  3. Anyone tried the Creality CR-10 3D printer?
104 Posts 12 Posters 33.1k Views 10 Watching
    What layer hight did you use?
    dbemowskD 1 Reply Last reply
      dbemowskD
      dbemowskD
      @gohan Sound like it was a gcode file on the SD card, so my guess is that he didn't slice it and may not know.
      gohanG 1 Reply Last reply
      • dbemowskD
        dbemowskD
        A note though if you are looking at choosing a slicer. For most of the time that I owned my 3D printer I was using Cura as my slicer. I have recently done some things using Slic3r and I find that it has a lot more options and does an overall better job at slicing. I also recommend a rapberry pi running octoprint.
        NeverDieN 1 Reply Last reply
        • dbemowskD dbemowsk
          NeverDieN
          NeverDieN
          @dbemowsk Presently using https://prusacontrol.org/ , which is a simplified version aimed at fresh noobs like me. I used it to generate the gcode for the Andreas Spiess power meter case (referenced above).,
          • NeverDieN
            NeverDieN
            #85
            Are any of the available printer filaments odor free? The free roll of Prusa PLA that came with my kit doesn't smell very good when printing with it.
            I just now ordered: https://www.amazon.com/gp/product/B00MB3CV6K/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
            which claims to be "odor free." Well, here's hoping it is. ;)
            dbemowskD NeverDieN 2 Replies Last reply
            • NeverDieN NeverDie
              dbemowskD
              dbemowskD
              @neverdie said in Anyone tried the Creality CR-10 3D printer?:
              I myself have not tried any that are completely odor free. I haven't had too much trouble with the PLA that I have used, and I have tried a number of different brands. ABS smells a lot worse than PLA.
                @dbemowsk I was referring to the box he was printing, maybe a thicker layer would cut the print time since he doesn't need to have fine details on the box
                  dbemowskD
                  dbemowskD
                  @gohan I see. I thought you were referring to his benchy.
                  • E
                    E
                    executivul
                    PLA smells like hot popcorn/cooking oil, it's corn based afterall
                    ABS smells bad and it's a little toxic
                    PETG is almost odourless, very resistent, easy to print, doesn't warp or shrink when cooling
                    Best slicer: Simplify3D
                    • scalzS
                      scalzS
                      wrote on last edited by scalz
                      #90
                      PETG and PLA are easier to print. PLA is easier, but PETG is not hard to use, just need a few changes on settings for speed etc.
                      I use simplify3d too :)
                      Note:
                      • when you buy new filament rolls, it's good to check the thickness with caliper and calibrate your slicer for that. It can improve results
                      • better use different nozzles. one for PLA, and one for PETG. they don't melt at same temperature.
                        So if you melt PETG and then would like to use PLA, then you could get clogging because of PETG residue not melting at PLA temperature.
                      • when sourcing parts on aliexpress for heatbreak etc (spare parts etc), it's good to remachine them. it can be a source of clogging too. They are not same quality as if you ordered them from e3d for example..
                      • E executivul
                        dbemowskD
                        dbemowskD
                        @executivul Doesn't Simplify3D cost $$$ though? Slic3r is free.
                        E 1 Reply Last reply
                          E
                          E
                          executivul
                          @dbemowsk said in Anyone tried the Creality CR-10 3D printer?:
                          Unfortunately for them it does, but we know a guy...
                          • E executivul
                            dbemowskD
                            dbemowskD
                            @executivul said in Anyone tried the Creality CR-10 3D printer?:
                            Never a bad thing...
                            • NeverDieN
                              NeverDieN
                              #94
                              Worth mentioning: in fooling around with the Prusa slicer, I noticed that the estimated print times for the I3 MK3 are almost half of what they are for the I3 MK2. I presume that can be attributed to the Trinamic driver chips and also, possibly, Prusa's custom firmware's ability to effectively exploit them. Not sure as to whether or not Marlin can yet do the same.
                                NeverDieN
                                NeverDieN
                                I tried it, and indeed it seems to have no odor. Hopefully (?) it's also not giving off any emissions that I can't smell either.
                                • NeverDieN
                                  NeverDieN
                                  #96
                                  I upgraded my Prusa I3 MK3 to use a Volcano with a 0.8mm nozzle. Now I can print a Benchie in 16 minutes!
                                  https://www.thingiverse.com/thing:763622
                                  For enclosures, the relative speed improvement should be even more noticeable.
                                    dbemowskD
                                    dbemowskD
                                    @neverdie Are you using an E3D J-Head with your Volcano hot end? I am in the process of working on an E3D clone J-Head setup with a Bowden extruder, but I went with the standard heat block and not the Volcano.
                                      NeverDieN
                                      NeverDieN
                                      @dbemowsk All I did was swap the E3D V6 hot-end for the volcano hot end.
                                      What is a J-Head?
                                      • NeverDieN
                                        NeverDieN
                                        I also printed a Benchie in translucent PLA at 0.1mm layer height using the volcano, and it came out very smooth:
                                        So, overall, it has pretty good dynamic range.
                                          What is a J-Head?
                                          dbemowskD
                                          dbemowskD
                                          #100
                                          @neverdie If you have an E3D V6, then you are running a J-Head.
                                          Not sure exactly why they call it a J-Head as it looks nothing like a J shape...
                                          I assume you just swapped out the heat block? The Volcanos are like a standard heat block only stood on end.
                                          https://www.amazon.com/J-head-Hotend-Filament-Extruder-Printer/dp/B010MSTVZO
