  3. SMD Reflow Oven / PID
23 Posts 6 Posters 9.3k Views 2 Watching
  • Mars WarriorM
    Mars WarriorM
    Mars Warrior
    A bit off-topic, but as per the suggestions earlier in this topic I managed to get a toaster oven working with an OSPId reflow controller, and got some test boards with 0603, 0805, 1206 and SOT23 stuff reflowed with 4 year old AIM solder paste (no flux, lead free of course).
    Learned a lot. Now should get my hands dirty with some nRF52832 (ebyte E73) modules / PCB's to produce something useful ;-)
    I see so much nice designs here with that module!
    NeverDieN T 2 Replies Last reply
    • Mars WarriorM Mars Warrior
      NeverDieN
      NeverDieN
      @mars-warrior That's cool that you got lead free paste to work. How difficult was it?
      Mars WarriorM 1 Reply Last reply
      • NeverDieN NeverDie
        Mars WarriorM
        Mars WarriorM
        Mars Warrior
        @neverdie No idea if this was difficult as I never worked with leaded solder paste :laughing:
        I used OSPID's RoHS reflow profile to reflow a test board
        The test board looks like this. I was surprised that I managed to place the 0603 (imperial) with a pincet on the board (and magnifying glasses).
        No idea how good the connections really are with 4 year old solderpaste. I guess I should not use that for real boards :sunglasses:
          Toyman
          @mars-warrior said in nRF5 action!:
          where did you get it?
          • NeverDieN
            NeverDieN
            There's starting to be some interesting solder paste dispensors on thingiverse, such as:
            https://www.thingiverse.com/thing:384680
            or
            https://www.thingiverse.com/thing:2123259
            I'd probably need a tool like one of those. I didn't have good enough technique dispensing manually directly from a solder paste syringe, and I never really warmed up to the idea of using stencils. Well, not yet anyway. Using non-leaded solder paste would make the whole thing more appealing. Since nobody seemed to be doing it, I just assumed it was too hard to get it to work...until you came along!
            T 1 Reply Last reply
            • Mars WarriorM
              Mars WarriorM
              Mars Warrior
              @toyman said in nRF5 action!:
              I bought it from someone else, but he bought it from Rocketstream
              OSPid
              In the mean time I learned how a PID controller works (approx) as described here with this nice GIF from Wikipedia:
              And managed to get a very good implementation by OSPid of my (slightly modified) reflow profile for lead free solderpaste (max of 245 degrees):
              As you can see much better than my previous posted picture. Note that green = profile, and red is the actual temperature measurements.
              The original OOTB PID settings where 2/0.5/2 and I'm now using 2.5/160/40 which gives a very nice result!
              I increased the P value a bit. Made I much higher to make it follow the profile much, much, much better and used 40 for the D value to smoothen the temperature and prevent to much overshoot at 240 degrees.
              The only weird thing is that the oven is spec'd at max 230 degrees, but I already got it to 280 degrees (that was before I understood PID settings, I entered completely wrong ones) and burning the test PCB with the attached temperature sensor inside it:
              So now I have to make a real PCB and see if all this learning (using a stencil, applying solder paste, placing components, reflowing) can produce a working product :grinning:
              :innocent:
                if you don't make many smd project, the controller is not really mandatory as you can see here https://www.youtube.com/watch?v=mjfnpjvw9jY
                • NeverDieN
                  NeverDieN
                  Maybe this, or one like it? There are a ton of them on ebay.
                  https://www.ebay.com/itm/AC-110-240-Digital-PID-Temperature-controller-40A-SSR-K-thermocouple-Sensor/371134791350?epid=918051785&hash=item56695b7eb6:g:yRAAAOSwVFlUBBap
                  Ah, but of course, I don't suppose they would follow a temperature profile....
                    Mars WarriorM
                    Mars WarriorM
                    Mars Warrior
                    wrote on last edited by Mars Warrior
                    @neverdie Yup, cheap but no (adjustable) temperature profile...
                    I just found it easier to use a reflow controller, as I had no idea how not using a profile would impact the soldering results.
                    I bought a new, fairly cheap but good €70 oven, and the rest is second hand stuff for around €50; an OMRON SSR (40A), which gets barely warm during a reflow session, an osPID controller and a temperature sensor.
                    I'm happy with the combination as it gives me reproducible results.
                    Of course I have no results yet with real boards, but I'm confident that the reflow setup can be adjusted (longer pre-heat and soak times for instance) to meet the PCB, reflow paste and component requirements.
                    As you can see below, the osPID profile is very easy to setup:
                    RoHS24X		//first row is Profile Name with different crossings
                    3, 40, 0	//Step Setpoint to 40, wait 0 seconds
                    2, 0, 0		//Wait for PID Input to cross setpoint
                    127, 0, 1	//buzz for 1 second as a signal that the oven is starting to heat
                    1, 150, 100	//PRE-HEAT: ramp setpoint to 150 degrees over the course of 100 seconds
                    2, 5, 5		//Wait for PID Input to cross setpoint
                    1, 200, 120	//SOAK: ramp setpoint to 200 degrees over the course of 120 seconds
                    1, 240, 45	//REFLOW: ramp setpoint to 240  degrees over the course of 45 seconds
                    1, 218, 30	//ramp setpoint to 218 (TAL) over the course of 30 seconds
                    2, 5, 5		//Wait for PID Input to cross setpoint --> within 5 degrees, 5 seconds
                    127, 0, 1	//buzz for 2 seconds as a signal to open the oven door
                    1, 50, 150	//ramp setpoint to 50 over the course of 150 seconds
                    127, 0, 2	//buzz for 2 seconds
                    3, 20, 0	//Step Setpoint to 20, full cooldown!```
                    • MiKaM
                      MiKaM
                      MiKa
                      Have look here: http://www.whizoo.com/
                      and source code: https://github.com/engineertype/ControLeo/tree/master/ControLeo/examples/ReflowWizard
                        OSPid
                        :innocent:
                        Toyman
                        Thanks!
                        I have to admit I've acquired pretty decent understanding of PID while working on my sous-vide machine :-)
                          or
                          Toyman
                          @neverdie said in nRF5 action!:
                          what did you have issues with?
                          NeverDieN 1 Reply Last reply
                          • T Toyman
                            NeverDieN
                            NeverDieN
                            It was very hard to extrude it, so I always seemed to either underextrude or overstrude. I found it very hard to get the right amount exactly where it should go by just manually pressing the plunger on the solder paste syringe that the material came in.
                            T Nca78N 2 Replies Last reply
                              Toyman
                              @neverdie
                              two hypothesis:
                              a) old paste
                              b) wrong needle gauge
                              I use Mechanic XG paste, works perfect
                              • T Toyman
                                @neverdie
                                two hypothesis:
                                a) old paste
                                NeverDieN
                                NeverDieN
                                @toyman said in SMD Reflow Oven / PID:
                                Mechanic XG paste
                                This? https://www.ebay.com/itm/New-Mechanic-XG-Z40-10cc-Syringe-Solder-Paste-Flux-Sn63-Pb37-25-45um-10cc-US/202242405146?hash=item2f1696331a:g:WsMAAOSwu4BV1Ds8:sc:USPSFirstClass!78726!US!-1
                                  Mechanic XG paste
                                  Toyman
                                  wrote on last edited by Toyman
                                  @neverdie yes, although I use the one in small cans and reload small amount into 1 ml syringe (with proper gauge needle!)
                                  https://www.aliexpress.com/item/Original-Low-temperature-soldering-Paste-Flux-MECHANIC-B80-60g-Solder-tin-paste-Sn42-Bi58-For-Hakko/32878574326.html?spm=2114.search0204.3.1.51224cc6X3Qstz&s=p&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_10543_5722615_10696_10084_10083_10618_10307_10301_5722715_10059_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_55,ppcSwitch_5_ppcChannel&priceBeautifyAB=0
                                  This bottle contains all the needles conviniently cut
                                  https://www.aliexpress.com/item/50ml-Empty-E-liquid-Plastic-Rosin-Flux-Alcohol-Bottle-For-Dispenser-Rosin-Solder-Flux-Paste-11/32810052820.html?spm=2114.search0204.3.14.37687b2184NHbx&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_10543_5722615_10696_10084_10083_10618_10307_10301_5722715_10059_100031_10103_10624_10623_10622_5722515_10621_10620-10620,searchweb201603_55,ppcSwitch_5_ppcChannel&algo_expid=47557fe8-25e4-4763-96f0-5831fc4e628f-1&algo_pvid=47557fe8-25e4-4763-96f0-5831fc4e628f&priceBeautifyAB=0
                                  • T Toyman
                                    NeverDieN
                                    NeverDieN
                                    @toyman What about the syringes? Do you have a link for those as well?
                                    I suppose a syringe gun might be handy, if no stepper motor operated one is available:
                                    https://www.aliexpress.com/item/New-Arrival-Manual-Syringe-Gun-Dispenser-10cc-Glue-Dispensing-Gun/32555533165.html?spm=2114.search0604.8.44.58b37fcbKvXPej&priceBeautifyAB=0
                                      Toyman
                                      @neverdie c'mon, you don't need any special syringe. Ordinary BD will do
                                      Regarding the motor operated one, I actually printed out a full set of 3d parts for the motor oerated syringe but never assembled as there is no need.
                                      If I ever decide to automate the process, I'll make an air driven station with 2 valves. Mechanic solder syringes are supposed to be used with this type of dispensers.
                                      • Nca78N
                                        Nca78N
                                        So I gave it a try today with a solder paste syringe from AliExpress (not perempted like the paste I got from my local shop before). I used a normal syringe pusher (after removing the rubber end) and it went relatively smoothly with a green colored needle (don't know the diameter). I guess I'll try the small syringe technique as it must be easier to have regular flow, but it was good enough.
                                        Without much training I managed to solder my ESP32 module (and 2 buttons) to the adapter board. I used my small 10*10cm hotplate, remotely following the reflow profile for this solder type and all connections are good.
                                        T NeverDieN 2 Replies Last reply
                                        • Nca78N Nca78
                                          Toyman
                                          @nca78 said in SMD Reflow Oven / PID:
                                          interesting. Do you use an ordinary kitchen hotplate?
                                          Nca78N 1 Reply Last reply
