  3. New 2.2.0 Signal report function
14 Posts 6 Posters 6.3k Views 8 Watching
  • P Offline
    P Offline
    peerv
    How can I implement the new 2.2.0 function
    #define MY_SIGNAL_REPORT_ENABLED
    Should it be defined in the node and/or the gateway?
    Can it be used with NRF24?
    How is the RSSI value reported?
    Could not find a writeup on this new function.
      https://forum.mysensors.org/topic/7822/portable-rfm69-signal-scanner/6
      It works only for RFM69 and I didn't need to add the define you mentioned
      • F Offline
        F Offline
        flopp
        wrote on last edited by flopp
        I tried to send RSSI with nRF and it seemed to work, I could get a value that was changing if I moved away from Gateway.
        i was using this variable, transportGetSignalReport(SR_TX_RSSI)
        so to send the RSSI create a Child, I think you can pick anyone that can handle value from 0-1024 then use below message to send the value
        send(RSSIMsg.set(transportGetSignalReport(SR_TX_RSSI)));
        I am using Domoticz as Controller
          I'll give it a try
          • F Offline
            F Offline
            flopp
            I just now found some other maybe interested variables
            transportGetReceivingRSSI()
            transportGetSendingRSSI()
            transportGetReceivingSNR()
            transportGetSendingSNR()
            transportGetTxPowerLevel()
            transportGetTxPowerPercent()
            transportInternalToRSSI(_transportSM.uplinkQualityRSSI)
            i have not tested anyone of them, but it seems that "transportGetSendingRSSI()" will give same result as "transportGetSignalReport(SR_TX_RSSI)"
            so the message may look like this instead
            send(RSSIMsg.set(transportGetSendingRSSI()));
              It's similar to the signal scanner code I used but I did not know it was working on nrf24
              • slingS Offline
                slingS Offline
                sling
                Very useful new feature.
                I learned a lesson: I'll be using the nrf24 without booster from now on. Much better range and commmunication.
                output from nrf24 with radio set to LOW:
                -256 :transportGetReceivingRSSI()
                -29 :transportGetSendingRSSI()
                -256 :transportGetReceivingSNR()
                -256 :transportGetSendingSNR()
                -12 :transportGetTxPowerLevel()
                25 :transportGetTxPowerPercent()
                0 :transportInternalToRSSI(_transportSM.uplinkQualityRSSI)
                  How did you make the tests?
                  • slingS Offline
                    slingS Offline
                    sling
                    I added this to my sketch and observed serial output:
                    Serial.print(transportGetReceivingRSSI()); Serial.println(" :transportGetReceivingRSSI()");
                    Serial.print(transportGetSendingRSSI()); Serial.println(" :transportGetSendingRSSI()");
                    Serial.print(transportGetReceivingSNR()); Serial.println(" :transportGetReceivingSNR()");
                    Serial.print(transportGetSendingSNR()); Serial.println(" :transportGetSendingSNR()");
                    Serial.print(transportGetTxPowerLevel()); Serial.println(" :transportGetTxPowerLevel()");
                    Serial.print(transportGetTxPowerPercent()); Serial.println(" :transportGetTxPowerPercent()");
                    Serial.print(transportInternalToRSSI(_transportSM.uplinkQualityRSSI));Serial.println(" :transportInternalToRSSI(_transportSM.uplinkQualityRSSI)");
                    I don't know if it's a valid way to check the values.
                    • jumpingJ Offline
                      jumpingJ Offline
                      jumping
                      the NRF24l01 doesn't have a RSSI function as reported in Nordic datasheet, so how can the signal report work?
                      thanks
                      Raspberrry PI3 - Domoticz
                      ESP8266 GW - MySensors 2.1.1
                      • jumpingJ jumping
                        thanks
                        @jumping it doesn't :-)
                        See https://github.com/mysensors/MySensors/blob/57eca4f4afb3a26f4ef0ec10d522ac062de4d101/hal/transport/RF24/MyTransportRF24.cpp#L176
                        int16_t transportGetReceivingRSSI(void)
                        	// not available, only bool RPD
                        	return INVALID_RSSI;
                        int16_t transportGetSendingSNR(void)
                        	return INVALID_SNR;
                        int16_t transportGetReceivingSNR(void)
                        	return INVALID_SNR;
                        and
                        https://github.com/mysensors/MySensors/blob/6794c72ecd8c35c1a7587f73996d50c347b17f93/hal/transport/MyTransportHAL.h#L23
                        #define INVALID_SNR         ((int16_t)-256)	//!< INVALID_SNR
                        #define INVALID_RSSI        ((int16_t)-256)	//!< INVALID_RSSI
                        #define INVALID_PERCENT     ((int16_t)-100)	//!< INVALID_PERCENT
                        #define INVALID_LEVEL ((int16_t)-256) //!< INVALID_LEVEL
                        jumpingJ 1 Reply Last reply
                          	return INVALID_SNR;
                          	return INVALID_SNR;
                          and
                          jumpingJ Offline
                          jumpingJ Offline
                          jumping
                          @mfalkvidd thanks for your answer, can you tell me what is the RF24_getSendingRSSI?
                          int16_t transportGetSendingRSSI(void)
                          	return RF24_getSendingRSSI();
                          • jumpingJ jumping
                            @jumping github has a great search function if you want to get the answer quicker next time. :-)
                            Implementation: https://github.com/mysensors/MySensors/blob/345d6d7d119f5d2446c7d6a41e6f749e6ca8741c/drivers/RF24/RF24.cpp#L401
                            • jumpingJ Offline
                              jumpingJ Offline
                              jumping
                              thanks, next time I will use the github search function :-) :+1:
