  3. HC12 Serial Radio
HC12 Serial Radio
8 Posts 5 Posters 2.4k Views 4 Watching
    mcrahr
    Does anyone know if there are work done to support the HC12 radio ?
    If not I might give it a go.
    Be.
    Michael
    YveauxY 1 Reply Last reply
    • M mcrahr
      Be.
      Michael
      YveauxY
      YveauxY
      @mcrahr no, it's not supported by mySensors.
      Feel free to add support for it, but to get it included in the stack it requires long time maintenance and support. Would you be able to supply it?
        mcrahr
        I would think so.
        • J
          J
          Johhnywalter
          wrote on last edited by Johhnywalter
          Is it possible to program the microcontroller on the HC12 board to directly read simple inputs such as switches or a voltage and send a signal by itself best socket? Or maybe pull up or down a pin when certain command is received?
          Great article!
          Regards,
          Jon
          • rozpruwaczR
            rozpruwaczR
            rozpruwacz
            I would say that it is possible, but it would be a lot of work to make such software - unless you have access to source code that is run on this module.
            • scalzS
              scalzS
              wrote on last edited by scalz
              @Johhnywalter i don't think so, it's a transceiver only..and the very few IOs may be used for the serial comm (from datasheet for tx,rx).
              imho a rf spi module has faster communication (so, more sw freedom for the rf stack) and "easier" to use, as it doesn't need to have a free serial or deal with softserial.
              • rozpruwaczR
                rozpruwaczR
                rozpruwacz
                there is MCU onboard, it is stm8s
                • J
                  J
                  Johhnywalter
                  Ok,thanks for responds guys
