Connecting PROMICRO & NRF24L01 ?
Can any body help
I try to connect PROMICRO 3.3V & NRF24L01
Connect of NRF pins:
- SCK <> 15pin
- MISO <> 14pin
- MOSI <> 16pin
- CSN <> 10pin
- CE <> 9pin
- VCC to 3.3v line
- GND to GND
Load simple example Air Humidity Sensor
But get errors
2640406 TSM:FAIL:RE-INIT 2640406 TSM:INIT 2640412 !TSM:INIT:TSP FAIL 2640412 TSM:FAIL:CNT=7 2640413 TSM:FAIL:DIS 2640413 TSF:TDI:TSLWhat i do wrong?
Can any body help
- SCK <> 15pin
- MISO <> 14pin
- MOSI <> 16pin
- CSN <> 10pin
- CE <> 9pin
- VCC to 3.3v line
- GND to GND
But get errors
Just change to ProMini 328P
and al ok__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.2.0 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0 25 TSM:INIT 26 TSF:WUR:MS=0 33 TSM:INIT:TSP OK 35 TSF:SID:OK,ID=5 37 TSM:FPAR 73 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 900 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0 905 TSF:MSG:FPAR OK,ID=0,D=1 2080 TSM:FPAR:OK 2081 TSM:ID 2082 TSM:ID:OK 2084 TSM:UPL 2087 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 4096 TSM:UPL 4098 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 6106 TSM:UPL 6108 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 8116 TSM:UPL 8118 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 -
Any solution for PRO MICRO ?
