  3. battery powered sensor / watchdog?
29 Posts 8 Posters 5.9k Views 8 Watching
  • electrikE
    electrikE
    electrik
    so just to make sure I understand. Is the node also in the pool? Or just the sensor?
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      just the sensor. Node is in box outside of the pool.
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      • E
        E
        executivul
        Put an esp wifi node in the box with a beefier battery, or another box next to the first one if it isn't large enough. There is an "esp bridge" app that can easily do serial monitoring over wifi. That way you should have console output from the node when ot craps out. I've used it to debug some app that controls some contactors via a 5v relay board, turning contactors off sent the w5500 to Valhalla, the debug output via the esp saved the day since the device is located in a cielling a few meters up.
        • CrankyCoderC
          CrankyCoderC
          CrankyCoder
          This is a cool idea. Definitely worth throwing some bigger batteries at it for debugging. I am looking for this bridge stuff now :)
          www.CrankyCoder.net
          MySensors: 2.3
          E 1 Reply Last reply
          • CrankyCoderC CrankyCoder
            E
            E
            executivul
            @crankycoder https://github.com/jeelabs/esp-link
              I eneble wdt on pretty much all my nodes. Just remember to disable it before entering sleep. How did you setup the node? Do you have any booster running?
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                Where do you put your enable/disable watchdog? My node sleeps for 90 minutes at a time. Do you mean like a voltage booster? no, but i am monitoring the battery voltage so i know when it gets close to the 3.3 that the radio needs.
                www.CrankyCoder.net
                MySensors: 2.3
                  I enable it at beginning of loop and disable it before the sleep. What battery do you use? Btw the nrf24 radio can go down to 1.8V
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    Im using an 18650. currently it's sitting around 3.9v.
                    Do you have a link to the proper "mysensors" way of handling watch dog? Im not opposed to trying it. Especially if it gets hung up trying to do something then maybe the WDT while it's awake may help.
                    www.CrankyCoder.net
                    MySensors: 2.3
