mysgw MQTT Issues
Hello to all,
I'm having issues with the only node in RF69 I've actually installed.
Switched to RPi and radio connected as MQTT server I'm getting this:mysgw: Starting gateway... mysgw: Protocol version - 2.2.1-alpha mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.1-alpha mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: GWT:RMQ:MQTT RECONNECT mysgw: connected to 192.168.1.50 mysgw: GWT:RMQ:MQTT CONNECTED mysgw: GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:PNG:SEND,TO=0 mysgw: TSF:CKU:OK mysgw: TSF:MSG:GWL OK mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:CKU:OK,FCTRL mysgw: TSF:MSG:GWL OK mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:CKU:OK,FCTRL mysgw: TSF:MSG:GWL OK mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:CKU:OK,FCTRL mysgw: TSF:MSG:GWL OKIs this
!TSFcausing me the issues not getting any informations from the node?
The node has worked well with RF68 on arduino (as gateway) before moving to RPi.
What could be the cause?Thanks,
Simon
@gohan said in mysgw MQTT Issues:
Why are you using version 2.2.1? What do you see on the node log?
I've noticed this now (remote) connected to the RPi. I can give a check on the logs of the node as soon I'm back.
About the version, which should I use? This is the first I've downloaded (months ago).
I've seen there is a v2.3.0-alpha. I could test it.Simon
use the master branch that is 2.2, the 2.2.1 are 2.3 are alpha versions and still under development
Ok, this is something I can test right now!
Same result:mysgw: Starting gateway... mysgw: Protocol version - 2.2.0 mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: GWT:RMQ:MQTT RECONNECT mysgw: connected to 192.168.1.50 mysgw: GWT:RMQ:MQTT CONNECTED mysgw: GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:CKU:OK,FCTRL mysgw: TSF:MSG:GWL OK mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:CKU:OK,FCTRL mysgw: TSF:MSG:GWL OK mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:CKU:OK,FCTRL mysgw: TSF:MSG:GWL OK mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0Is the
!TFS:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0actually the answer sent?
Could it be a power issue? The radio is directly connected to 3.3V pin, without capacitor.Simon
Hello!
Added capacitor, but it's still not working.
It has worked from some minutes but then no-more.
Here results from Gateway and Node:Node:
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.2.0 16 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0 25 MCO:BGN:BFR 27 TSM:INIT 28 TSF:WUR:MS=0 30 TSM:INIT:TSP OK 31 TSM:INIT:STATID=27 33 TSF:SID:OK,ID=27 35 TSM:FPAR 1036 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 3043 !TSM:FPAR:NO REPLY 3045 TSM:FPAR 4046 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6053 !TSM:FPAR:NO REPLY 6055 TSM:FPAR 7056 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 9063 !TSM:FPAR:NO REPLY 9065 TSM:FPAR 9069 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 10904 TSF:MSG:READ,0-0-27,s=255,c=3,t=8,pt=1,l=1,sg=0:0 10908 TSF:MSG:FPAR OK,ID=0,D=1 11077 TSM:FPAR:OK 11078 TSM:ID 11080 TSM:ID:OK 11081 TSM:UPL 18379 !TSF:MSG:SEND,27-27-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1 20386 TSM:UPL 27659 !TSF:MSG:SEND,27-27-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1 29666 TSM:UPL..and here the gateway:
Apr 10 21:49:36 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Apr 10 21:49:36 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27 Apr 10 21:49:38 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 Apr 10 21:49:38 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Apr 10 21:49:38 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27 Apr 10 21:49:40 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 Apr 10 21:49:41 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Apr 10 21:49:41 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27 Apr 10 21:49:43 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 Apr 10 21:49:44 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Apr 10 21:49:44 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27 Apr 10 21:49:46 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 Apr 10 21:49:47 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Apr 10 21:49:47 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27 Apr 10 21:49:48 mysensors-gateway mysgw: TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 Apr 10 21:49:49 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:49:49 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:49:50 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 Apr 10 21:49:50 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:49:50 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:49:52 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 Apr 10 21:49:53 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:49:53 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:49:54 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 Apr 10 21:49:54 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:49:54 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:49:55 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 Apr 10 21:49:58 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:49:58 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:50:00 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 Apr 10 21:50:00 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:50:00 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:50:01 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 Apr 10 21:50:02 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:50:02 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:50:03 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 Apr 10 21:50:03 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Apr 10 21:50:03 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1 Apr 10 21:50:05 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1Seems the GW is not able to send out the answer.
BTW It gets every message from the node...Ideas?
Thanks!
Simon
move node closer. You could also try swapping the 2 radio modules to see if the problem changes.
Strange is, the same radios had worked well until I've switched to RPi GW.
From the logs, correct me if I'm wrong, the issue seems to be on the gateway, not able to send the return/ack message:!TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0The node is sending well!
TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:Or not??
I've added capacitors 100uf to both and, as well, added a copper coli antenna 868Mhz.
Now the GW is 10meters far away from the node. There is only one wall between.
I was testing to switch to RF69 radios which should be better if compared to nRF24L01+ in terms of range and walls.
This is not what expected...I'll try to replace the radio on the GW side.
Any other suggestion is well appreciated!
Thanks, Simon
I forgot you had rfm69, so capacitor is not that important. Try to look at my rfm69 signal scanner and look for the code to print on debug the rssi of signal and output power and try to move around to see if you get any value change. I had problems with rpi3 gw using the alpha version, but on stable it works. You could also try to compile it as an ethernet gateway just to see if you get any changes. Can you also post the configure parameters you user?
Hello!
Which parameters?
compiling parameters of the GW?
I've configured it with:./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-gateway=mqtt --my-controller-ip-address=192.168.1.50 --my-mqtt-publish-topic-prefix=mygateway1-out --my-mqtt-subscribe-topic-prefix=mygateway1-in --my-mqtt-client-id=raspberryRFM69About the rfm69 signal scanner, should it run on the node or on the RPi?
(where to find it?)Thanks @gohan :-)
https://forum.mysensors.org/topic/7822/portable-rfm69-signal-scanner/6
Ok, then I need to upload it on the node (which is on a little wooden bird house) and go around with my laptop connected on it :-) Not a problem.
But would that report issues on the GW RPi as well? How?Meanwhile I can try to compile the ethernet version to give it a try.
Thanks, Simon
Hello @gohan
Installed ethernet version:./configure --my-gateway=ethernet --my-port=5003And it's even worst:
# ./mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.2.0 mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=1 mysgw: TSM:FAIL:DIS mysgw: TSF:TDI:TSL mysgw: TSM:FAIL:RE-INIT mysgw: TSM:INIT mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=2 mysgw: TSM:FAIL:DIS mysgw: TSF:TDI:TSL mysgw: TSM:FAIL:RE-INIT mysgw: TSM:INIT mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=3 mysgw: TSM:FAIL:DIS mysgw: TSF:TDI:TSL mysgw: TSM:FAIL:RE-INIT mysgw: TSM:INIT mysgw: !TSM:INIT:TSP FAILUsing the mqtt version at least the init gets completed.
Ideas?Simon
Just a quick idea: are you powering the RFM69 from the Rpi?
I use a Rpi Zero W and when I powered my radio NRF24 from that it doesnt get enough juice even with caps.
I now use a bigger USB-wall wart and use AMS1117-3.3 to power the radio (PA-version) and added caps.My two cents
@masmat said in mysgw MQTT Issues:
I've tried to get 3.3V from external source, but same situation:
Apr 16 23:27:02 mysensors-gateway mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0 Apr 16 23:27:02 mysensors-gateway mysgw: TSF:LRT:OK Apr 16 23:27:02 mysensors-gateway mysgw: TSM:INIT Apr 16 23:27:02 mysensors-gateway mysgw: TSF:WUR:MS=0 Apr 16 23:27:02 mysensors-gateway mysgw: TSM:INIT:TSP OK Apr 16 23:27:02 mysensors-gateway mysgw: TSM:INIT:GW MODE Apr 16 23:27:02 mysensors-gateway mysgw: TSM:READY:ID=0,PAR=0,DIS=0 Apr 16 23:27:02 mysensors-gateway mysgw: MCO:REG:NOT NEEDED Apr 16 23:27:02 mysensors-gateway mysgw: MCO:BGN:STP Apr 16 23:27:02 mysensors-gateway mysgw: MCO:BGN:INIT OK,TSP=1 Apr 16 23:27:02 mysensors-gateway mysgw: GWT:RMQ:MQTT RECONNECT Apr 16 23:27:02 mysensors-gateway mysgw: connected to 192.168.1.50 Apr 16 23:27:02 mysensors-gateway mysgw: GWT:RMQ:MQTT CONNECTED Apr 16 23:27:02 mysensors-gateway mysgw: GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT Apr 16 23:27:42 mysensors-gateway mysgw: TSF:MSG:READ,1-27-177,s=48,c=0,t=32,pt=7,l=23,sg=1: 0 Apr 16 23:27:42 mysensors-gateway mysgw: !TSF:MSG:LEN,7!=32 Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:BC Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27 Apr 16 23:27:45 mysensors-gateway mysgw: TSF:PNG:SEND,TO=0 Apr 16 23:27:45 mysensors-gateway mysgw: TSF:CKU:OK Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:GWL OK Apr 16 23:27:47 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:BC Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27 Apr 16 23:27:51 mysensors-gateway mysgw: TSF:CKU:OK,FCTRL Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:GWL OK Apr 16 23:27:53 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0Possible the problem is only sending and not receiving?
I've not tested the signal scanner right now.
I was hoping it's a power issue :'(Simon
Hello @gohan ,
I was able to compile correctly the network IP mode. I had compiled it with the wrong transport.
BTW, now it initialized correctly, BUT same problems.
I've replaced the radio as well (only on the gateway).
Here the logs:mysgw: Starting gateway... mysgw: Protocol version - 2.2.0 mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: Listening for connections on 0.0.0.0:5003 mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:PNG:SEND,TO=0 mysgw: TSF:CKU:OK mysgw: TSF:MSG:GWL OK mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0: mysgw: TSF:MSG:BC mysgw: TSF:MSG:FPAR REQ,ID=27 mysgw: TSF:CKU:OK,FCTRL mysgw: TSF:MSG:GWL OKAs you can see the SEND message fails.
I'll try now to move the node closer and then try the scanner.Hope it helps :-(
Simon
