python instead.
                      • korttomaK
                        korttomaK
                        korttoma
                        @NeverDie Thanks for posting, I created a new API key and deleted my old plot and so far so good, it is working again.
                        Like you I also prefer the UI and plots produced by plot.ly but I'm not convinced by the reliability so far.
                        • Tomas
                        • HoffanH
                          HoffanH
                          Hoffan
                          Hi Guys
                          How much work is it in Plot.ly to get in to work
                          Becuase i test to Copy the examples upper here and put my INFO in the text
                          But nothing happens, Must i change a lot of thing on the Plot.ly page
                            I share your concern. It has been a bumpy ride. If it weren't for the pan and zoom UI, I would have tried switching to another free service.
                            • HoffanH
                              HoffanH
                              Hoffan
                              Any one that can explain for me how to get plot.ly to work, I really don't get it :(
                              • korttomaK
                                korttomaK
                                korttoma
                                @Hoffan if you have an APIKey and username from plot.ly all you need to do is to change the following from the first post in this thread:
                                ("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 83) If you don't know what this should be let me know so I can explain further.
                                <username>
                                <APIKey>
                                <nameForGraph>
                                <graphTitle>
                                You should make sure you remove all the < >
                                Also I noticed that you can only have one private graph so if you already have one the second one will not get created.
                                Try changing "world_readable":false to "world_readable":true
                                Now test your lua code from apps -> develop apps -> test loop code (lua). Do you get any errors?
                                • Tomas
                                • HoffanH
                                  HoffanH
                                  Hoffan
                                  @korttoma
                                  So if i understand this right, If i have a User and a APIKey, i dont need to do
                                  anything on plot.ly page
                                  I will test to change false to True when i get back home tonight :)
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    @Hoffan no you should not need to change anything at plot.ly your graph should just appear among "YOUR RECENT FILES" on the right when you go to "https://plot.ly/".
                                    • Tomas
                                    • HoffanH
                                      HoffanH
                                      Hoffan
                                      @korttoma
                                      Big thanks. Now its working :)
                                        samppa
                                        It seems that plot.ly has new limitations to the free API in their price plan:
                                        • Only one free private graph
                                        • API rate limits: 50 per day or 30 per hour
                                        Then you have to pay 20 USD/month to get unlimited access.
                                        Damn. There goes the cheap solution.
                                        NuubiN 1 Reply Last reply
                                        • S samppa
                                          NuubiN
                                          NuubiN
                                          Nuubi
                                          @samppa Yeah, one another, again. Personally, started with Pachube a few years ago. Gone, a long time ago.
