  3. MQTT Gateway Disconnects from Broker
4 Posts 2 Posters 1.0k Views 2 Watching
  • SoloamS
    SoloamS
    Soloam
    I'm having a problem with my MQTT gateway, it keeps connecting and disconnecting from my MQTT broker. This problem is solved when I restart the mosquitto server, only to come back again some time later...
    This is my MQTT topics
    mygateway1-out/0/255/0/0/18 2.1.1
    mygateway1-out/100/0/1/0/1 42.0
    mygateway1-out/100/0/1/0/1 41.0
    mygateway1-out/100/1/1/0/0 19.0
    This output is only from more or less 5 min, At this time the service is unusable. I have to restart it to regain control.
    Thank You
    • SoloamS Soloam
      Thank You
      @soloam what type of gateway is this? (esp8266, wiznet, etc). How is it powered (most common problem is restarts due to insufficient power). What does the gateway debug log say?
      • SoloamS
        SoloamS
        Soloam
        I'm trying to get a Log to show, but when I unplug the GW to plug it to the pc to get the serial console, I lose the error.
        This is a Arduino Mini powerd by a mobile phone charger with a W5100.
        Thank You
        • SoloamS Soloam
          Thank You
          @soloam you can connect the ftdi and the charger at the same time. Just skip connecting Vcc from the ftdi.
