  2. Feature Requests
  3. Additional sleep methods with array of pins as parameters ?
24 Posts 5 Posters 6.0k Views 5 Watching
  • Nca78N Nca78
    @yveaux said in Additional sleep methods with array of pins as parameters ?:
    Yes, they have to set it to input. There's no pin configuration in the (AVR) sleep code: https://github.com/mysensors/MySensors/blob/development/hal/architecture/AVR/MyHwAVR.cpp#L153
    But atmega pins default as inputs so it's not really mandatory with the default IC.
    YveauxY
    YveauxY
    #21
    @nca78 said in Additional sleep methods with array of pins as parameters ?:
    I like to make things explicit, especially if you decide to port to another architecture later on
    Nca78N 1 Reply Last reply
    • YveauxY Yveaux
      Nca78N
      Nca78N
      I like to make things explicit, especially if you decide to port to another architecture layer on
      I completely agree with you. Just stating that @mfalkvidd is not wrong when saying at the moment it's not necessary to declare pins as inputs
      To go back to the main subject should I make a first version of this code (in post 9) to have a clearer basis for future discussions ? Or am I going a wrong way ?
      • NeverDieN
        NeverDieN
        Anything is always better than nothing.
        • YveauxY Yveaux
          @mfalkvidd said in Additional sleep methods with array of pins as parameters ?:
          I don’t think sketch developer should need to worry about setting the pin to input,
          @yveaux clarification: imho, if support for many interrupts is added in a future version of MySensors (which is what we're discussing in this thread), sketch developers should not need to manually call pinMode.
