Unable to get MySensors sensors to Work with MyController running on RPi
I am running MyController on a Raspberry Pi and I have built a simple MySensors temperature and humidity sensor using the DHT-11 and an Arduino Pro Mini.
I have the serial gateway setup and I believe it is working, as it does "communicate" with my node but strange things are happening and the Sensor data is not updating.
For example, when I add the MySensors Temperature sensor node by pressing "Reset", it automatically registers 2 Nodes in MyController, one with ID 0 and another with ID 1.
The node with ID 0 "connects" itself to the gateway, as you can see here in the topology:
topologyThe node with ID 1, the TemperatureandHumidity node with the actual sensors registered to it, does not "connect" to the gateway.
Here is my gateway:
Here is what the node page looks like: node page
And the sensor page: sensors
Here's my serial output from the sensor:
0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1 3 TSM:INIT 4 TSF:WUR:MS=0 11 TSM:INIT:TSP OK 13 TSF:SID:OK,ID=1 14 TSM:FPAR 51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 940 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0 945 TSF:MSG:FPAR OK,ID=0,D=1 2058 TSM:FPAR:OK 2059 TSM:ID 2060 TSM:ID:OK 2062 TSM:UPL 2065 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2074 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2079 TSF:MSG:PONG RECV,HP=1 2081 TSM:UPL:OK 2083 TSM:READY:ID=1,PAR=0,DIS=1 2088 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 2095 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 2102 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1 2110 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 2122 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M 2130 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:TemperatureAndHumidity 2141 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1 2148 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2156 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK: 2161 MCO:REG:REQ 2165 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2 2171 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1 2177 MCO:PIM:NODE REG=1 2179 MCO:BGN:STP 2182 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255 2187 MCO:SLP:TPD 2188 MCO:SLP:WUP=-1 2190 MCO:BGN:INIT OK,TSP=1 2216 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.0 T: 21.00 2225 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:47.0 H: 47.00 2232 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2237 MCO:SLP:TPD 2239 MCO:SLP:WUP=-1 2263 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2268 MCO:SLP:TPD 2269 MCO:SLP:WUP=-1 2293 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2298 MCO:SLP:TPD 2299 MCO:SLP:WUP=-1 2323 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2328 MCO:SLP:TPD 2330 MCO:SLP:WUP=-1 2354 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2359 MCO:SLP:TPD 2361 MCO:SLP:WUP=-1 2384 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2390 MCO:SLP:TPD 2392 MCO:SLP:WUP=-1 2415 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2420 MCO:SLP:TPD 2422 MCO:SLP:WUP=-1 2446 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2451 MCO:SLP:TPD 2452 MCO:SLP:WUP=-1 2477 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2482 MCO:SLP:TPD 2483 MCO:SLP:WUP=-1 2506 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2511 MCO:SLP:TPD 2513 MCO:SLP:WUP=-1 2537 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2542 MCO:SLP:TPD 2544 MCO:SLP:WUP=-1 2570 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.0 T: 21.00 2579 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:47.0 H: 47.00 2585 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2590 MCO:SLP:TPD 2592 MCO:SLP:WUP=-1 2618 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:48.0 H: 48.00 2625 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2630 MCO:SLP:TPD 2632 MCO:SLP:WUP=-1 2656 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2661 MCO:SLP:TPD 2662 MCO:SLP:WUP=-1 2685 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2691 MCO:SLP:TPD 2693 MCO:SLP:WUP=-1 2716 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2721 MCO:SLP:TPD 2723 MCO:SLP:WUP=-1 2749 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:47.0 H: 47.00 2756 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2761 MCO:SLP:TPD 2763 MCO:SLP:WUP=-1 2787 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2792 MCO:SLP:TPD 2793 MCO:SLP:WUP=-1 2818 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2823 MCO:SLP:TPD 2824 MCO:SLP:WUP=-1 2847 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2852 MCO:SLP:TPD 2854 MCO:SLP:WUP=-1 2878 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2883 MCO:SLP:TPD 2885 MCO:SLP:WUP=-1 2909 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2914 MCO:SLP:TPD 2916 MCO:SLP:WUP=-1 2941 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.0 T: 21.00 2951 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:46.0 H: 46.00 2957 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2962 MCO:SLP:TPD 2964 MCO:SLP:WUP=-1 2988 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 2993 MCO:SLP:TPD 2995 MCO:SLP:WUP=-1 3018 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 3023 MCO:SLP:TPD 3024 MCO:SLP:WUP=-1 3049 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 3054 MCO:SLP:TPD 3055 MCO:SLP:WUP=-1 3080 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 3085 MCO:SLP:TPD 3086 MCO:SLP:WUP=-1 3109 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 3115 MCO:SLP:TPD 3117 MCO:SLP:WUP=-1 3140 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 3145 MCO:SLP:TPD 3147 MCO:SLP:WUP=-1 3171 MCO:SLP:MS=25000,SMS=0,I1=255,M1=255,I2=255,M2=255 3176 MCO:SLP:TPDThe resource logs in MyController are empty, but I may have the log level set incorrectly.
Any guidance or help anyone can provide me is greatly appreciated.
