  3. Raspberry Pi with openHAB and nRF24L01
7 Posts 2 Posters 2.8k Views 2 Watching
  • Z
    Z
    zombiee77
    Hello Forum,
    I am using the latest openHAB ( 2.2.0-1) and Arduino IDE 1.8.5!
    I installed the openHABian on the RPi and attached the NRF24 (with this description: https://www.mysensors.org/build/raspberry). I also installed the MySensors ans described in the link.
    I also installed a programm to the arduino (https://www.mysensors.org/build/binary). The Arduino has also a NRF24 attached.
    I have started the serial monitor in the Arduino IDE to see, what's happening in the Arduino:
    | / |_ / | ___ _ __ ___ ___ _ __ ___
    | |/| | | | _
    \ / _ \ _ \/ __|/ _ \|
    _/ __|
    | || | / | | _ \ _ | | _
    |_
    , |/ ___|| ||/_/|| |/
    __/ 2.2.0
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:FPAR
    40 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    249 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    256 TSF:MSG:FPAR OK,ID=0,D=1
    2048 TSM:FPAR:OK
    2048 TSM:ID
    2050 TSM:ID:REQ
    2054 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4061 TSM:ID
    4061 TSM:ID:REQ
    4065 TSF:MSG:SEND,255-255-0-0,s=221,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6072 TSM:ID
    6072 TSM:ID:REQ
    6076 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8083 TSM:ID
    8083 TSM:ID:REQ
    8087 TSF:MSG:SEND,255-255-0-0,s=147,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10094 !TSM:ID:FAIL
    10096 TSM:FAIL:CNT=1
    10098 TSM:FAIL:DIS
    10100 TSF:TDI:TSL
    This looks for me OK, but I am not pretty sure.
    Now I would like to anyhow see on the RPi, that there is a connection. But since I am total newbie, I would like to ask the forum for help.
    First question:
    How can I see on th RPi, that there is a connection between the Arduino node and the RPi?
    Second question:
    How can I bring this into openHAB?
    I would love to read meaningful answers.
    Thank you
    z
      you forgot to add node id to the node
      • Z
        Z
        zombiee77
        Hi Gohan,
        Thank you for the fast reply.
        I thought, I gave an ID:
        #define CHILD_ID 3
        BY the way, Do the Gateway also needs an ID?
        And where to Define?
        Kind regs from germany
        Z
          You have to use MY_NODE_ID, child ID is for the sensors. Gateway is always 0, no need to specify it.
          Z 1 Reply Last reply
            Z
            Z
            zombiee77
            @gohan said in Raspberry Pi with openHAB and nRF24L01:
            MY_NODE_ID
            with
            #define MY_NODE_ID 1
            it works now!!!
            Thank you so much gohan.
            Which FAQ or HowTo I have missed to know this?
              https://www.mysensors.org/download/sensor_api_20
                Z
                Z
                zombiee77
                @gohan THANX!!!
