  3. SW_Signing failing: !TSF:MSG:SIGN FAIL
27 Posts 3 Posters 4.6k Views 3 Watching
  • joaoabsJ joaoabs
    Sorry for the delayed answer, I was making sure I had a better testing enviroment:
    Controller/Gateway: RPI3 with OpenHab2 and NRF24L01+ connected directly to the pin header. The NRF has a 4.7uF capacitor soldered to it and is the simple + model (not PA+NLA)
    Node: Arduino mini pro 3v 8MHz, in a prototype board with:
    • Hi-Link power supply (220AC to 5V DC)
    • 2200uF capactior to stabilize 5V (and also a pico range one to filter high frequencies)
    • 3.3V regulator
    • 100uf capacitor to stabilize 3.3V (and also a pico range one to filter high frequencies)
    • NRF24L01+ feed from the 3.3V regulator and with an additional 4.7uF capacitor
    • Connections made by wire around the board
    • The board is supposed to:
      • Interact with a 4-relay module
      • Read the temperature of several DS18B20's (only used 1 in the testing)
      • Detect presence in 3 motion sensors
      • Read temperature/Humidity from a DHT22
    • The node is ~6m away of the GW/Controller with line of sight
    • The pins and skecth options are in its own comments.
    • The " && transportSanityCheck());" patch was applied
    • Signing is activated
    Code:
     * This program is free software; you can redistribute it and/orlçyovzwqi71234567890ll
     * Version 1.0
     * Combined sketch with:
     *      - NODE ID 44
     *      - Relay sketch, base sketch for all          - PIN 3,4,5,6  -   Child ID from 1,2,3,4
     *      - DOOR sketch (trip alarm), added code       - PIN A0,A1    -   Child ID 30,31
     *      - TEMP sketch (DS18B20), added code          - PIN 8        -   Child ID from 10 to 18  (defined 8 as MAX)
     *      - Hum sketch (DHT22), added code             - PIN A7       -   Child ID 50 (Temp) and 60 (Hum)
     *      - MOTION sketch, added code                  - PIN A6       -   Child ID 70
     * BOARD
     * D0 - RX (not used - but can be used with a plug on the programing header))
     * D1 - TX (not used - but can be used with a plug on the programing header))
     * D2 - NRF24 IRQ
     * D3 - RJ-45 (3)
     * D4 - 1-W (RJ-45 (4) & pin header)
     * D5 - Relay (5) (relay pin header has 6 pins where 6 is 5v and 1 is GND)
     * D6 - Relay (4)
     * D7 - Relay (3)
     * D8 - Relay (2)
     * D9 - NRF CE
     * D10- NRF CS
     * D11- NRF MOSI
     * D12- NRF MISO
     * D13- NRF SCK
     * A0 - RJ-45 (6)  (DOOR Sketch)
     * A1 - RJ-45 (2)  (DOOR Sketch)
     * A2 - RJ-45 (1)
     * A3 - RJ-45 (4)
     * A4 - I2C
     * A5 - I2C
     * A6 - PIR (pin header)  (MOTION Sketch)
     * A7 - DHT (pin header)
     * All sketches copied from http://www.mysensors.org
     * signing "hidden" page: https://www.mysensors.org/apidocs-beta/group__MySigninggrpPub.html
    // Static node ID definition
    #define MY_NODE_ID 44
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    //#define MY_REPEATER_FEATURE
    //CODE FOR SIGNING************************************************
    //#define MY_SIGNING_WEAK_SECURITY
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN A4
    #define MY_SIGNING_REQUEST_SIGNATURES  // will inform the gateway that I expect it to sign all messages to me
    //#define MY_DEBUG_VERBOSE_SIGNING
    //What features/Sketches to use?  ************************************************
    #define RELAY
    //#define DHTCODE
    #define DOOR
    #define MOTION
    //#define TEMP
    //CODE OF DOOR SKETCH************************************************
    #ifdef DOOR
    #include <Bounce2.h>
    #define CHILD_ID_A 30
    #define CHILD_ID_B 31
    #define BUTTON_PIN_A  A0  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_B  A1  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer_a = Bounce();
    Bounce debouncer_b = Bounce();
    int oldValue_a=-1;
    int oldValue_b=-1;
    MyMessage msg_door_a(CHILD_ID_A,V_TRIPPED);
    MyMessage msg_door_b(CHILD_ID_B,V_TRIPPED);
    //CODE OF MOTION SKETCH************************************************
    #ifdef MOTION
    int oldMotion_a=-1;
    //uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR_MOTION_A A6   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID_MOTION_A 70   // Id of the sensor child
    // Initialize motion message
    MyMessage msg_motion_a(CHILD_ID_MOTION_A, V_TRIPPED);
    //CODE OF TEMP SKETCH************************************************
    #ifdef TEMP
    #include <OneWire.h>
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    #define MAX_ATTACHED_DS18B20 10
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg_temp(0,V_TEMP);
    //CODE FOR LOOP************************************************
    long x = 327670;
    int y = 32767;
    //CODE OF RELAY SKETCH************************************************
    #ifdef RELAY
    #define RELAY_PIN 5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    //CODE OF DHT SKETCH************************************************
    #ifdef DHTCODE
    //#include "DHT.h"
    #include <DHT.h>
    #define DHT_DATA_PIN A7
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 50
    #define CHILD_ID_TEMP 60
    float lastTempdht;
    float lastHumdht;
    uint8_t nNoUpdatesTempdht;
    uint8_t nNoUpdatesHumdht;
    //bool metric = true;
    DHT dht;
    void before()
     #ifdef RELAY
     for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
     #ifdef TEMP
     sensors.begin();
    #ifdef DOOR
      // Setup the button A
      pinMode(BUTTON_PIN_A,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_A,HIGH);
      debouncer_a.attach(BUTTON_PIN_A);
      debouncer_a.interval(5);
      // Setup the button B
      pinMode(BUTTON_PIN_B,INPUT);
      digitalWrite(BUTTON_PIN_B,HIGH);
      debouncer_b.attach(BUTTON_PIN_B);
      debouncer_b.interval(5);
    #ifdef MOTION
      pinMode(DIGITAL_INPUT_SENSOR_MOTION_A, INPUT);      // sets the motion sensor digital pin as input
    #ifdef TEMP
    #ifdef DHTCODE
       sendSketchInfo("MIXED JOAOABS SOTAO", "1.0");
    //FOR RELAY: Child ID from 1 to 4
    #ifdef RELAY
            //  present(sensor, S_BINARY);
             present(sensor, S_BINARY, "RELAYS", true);  // forcing ack for this child's messages
    //FOR DOOR: Child ID 30
    #ifdef DOOR
     // present(CHILD_ID_A, S_DOOR);
     // present(CHILD_ID_B, S_DOOR);
      present(CHILD_ID_A, S_DOOR, "DOOR_A", true);  // CHILD ID = 30 and forcing ack for this child's messages
      present(CHILD_ID_B, S_DOOR, "DOOR_B", true);  // CHILD ID = 31 and forcing ack for this child's messages
    #ifdef MOTION
    present(CHILD_ID_MOTION_A, S_MOTION, "PIR", true); // CHILD ID =  70 and forcing ack for this child's messages
    //FOR TEMP: Child ID from 10 to 18  (defined 8 as MAX)
    #ifdef TEMP
         int a;
         a=i+10;
         present(a, S_TEMP);
    #ifdef DHTCODE
    //FOR DHT: Child ID 50 and 60
      present(CHILD_ID_HUM, S_HUM);
    #ifdef DOOR
    //For DOOR A
    debouncer_a.update();
      // Get the update value
      int value_a = debouncer_a.read();
      if (value_a != oldValue_a) {
         // Send in the new value
         send(msg_door_a.set(value_a==HIGH ? 1 : 0));
         oldValue_a = value_a;
    //For DOOR B
    debouncer_b.update();
      int value_b = debouncer_b.read();
      if (value_b != oldValue_b) {
         send(msg_door_b.set(value_b==HIGH ? 1 : 0));
         oldValue_b = value_b;
    #ifdef MOTION
        // Read digital motion value
        int valueMotion_a = digitalRead(DIGITAL_INPUT_SENSOR_MOTION_A);
        if (valueMotion_a != oldMotion_a)
         #ifdef MY_DEBUG
         Serial.println(valueMotion_a);
         #endif MY_DEBUG
         send(msg_motion_a.set(valueMotion_a?"1":"0"));  // Send tripped value to gw
         oldMotion_a = valueMotion_a;
    //Loop Code ************************************************
    //Resets every 1-2 minutes
      if (x>0)
        x=x-1;
      else
        y=y-1;
        if (x==0 && y==0)
         #ifdef MY_DEBUG
      Serial.println("****** counters reached 0 **************");
         x = 1600000;
         y = 32767;
    // So Let's fetch temperatures from Dallas sensors
    #ifdef TEMP
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
     //   Serial.println("temperature:");
     //   Serial.println(temperature);
        #if COMPARE_TEMP == 1
        #else
         int a=i+10;
          send(msg_temp.setSensor(a).set(temperature,1));
        #ifdef DHTCODE
        dht.readSensor(true);
        delay(2000);
        float temperaturedht = dht.getTemperature();
        if (isnan(temperaturedht))
        else if (temperaturedht != lastTempdht || nNoUpdatesTempdht == FORCE_UPDATE_N_READS)
         lastTempdht = temperaturedht;
         if (!metric)
          temperaturedht = dht.toFahrenheit(temperaturedht);
         // Reset no updates counter
         nNoUpdatesTempdht = 0;
         temperaturedht += SENSOR_TEMP_OFFSET;
         send(msgTemp.set(temperaturedht, 1));
         #ifdef MY_DEBUG
         Serial.print("T: ");
         Serial.println(temperaturedht);
        else
         nNoUpdatesTempdht++;
        float humiditydht = dht.getHumidity();
        if (isnan(humiditydht))
       else if (humiditydht != lastHumdht || nNoUpdatesHumdht == FORCE_UPDATE_N_READS) {
       lastHumdht = humiditydht;
       nNoUpdatesHumdht = 0;
       send(msgHum.set(humiditydht, 1));
       #ifdef MY_DEBUG
       Serial.print("H: ");
       Serial.println(humiditydht);
       else
        nNoUpdatesHumdht++;
        //THERE IS ONLY RECEIVE CODE for RELAY.  DOOR, TEMP and HUM are just sent periodically and not on-demand
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
    If we only choose the relay-related code, I can feel some reliability. Every command that is sent is executed.
    If I activate just the temperature code, I start having signature failures when trying to open/close relays. Not always, but often, so reliability is affected. Example of trying to change the relay 4 (44:4).
    May  3 18:31:32 nettemp mysgw: GWT:RFC:C=0,MSG=44;3;1;1;2;1
    May  3 18:31:32 nettemp mysgw: !TSF:MSG:SEND,0-0-44-44,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
    May  3 18:31:32 nettemp mysgw: !TSF:MSG:SIGN FAIL
    May  3 18:31:33 nettemp mysgw: GWT:RFC:C=0,MSG=44;3;1;1;2;1
    May  3 18:31:33 nettemp mysgw: !TSF:MSG:SEND,0-0-44-44,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
    May  3 18:31:33 nettemp mysgw: !TSF:MSG:SIGN FAIL
    May  3 18:31:34 nettemp mysgw: GWT:RFC:C=0,MSG=44;3;1;1;2;1
    May  3 18:31:34 nettemp mysgw: !TSF:MSG:SEND,0-0-44-44,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
    May  3 18:31:34 nettemp mysgw: !TSF:MSG:SIGN FAIL
    (nothing appears in the node log, as it haven't received anything).
     __  __       ____
            |___/                      2.2.0
    16 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.2.0
    25 MCO:BGN:BFR
    69 TSM:INIT
    70 TSF:WUR:MS=0
    77 TSM:INIT:TSP OK
    79 TSM:INIT:STATID=44
    81 TSF:SID:OK,ID=44
    82 TSM:FPAR
    102 TSF:MSG:SEND,44-44-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    159 TSF:MSG:READ,0-0-44,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    164 TSF:MSG:FPAR OK,ID=0,D=1
    2109 TSM:FPAR:OK
    2110 TSM:ID
    2111 TSM:ID:OK
    2113 TSM:UPL
    2115 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2122 TSF:MSG:READ,0-0-44,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2127 TSF:MSG:PONG RECV,HP=1
    2129 TSM:UPL:OK
    2131 TSM:READY:ID=44,PAR=0,DIS=1
    2136 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    2142 TSF:MSG:READ,0-0-44,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
    2152 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
    2158 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
    2246 TSF:MSG:SEND,44-44-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.2.0
    2255 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    2262 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    2352 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
    2360 TSF:MSG:READ,0-0-44,s=255,c=3,t=16,pt=0,l=0,sg=1:
    2382 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    2397 TSF:MSG:READ,0-0-44,s=255,c=3,t=6,pt=0,l=1,sg=1:M
    2485 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    2491 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    2581 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=11,pt=0,l=19,sg=1,ft=0,st=OK:MIXED JOAOABS SOTAO
    2591 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    2598 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    2685 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
    2694 TSF:MSG:SEND,44-44-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    2701 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    2791 TSF:MSG:SEND,44-44-0-0,s=1,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
    2801 TSF:MSG:SEND,44-44-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    2807 TSF:MSG:READ,0-0-44,s=1,c=0,t=3,pt=0,l=6,sg=0:RELAYS
    2812 TSF:MSG:ACK
    2814 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    2904 TSF:MSG:SEND,44-44-0-0,s=2,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
    2914 TSF:MSG:SEND,44-44-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    2920 TSF:MSG:READ,0-0-44,s=2,c=0,t=3,pt=0,l=6,sg=0:RELAYS
    2926 TSF:MSG:ACK
    2927 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3015 TSF:MSG:SEND,44-44-0-0,s=3,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
    3024 TSF:MSG:SEND,44-44-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    3031 TSF:MSG:READ,0-0-44,s=3,c=0,t=3,pt=0,l=6,sg=0:RELAYS
    3036 TSF:MSG:ACK
    3038 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3125 TSF:MSG:SEND,44-44-0-0,s=4,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
    3134 TSF:MSG:SEND,44-44-0-0,s=30,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    3140 TSF:MSG:READ,0-0-44,s=4,c=0,t=3,pt=0,l=6,sg=0:RELAYS
    3145 TSF:MSG:ACK
    3147 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3234 TSF:MSG:SEND,44-44-0-0,s=30,c=0,t=0,pt=0,l=6,sg=1,ft=0,st=OK:DOOR_A
    3244 TSF:MSG:SEND,44-44-0-0,s=31,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    3250 TSF:MSG:READ,0-0-44,s=30,c=0,t=0,pt=0,l=6,sg=0:DOOR_A
    3256 TSF:MSG:ACK
    3257 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3344 TSF:MSG:SEND,44-44-0-0,s=31,c=0,t=0,pt=0,l=6,sg=1,ft=0,st=OK:DOOR_B
    3353 TSF:MSG:SEND,44-44-0-0,s=70,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    3360 TSF:MSG:READ,0-0-44,s=31,c=0,t=0,pt=0,l=6,sg=0:DOOR_B
    3365 TSF:MSG:ACK
    3367 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3460 TSF:MSG:SEND,44-44-0-0,s=70,c=0,t=1,pt=0,l=3,sg=1,ft=0,st=OK:PIR
    3467 MCO:REG:REQ
    3470 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
    3476 TSF:MSG:READ,0-0-44,s=70,c=0,t=1,pt=0,l=3,sg=0:PIR
    3481 TSF:MSG:ACK
    3483 TSF:MSG:READ,0-0-44,s=255,c=3,t=16,pt=0,l=0,sg=1:
    3510 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    3524 TSF:MSG:READ,0-0-44,s=255,c=3,t=27,pt=1,l=1,sg=1:1
    3609 MCO:PIM:NODE REG=1
    3611 MCO:BGN:STP
    3613 MCO:BGN:INIT OK,TSP=1
    3619 TSF:MSG:SEND,44-44-0-0,s=30,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    3627 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3714 TSF:MSG:SEND,44-44-0-0,s=30,c=1,t=16,pt=2,l=2,sg=1,ft=0,st=OK:1
    3722 TSF:MSG:SEND,44-44-0-0,s=31,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    3734 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3822 TSF:MSG:SEND,44-44-0-0,s=31,c=1,t=16,pt=2,l=2,sg=1,ft=0,st=OK:1
    3832 TSF:MSG:SEND,44-44-0-0,s=70,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    3844 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    3932 TSF:MSG:SEND,44-44-0-0,s=70,c=1,t=16,pt=0,l=1,sg=1,ft=0,st=OK:0
    26080 TSF:MSG:READ,0-0-44,s=1,c=3,t=16,pt=0,l=0,sg=1:
    26106 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    26120 TSF:MSG:READ,0-0-44,s=1,c=1,t=2,pt=0,l=1,sg=1:0
    26205 TSF:MSG:ACK REQ
    26209 TSF:MSG:SEND,44-44-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    Incoming change for sensor:1, New status: 0
    26216 TSF:MSG:READ,0-0-44,s=1,c=3,t=16,pt=0,l=0,sg=1:
    26240 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    26250 TSF:MSG:READ,0-0-44,s=1,c=1,t=2,pt=0,l=1,sg=1:0
    26334 TSF:MSG:ACK REQ
    26339 TSF:MSG:SEND,44-44-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    29867 TSF:MSG:READ,0-0-44,s=2,c=3,t=16,pt=0,l=0,sg=1:
    29888 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    29902 TSF:MSG:READ,0-0-44,s=2,c=1,t=2,pt=0,l=1,sg=1:0
    29986 TSF:MSG:ACK REQ
    29991 TSF:MSG:SEND,44-44-0-0,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    Incoming change for sensor:2, New status: 0
    29999 TSF:MSG:READ,0-0-44,s=2,c=3,t=16,pt=0,l=0,sg=1:
    30022 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    30031 TSF:MSG:READ,0-0-44,s=2,c=1,t=2,pt=0,l=1,sg=1:0
    30116 TSF:MSG:ACK REQ
    30120 TSF:MSG:SEND,44-44-0-0,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    31344 TSF:MSG:READ,0-0-44,s=3,c=3,t=16,pt=0,l=0,sg=1:
    31366 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    31373 TSF:MSG:READ,0-0-44,s=3,c=1,t=2,pt=0,l=1,sg=1:0
    31457 TSF:MSG:ACK REQ
    31464 TSF:MSG:SEND,44-44-0-0,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    Incoming change for sensor:3, New status: 0
    31471 TSF:MSG:READ,0-0-44,s=3,c=3,t=16,pt=0,l=0,sg=1:
    31498 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    31510 TSF:MSG:READ,0-0-44,s=3,c=1,t=2,pt=0,l=1,sg=1:0
    31594 TSF:MSG:ACK REQ
    31597 TSF:MSG:SEND,44-44-0-0,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    32621 TSF:MSG:READ,0-0-44,s=4,c=3,t=16,pt=0,l=0,sg=1:
    32643 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
    32657 TSF:MSG:READ,0-0-44,s=4,c=1,t=2,pt=0,l=1,sg=1:0
    Incoming change for sensor:4, New status: 0
    32752 TSF:MSG:SEND,44-44-0-0,s=31,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    32758 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
    32845 TSF:MSG:SEND,44-44-0-0,s=31,c=1,t=16,pt=2,l=2,sg=1,ft=0,st=OK:0
    33015 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
    33020 TSF:TDI:TSL
    33022 MCO:SLP:WUP=-1
    33025 TSF:TRI:TSB
    160429 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
    160434 TSF:TDI:TSL
    160436 MCO:SLP:WUP=-1
    160438 TSF:TRI:TSB
    I'll keep doing some more tests and will report it here. Meanwhile if there is anything else you'd like me to try, do let me know.
    Thanks,
    Joaoabs
    AnticimexA
    AnticimexA
    Anticimex
    @joaoabs the failures you see are not signing failures. It is NACKs. Messages are not reaching its destination, and when that happens signing won't work. So you also get errors relating to signing as a consequence.
    It is the rf link that is unstable in your latest log.
    • joaoabsJ
      joaoabsJ
      joaoabs
      Thanks Anticimex for replying back,
      I understand now the root cause is not related with the signing itself. It makes sense.
      I may have wrongly associated to it becasue I read somewhere that the radio communication can be affected by signing because the packets are full and therefore the probability to have a missed bit in the between is bigger.
      However, the RF link is the same in test 1 and test 2 (~6m with line of sight), and the result is totally different... It must be something on the code, not in the RF link, don't you think?
      Thanks,
      Joaoabs
      AnticimexA 1 Reply Last reply
      • joaoabsJ joaoabs
        Thanks,
        Joaoabs
        AnticimexA
        AnticimexA
        Anticimex
        @joaoabs well, I agree that it should not affect the airborne part of it, but one way or another it prevents the messages from coming through. Perhaps your sensor communication induce some disturbance in the radio supply?
        • joaoabsJ
          joaoabsJ
          joaoabs
          wrote on last edited by joaoabs
          #24
          Some more testing:
          I realised I was doing a rookie mistake: When testing, I changed PC and the default options to compile the mini-pro were 16MHz/5V on the new PC, while mine is 8MHz/3.3v.
          I guess this difference in the clock was messing up the timmings on the 1-W bus, hence the eractic behaviour.
          Now the sketch with the door/motion, relay and temp(DS18B20) seems to be more stable. Adding the DHT code, we get back to erratic behaviour, as the initial post, althought the used memory without "MY_DEBUG" is 70% used.
          I'll be doing more tests and report back.
          Thanks,
          AnticimexA tekkaT 2 Replies Last reply
          • joaoabsJ joaoabs
            Some more testing:
            Thanks,
            AnticimexA
            AnticimexA
            Anticimex
            @joaoabs thanks for reporting. Is this with or without @tekka's patch?
            • joaoabsJ joaoabs
              Some more testing:
              Thanks,
              tekkaT
              tekkaT
              tekka
              @joaoabs Please post then full debug log when you observe the erratic behaviour (previously mentioned patch must be applied).
              joaoabsJ 1 Reply Last reply
              • tekkaT tekka
                joaoabsJ
                joaoabsJ
                joaoabs
                @tekka What debug flag should I activate for this?
                When I see the erratic behavior there isn't nothing appearing in the serial console, even with the MY_DEBUG on, so I guess there should be other that is of your interest...
