Anyone tried the Creality CR-10 3D printer?
I also printed a Benchie in translucent PLA at 0.1mm layer height using the volcano, and it came out very smooth:
So, overall, it has pretty good dynamic range. -
@neverdie If you have an E3D V6, then you are running a J-Head.
Not sure exactly why they call it a J-Head as it looks nothing like a J shape...I assume you just swapped out the heat block? The Volcanos are like a standard heat block only stood on end.
https://www.amazon.com/J-head-Hotend-Filament-Extruder-Printer/dp/B010MSTVZO
@dbemowsk said in Anyone tried the Creality CR-10 3D printer?:
Yes, that and using the longer nozzle that matches it.
Thought I'd share a couple cool things I've learned recently.
One is that meshmixer offers treelike supports, which is pretty cool, and it's free:
You can import your model and just add the supports without using the rest of meshmixer, if that's all you want. That's how I plan to use it.The other is that if you want to print faster, but with good print quality, you should definitely look into linear advance.
https://www.youtube.com/watch?v=c5jjwBqARpo&t=255sAnyone else learned anything cool lately?
