  3. mysgw MQTT Issues
mysgw MQTT Issues
22 Posts 3 Posters 3.9k Views 3 Watching
  • X
    X
    xefil
    Hello to all,
    I'm having issues with the only node in RF69 I've actually installed.
    Switched to RPi and radio connected as MQTT server I'm getting this:
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.1-alpha
    mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.1-alpha
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: GWT:RMQ:MQTT RECONNECT
    mysgw: connected to 192.168.1.50
    mysgw: GWT:RMQ:MQTT CONNECTED
    mysgw: GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=27
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:GWL OK
    mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    Is this !TSF causing me the issues not getting any informations from the node?
    The node has worked well with RF68 on arduino (as gateway) before moving to RPi.
    What could be the cause?
    Simon
      Why are you using version 2.2.1? What do you see on the node log?
      X 1 Reply Last reply
        X
        X
        xefil
        @gohan said in mysgw MQTT Issues:
        I've noticed this now (remote) connected to the RPi. I can give a check on the logs of the node as soon I'm back.
        About the version, which should I use? This is the first I've downloaded (months ago).
        I've seen there is a v2.3.0-alpha. I could test it.
        Simon
          use the master branch that is 2.2, the 2.2.1 are 2.3 are alpha versions and still under development
            X
            X
            xefil
            Ok, this is something I can test right now!
            Same result:
            mysgw: Protocol version - 2.2.0
            mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: MCO:BGN:STP
            mysgw: TSF:MSG:BC
            mysgw: TSF:MSG:BC
            mysgw: TSF:MSG:BC
            Is the !TFS:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 actually the answer sent?
            Could it be a power issue? The radio is directly connected to 3.3V pin, without capacitor.
            Simon
              add capacitor and try again
                X
                X
                xefil
                Size? 100uF enough?
                  Yes, I use 10uF ceramic because of low ESR
                    X
                    X
                    xefil
                    @gohan
                    Actually I've only electrolytic ones, I'll try meanwhile with that, thanks!
                    Simon
                    • X
                      X
                      xefil
                      wrote on last edited by xefil
                      Hello!
                      Added capacitor, but it's still not working.
                      It has worked from some minutes but then no-more.
                      Here results from Gateway and Node:
                      Node:
                       __  __       ____
                              |___/                      2.2.0
                      16 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0
                      25 MCO:BGN:BFR
                      27 TSM:INIT
                      28 TSF:WUR:MS=0
                      30 TSM:INIT:TSP OK
                      31 TSM:INIT:STATID=27
                      33 TSF:SID:OK,ID=27
                      35 TSM:FPAR
                      1036 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      3043 !TSM:FPAR:NO REPLY
                      3045 TSM:FPAR
                      4046 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      6053 !TSM:FPAR:NO REPLY
                      6055 TSM:FPAR
                      7056 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      9063 !TSM:FPAR:NO REPLY
                      9065 TSM:FPAR
                      9069 TSF:MSG:SEND,27-27-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      10904 TSF:MSG:READ,0-0-27,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      10908 TSF:MSG:FPAR OK,ID=0,D=1
                      11077 TSM:FPAR:OK
                      11078 TSM:ID
                      11080 TSM:ID:OK
                      11081 TSM:UPL
                      18379 !TSF:MSG:SEND,27-27-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      20386 TSM:UPL
                      27659 !TSF:MSG:SEND,27-27-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                      29666 TSM:UPL
                      ..and here the gateway:
                      Apr 10 21:49:36 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      Apr 10 21:49:36 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27
                      Apr 10 21:49:38 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      Apr 10 21:49:38 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      Apr 10 21:49:38 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27
                      Apr 10 21:49:40 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      Apr 10 21:49:41 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      Apr 10 21:49:41 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27
                      Apr 10 21:49:43 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      Apr 10 21:49:44 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      Apr 10 21:49:44 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27
                      Apr 10 21:49:46 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      Apr 10 21:49:47 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      Apr 10 21:49:47 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27
                      Apr 10 21:49:48 mysensors-gateway mysgw: TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      Apr 10 21:49:49 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:49:49 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:49:50 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Apr 10 21:49:50 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:49:50 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:49:52 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Apr 10 21:49:53 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:49:53 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:49:54 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Apr 10 21:49:54 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:49:54 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:49:55 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Apr 10 21:49:58 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:49:58 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:50:00 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Apr 10 21:50:00 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:50:00 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:50:01 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Apr 10 21:50:02 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:50:02 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:50:03 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Apr 10 21:50:03 mysensors-gateway mysgw: TSF:MSG:READ,27-27-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      Apr 10 21:50:03 mysensors-gateway mysgw: TSF:MSG:PINGED,ID=27,HP=1
                      Apr 10 21:50:05 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      Seems the GW is not able to send out the answer.
                      BTW It gets every message from the node...
                      Ideas?
                      Simon
                        move node closer. You could also try swapping the 2 radio modules to see if the problem changes.
                        • X
                          X
                          xefil
                          Strange is, the same radios had worked well until I've switched to RPi GW.
                          From the logs, correct me if I'm wrong, the issue seems to be on the gateway, not able to send the return/ack message:
                          The node is sending well!
                          Or not??
                          I've added capacitors 100uf to both and, as well, added a copper coli antenna 868Mhz.
                          Now the GW is 10meters far away from the node. There is only one wall between.
                          I was testing to switch to RF69 radios which should be better if compared to nRF24L01+ in terms of range and walls.
                          This is not what expected...
                          I'll try to replace the radio on the GW side.
                          Any other suggestion is well appreciated!
                          Thanks, Simon
                            I forgot you had rfm69, so capacitor is not that important. Try to look at my rfm69 signal scanner and look for the code to print on debug the rssi of signal and output power and try to move around to see if you get any value change. I had problems with rpi3 gw using the alpha version, but on stable it works. You could also try to compile it as an ethernet gateway just to see if you get any changes. Can you also post the configure parameters you user?
                              X
                              X
                              xefil
                              Hello!
                              Which parameters?
                              compiling parameters of the GW?
                              I've configured it with:
                              ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-gateway=mqtt --my-controller-ip-address=192.168.1.50 --my-mqtt-publish-topic-prefix=mygateway1-out --my-mqtt-subscribe-topic-prefix=mygateway1-in --my-mqtt-client-id=raspberryRFM69
                              About the rfm69 signal scanner, should it run on the node or on the RPi?
                              (where to find it?)
                              Thanks @gohan :-)
                                https://forum.mysensors.org/topic/7822/portable-rfm69-signal-scanner/6
                                  X
                                  X
                                  xefil
                                  Ok, then I need to upload it on the node (which is on a little wooden bird house) and go around with my laptop connected on it :-) Not a problem.
                                  But would that report issues on the GW RPi as well? How?
                                  Meanwhile I can try to compile the ethernet version to give it a try.
                                  Thanks, Simon
                                  • X
                                    X
                                    xefil
                                    Hello @gohan
                                    Installed ethernet version:
                                    ./configure --my-gateway=ethernet --my-port=5003
                                    And it's even worst:
                                    # ./mysgw -d
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: !TSM:INIT:TSP FAIL
                                    mysgw: TSM:FAIL:CNT=1
                                    mysgw: TSM:FAIL:DIS
                                    mysgw: TSF:TDI:TSL
                                    mysgw: TSM:FAIL:RE-INIT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:CNT=2
                                    mysgw: TSM:FAIL:DIS
                                    mysgw: TSF:TDI:TSL
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:CNT=3
                                    mysgw: TSM:FAIL:DIS
                                    mysgw: TSF:TDI:TSL
                                    mysgw: TSM:INIT
                                    Using the mqtt version at least the init gets completed.
                                    Ideas?
                                    Simon
                                    • MasMatM
                                      MasMatM
                                      MasMat
                                      Just a quick idea: are you powering the RFM69 from the Rpi?
                                      I use a Rpi Zero W and when I powered my radio NRF24 from that it doesnt get enough juice even with caps.
                                      I now use a bigger USB-wall wart and use AMS1117-3.3 to power the radio (PA-version) and added caps.
                                      My two cents
                                      • MasMatM MasMat
                                        My two cents
                                        X
                                        X
                                        xefil
                                        @masmat said in mysgw MQTT Issues:
                                        My two cents
                                        I've tried to get 3.3V from external source, but same situation:
                                        Apr 16 23:27:02 mysensors-gateway mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0
                                        Apr 16 23:27:02 mysensors-gateway mysgw: TSF:LRT:OK
                                        Apr 16 23:27:02 mysensors-gateway mysgw: TSM:INIT
                                        Apr 16 23:27:02 mysensors-gateway mysgw: TSF:WUR:MS=0
                                        Apr 16 23:27:02 mysensors-gateway mysgw: TSM:INIT:TSP OK
                                        Apr 16 23:27:02 mysensors-gateway mysgw: TSM:INIT:GW MODE
                                        Apr 16 23:27:02 mysensors-gateway mysgw: TSM:READY:ID=0,PAR=0,DIS=0
                                        Apr 16 23:27:02 mysensors-gateway mysgw: MCO:REG:NOT NEEDED
                                        Apr 16 23:27:02 mysensors-gateway mysgw: MCO:BGN:STP
                                        Apr 16 23:27:02 mysensors-gateway mysgw: MCO:BGN:INIT OK,TSP=1
                                        Apr 16 23:27:02 mysensors-gateway mysgw: GWT:RMQ:MQTT RECONNECT
                                        Apr 16 23:27:02 mysensors-gateway mysgw: connected to 192.168.1.50
                                        Apr 16 23:27:02 mysensors-gateway mysgw: GWT:RMQ:MQTT CONNECTED
                                        Apr 16 23:27:02 mysensors-gateway mysgw: GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
                                        Apr 16 23:27:42 mysensors-gateway mysgw: TSF:MSG:READ,1-27-177,s=48,c=0,t=32,pt=7,l=23,sg=1: 0
                                        Apr 16 23:27:42 mysensors-gateway mysgw: !TSF:MSG:LEN,7!=32
                                        Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:BC
                                        Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27
                                        Apr 16 23:27:45 mysensors-gateway mysgw: TSF:PNG:SEND,TO=0
                                        Apr 16 23:27:45 mysensors-gateway mysgw: TSF:CKU:OK
                                        Apr 16 23:27:45 mysensors-gateway mysgw: TSF:MSG:GWL OK
                                        Apr 16 23:27:47 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                        Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:READ,27-27-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:BC
                                        Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:FPAR REQ,ID=27
                                        Apr 16 23:27:51 mysensors-gateway mysgw: TSF:CKU:OK,FCTRL
                                        Apr 16 23:27:51 mysensors-gateway mysgw: TSF:MSG:GWL OK
                                        Apr 16 23:27:53 mysensors-gateway mysgw: !TSF:MSG:SEND,0-0-27-27,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                        Possible the problem is only sending and not receiving?
                                        I've not tested the signal scanner right now.
                                        I was hoping it's a power issue :'(
                                        Simon
                                        • X
                                          X
                                          xefil
                                          Hello @gohan ,
                                          I was able to compile correctly the network IP mode. I had compiled it with the wrong transport.
                                          BTW, now it initialized correctly, BUT same problems.
                                          I've replaced the radio as well (only on the gateway).
                                          Here the logs:
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
                                          mysgw: TSF:MSG:BC
                                          mysgw: TSF:CKU:OK
                                          mysgw: TSF:MSG:BC
                                          As you can see the SEND message fails.
                                          I'll try now to move the node closer and then try the scanner.
                                          Hope it helps :-(
                                          Simon
