  3. [SOLVED]ESP8266_MQTT gate RFM69 not communicate with node
6 Posts 4 Posters 1.6k Views 4 Watching
  • W Offline
    W Offline
    wanvo
    wrote on last edited by wanvo
    Hi guys.
    I loaded the following code into my gate
    //#define MY_BAUD_RATE 9600
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    //#define MY_RFM69_FREQUENCY   RF69_868MHZ
    #define MY_RFM69_NEW_DRIVER
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    // Set WIFI SSID and password
    //#define MY_ESP8266_SSID "OrPiZero"
    //#define MY_ESP8266_PASSWORD "orangepi"
    #define MY_ESP8266_SSID "wanvo"
    #define MY_ESP8266_PASSWORD "merkulovanastya"
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    // MQTT broker ip address.
    //#define MY_CONTROLLER_IP_ADDRESS 10, 0, 0, 1
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 107
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    #include <ESP8266WiFi.h>
        Serial.setDebugOutput(true);
    	// Send locally attech sensors data here
    And the gate does not try to search for nodes. This is what I get from the serial debugger
    MCO:BGN:INIT GW,CP=RPNGE---,VER=2.2.0-rc.2
    238 TSF:LRT:OK
    240 TSM:INIT
    241 TSF:WUR:MS=0
    242 RFM69:INIT
    243 RFM69:INIT:PIN,CS=15,IQP=2,IQN=2
    247 RFM69:PTX:LEVEL=5 dBm
    250 TSM:INIT:TSP OK
    251 TSM:INIT:GW MODE
    253 TSM:READY:ID=0,PAR=0,DIS=0
    256 MCO:REG:NOT NEEDED
    scandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with wanvo, channel 7
    dhcp client start...
    761 .ip:192.168.0.106,mask:255.255.255.0,gw:192.168.0.1
    1261 .1261 IP: 192.168.0.106
    1263 MCO:BGN:STP
    1265 MCO:BGN:INIT OK,TSP=1
    1267 IP: 192.168.0.106
    1269 Attempting MQTT connection...
    2275 MQTT connected
    2277 Sending message on topic: mygateway1-out/0/255/0/0/18
    pm open,type:2 0
    Noda is on, but does not see the gate.
    Tell me, what is the reason for this behavior of the gate?
    • W wanvo
      Hi guys.
      238 TSF:LRT:OK
      240 TSM:INIT
      241 TSF:WUR:MS=0
      242 RFM69:INIT
      250 TSM:INIT:TSP OK
      scandone
      f 0, scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 5
      cnt
      1263 MCO:BGN:STP
      2275 MQTT connected
      pm open,type:2 0
      Welcome to the MySensors community @wanvo !
      A gateway will never scan for nodes. The output you posted is looks normal.
      Could you post the output of your node?
      • W Offline
        W Offline
        wanvo
        My Node out
         __  __       ____
                |___/                      2.2.0-rc.2
        18 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0-rc.2
        28 TSM:INIT
        28 TSF:WUR:MS=0
        32 TSM:INIT:TSP OK
        34 TSM:INIT:STATID=1
        36 TSF:SID:OK,ID=1
        38 TSM:FPAR
        1038 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        3045 !TSM:FPAR:NO REPLY
        3047 TSM:FPAR
        4050 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6060 !TSM:FPAR:NO REPLY
        6062 TSM:FPAR
        7065 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        9072 !TSM:FPAR:NO REPLY
        9074 TSM:FPAR
        10076 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        12083 !TSM:FPAR:FAIL
        12085 TSM:FAIL:CNT=1
        12087 TSM:FAIL:DIS
        12089 TSF:TDI:TSL
        22093 TSM:FAIL:RE-INIT
        22095 TSM:INIT
        22097 TSM:INIT:TSP OK
        22099 TSM:INIT:STATID=1
        22104 TSF:SID:OK,ID=1
        22106 TSM:FPAR
        23109 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        25116 !TSM:FPAR:NO REPLY
        25118 TSM:FPAR
        26120 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        28127 !TSM:FPAR:NO REPLY
        I checked this node with the gate OrangePiZero MQTT
        and the RF69 module on this gate was the same as on the ESP8266. Everything worked well.
        M 1 Reply Last reply
          Double check the wiring as the gateway is not receiving anything
          • W wanvo
            My Node out
             __  __       ____
                    |___/                      2.2.0-rc.2
            28 TSM:INIT
            28 TSF:WUR:MS=0
            32 TSM:INIT:TSP OK
            36 TSF:SID:OK,ID=1
            38 TSM:FPAR
            3047 TSM:FPAR
            6062 TSM:FPAR
            9074 TSM:FPAR
            12087 TSM:FAIL:DIS
            12089 TSF:TDI:TSL
            22095 TSM:INIT
            22106 TSM:FPAR
            25118 TSM:FPAR
            M Offline
            M Offline
            manutremo
            @wanvo I agree with gohan, check the wiring in the node.
            Don't take this as 100% sure but just as a hint - I think the fact that the node is showing TSP OK points in the direction that the IRQ wire might not be connected properly. I think that if the ones failing are the power wires or the SPI interface wires, you'd see a TSP fail message. Nothing wrong with checking all of them of course.
            • W Offline
              W Offline
              wanvo
              Thanks to all.
              The problem is solved.
              I forgot to add pin definitions to the sketch.
              #define MY_RF69_IRQ_PIN D1
              #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
              #define MY_RF69_SPI_CS D8 // NSS. Use MY_RFM69_CS_PIN for the development branch.```
