  3. With MySensors PC cold start!
6 Posts 4 Posters 2.1k Views 3 Watching
  • W
    W
    Wuffi0815
    Can someone help me or write a sketch?
    I would like to start my PC using Arduino, shutdown and reset!
    On a normal PC you connect so only pin against the desired mode.
    Pin 1 - mass short passage = PC starts
    Pin 1 - Ground Long Pass Approx. 5sec = PC Shuts down
    Pin 2 - Ground Short Circuit = PC Reset
    A little I have already prepared. I have to search for everything and I do not know the language that way.
    Thank you
    #define MY_NODE_ID AUTO
    #define MY_REPEATER_FEATURE
    #define PULSE_TIME 500UL  // half a second
    boolean goPulse;
    unsigned long pulseStartTime;
    #define RELAY_PIN_A 4
    #define RELAY_PIN_B 5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
        for (int sensor=1, pin=RELAY_PIN_A; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
        for (int sensor=1, pin=RELAY_PIN_B; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            present(sensor, S_BINARY);
        if (message.type==V_STATUS)
            // Change relay state
            digitalWrite(message.sensor-1+RELAY_PIN_A, message.getBool()?RELAY_ON:RELAY_OFF);
            goPulse = true;
            pulseStartTime = millis();
            digitalWrite(message.sensor-1+RELAY_PIN_B, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
        relayPulse();
    void relayPulse()
      if (goPulse)
        if (millis() - pulseStartTime < PULSE_TIME)
          digitalWrite(RELAY_PIN_A, RELAY_OFF);// didn't know your pin
        else
          digitalWrite(RELAY_PIN_B, RELAY_OFF); // didn't know your pin
          goPulse = false;
      I think you messed up the code. BTW, why do you want to force power off on a computer?
      W 1 Reply Last reply
        W
        W
        Wuffi0815
        @gohan
        Should run as a server. If remote access fails.
        Just needed a sketch that allowed me to control 3 different relays.
        Or. As template
        • H
          H
          hard-shovel
          The pins on the sketch and the schematic do not match,
          You need to be more careful on matching the items as it will make troubleshooting more difficult.
          This sketch is a quick and dirty method, that does basically to work for me using OpenHAB as a controller. (only tested using LED outputs not with an actual computer).
          If i was actually going to implement this, I would monitor the POWER LED on the computer for feedback and control of the pulses. ie for shutdown, try short pulse first for controlled shutdown and if not shutdown within expected time span, then preform a hard shutdown.
           * PC Power On/Off & Reset Sketch
           *  Power Pin Pulse         = PC Starts if Already Off,     *** PC Shutsdown if already on   ## this is the operation of my Computer ##
           *  Power Pin 5 Seconds Low = PC Forced Shutdown
           *  Reset Pin Pulse Low     = PC Reset (if already on)
           *  Using three child IDs
           *  1 = Power On/Off
           *  2 = Forced OFF
           *  3 = Reset
           *  Version 1.0 2018-01-19
           * Version 1.0 - Henrik Ekblad
          //#define MY_NODE_ID AUTO
          #define MY_NODE_ID 155            // my test Node ID,  Comment out for Auto ID
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          #define MY_REPEATER_FEATURE   // if you need the repeater function uncomment
          // Wait times
          #define LONG_WAIT 500
          #define SHORT_WAIT 50
          #define FORCED_TIME 5000UL    // 5 seconds
          boolean goPulse;
          #define POWER_PIN   4         // Arduino Digital I/O pin number for PC Power control
          #define RESET_PIN   5         // Arduino Digital I/O pin number for PC Reset control
          #define CHILD_ID_POWER       143        // these ID used for my test machine.   change to suit ie 1
          #define CHILD_ID_FORCEDOFF   144        // change to suit ie 2
          #define CHILD_ID_RESET       145        // change to suit ie 3
          boolean Status_Power      =  0;
          boolean Status_Forcedoff  =  0;
          boolean Status_Reset      =  0;
          boolean is_Power          =  0;
          boolean is_ForcedOff      =  0;
          boolean is_Reset          =  0;
          // Setup Messages
          MyMessage msg(CHILD_ID_POWER,V_STATUS);
          void before() {
            //  Set the pins to output mode
              pinMode(POWER_PIN, OUTPUT);
              pinMode(RESET_PIN, OUTPUT);
            //  Set the Pin states to known state
              digitalWrite(POWER_PIN, RELAY_OFF);
              digitalWrite(RESET_PIN, RELAY_OFF);
          void presentation() {
              wait(LONG_WAIT);        // Give gateway time to Process
          // Present child ids to conroller
              present(CHILD_ID_POWER, S_BINARY, "PC Power on-off");
              wait(SHORT_WAIT);        // Give gateway time to Process
              present(CHILD_ID_FORCEDOFF, S_BINARY, "PC Forced off");
              present(CHILD_ID_RESET, S_BINARY, "PC Reset");
          Serial.println();
          Serial.print ("loop start ");
          send(msg.setSensor(CHILD_ID_POWER).set( Status_Power));
          send(msg.setSensor(CHILD_ID_FORCEDOFF).set( Status_Forcedoff));
          send(msg.setSensor(CHILD_ID_RESET).set( Status_Reset));
          wait(100000);        // wait for testing
              switch (message.sensor) {
              case CHILD_ID_POWER:
                is_Power = message.getBool();
                Serial.print("incoming change for Power:");
                Serial.println((is_Power ? "On":"Off"));
                powercmd();        // process pulses etc in subroutine
                break;
              case CHILD_ID_FORCEDOFF:
                is_ForcedOff = message.getBool();
                Serial.print("incoming change for FORCED Power OFF:");
                Serial.println((is_ForcedOff ? "On":"Off"));
                forcedcmd();
                break;
              case CHILD_ID_RESET :
                is_Reset = message.getBool();
                Serial.print("incoming change for Reset:");
                Serial.println((is_Reset ? "On":"Off"));
                resetcmd();
                break;
              default:
                Serial.print("Unknown/UnImplemented message type: ");
                Serial.println(message.type);
          void powercmd() {
            // process power pin
            if (is_Power != Status_Power) {
              digitalWrite(POWER_PIN, RELAY_ON);
              delay(PULSE_TIME);          // delay used as pulse time is short & multiple processes are not expected
              Status_Power = is_Power;
          void forcedcmd() {
            // process forced power off command
              if (is_ForcedOff = 1 ) {
              delay(FORCED_TIME);          // delay used as multiple processes are not expected, quick and dirty
              Status_Forcedoff = 0;          // reset status for next time
              Status_Power =  0;          // power status also reset if power shutoff
          void resetcmd() {
            // process reset command
            if (is_Reset != 1 ) {
              digitalWrite(RESET_PIN, RELAY_ON);
              delay(PULSE_TIME);          // delay used as multiple processes are not expected, quick and dirty
              Status_Reset = 0;
          • H hard-shovel
             *  1 = Power On/Off
             *  2 = Forced OFF
             *  3 = Reset
            // Wait times
            boolean goPulse;
            // Setup Messages
            void before() {
            Serial.println();
                  break;
                  forcedcmd();
                  break;
                  resetcmd();
                  break;
                default:
            void powercmd() {
            void forcedcmd() {
            void resetcmd() {
                Status_Reset = 0;
            W
            W
            Wuffi0815
            @hard-shovel
            Works great thanks.
            Except the reset pin does not work that changed
            if (is_Reset = 1 )
            M 1 Reply Last reply
            • W Wuffi0815
              @hard-shovel
              Works great thanks.
              if (is_Reset = 1 )
              mickecarlsson
              wrote on last edited by mickecarlsson
              Yoy need to have two = in the code
              if (is_Reset == 1 )
